darinh
Posted: Sat Mar 29, 2008 6:29 pm Post subject: Rudder Cable Adjustment? |
What have you guys done for adjustment in the rudder cables? My kit comes with a set of rudder brackets that have a seriies of holes for adjustment but they are rather course adjustments. What about fine adjustment for cable stretch and small adjustments in rudder centering? has anyone used clip locking or safety wire turnbuckles? If so, where did you locate the turnbuckles? Pics would be great if you have them.
_________________ Darin Hawkes
Series 7
914 Turbo
Kaysville, Utah |
dan(at)azshowersolutions. Guest
Posted: Sun Mar 30, 2008 5:45 am Post subject: Rudder Cable Adjustment? |
Darin,
How are things going up in Utah? Sounds like you are making good progress.
I decided to put these turnbuckles... http://www.azshowersolutions.com/Fuselage11.html on the back of the rudder cables. I used the brackets at the front. I found everything I needed at Spruce.
Dan B
Mesa, AZ KF-IV 912s
darinh <gerns25(at)netscape.net> wrote:
[quote]--> Kitfox-List message posted by: "darinh"
What have you guys done for adjustment in the rudder cables? My kit comes with a set of rudder brackets that have a seriies of holes for adjustment but they are rather course adjustments. What about fine adjustment for cable stretch and small adjustments in rudder centering? has anyone used clip [quote][b]
dcsfoto
Posted: Sun Mar 30, 2008 5:55 am Post subject: Re: Rudder Cable Adjustment? |
model 7 has the handles in the center console for adjust,brackets for fine adjust.
rudder should center if done by the manual.
I would not mess with turnbuckels.
David Model 7 & 3
Do not arcive
Lynn Matteson
Posted: Sun Mar 30, 2008 7:13 am Post subject: Rudder Cable Adjustment? |
I thought that there should be a finer adjustment than the coarse
1/2" or whatever those straps/links would provide, too. So I went
with turnbuckles at the front inside the cabin. Since I installed
them, I've never had to touch them. I used a clean-looking fork at
the back swaged onto the cable.
After flying the thing for two years, I've found that the adjustment
is all in the feet of the pilot...yes, get the initial setting done
right so that the pedals are correctly placed, and that's it. At
least that's what worked for me with a Model IV, maybe/probably not
the same for the 7.
Lynn Matteson
flying w/480+ hrs/down for annual
On Mar 29, 2008, at 10:29 PM, darinh wrote:
Darin Hawkes
Series 7 (Painting)
914 Turbo
Kaysville, Utah
http://forums.matronics.com/viewtopic.php?p=173597#173597
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
darinh
Posted: Sun Mar 30, 2008 9:50 am Post subject: Re: Rudder Cable Adjustment? |
Dan,
It is going great up here...making good progress but still a ways to go. I looked at those same turnbuckles...can you tell me the overall lenght from end to end with the cable hardware?
I have set the rudder per the manual and all is as it should be now but in my experience (which is not much I must admit) cable systems tend to relax or break in over time and the turnbuckles would allow for this small amount of slop to be adjusted out. As far as the center console adjustment goes, this only changes peddle location and has nothing to do with the length of the cables...the "fine" adjustment in the brackets is not very fine. I think I will leave them as is now and if the cables stretch over time, I will install the turnbuckles like Lynn did...in the center console in the cabin.
Series 7
914 Turbo
Kaysville, Utah |
Posted: Sun Mar 30, 2008 11:54 am Post subject: Rudder Cable Adjustment? |
Darin,
With the turnbuckle closed, it measures 3.75" from nose to tail.... If I measure it all including the cable swag hardware it is 5"
It looks like the turnbuckles will give somewhere between 1 and 1.5" of adjustment.
Dan B Mesa, AZ
KF-IV 912s
Dan,
I have set the rudder per the manual and all is as it should be now but in my experience (which is not much I must admit) cable systems tend to relax or break in over time and the turnbuckles would allow for this small amount [quote][b]
darinh
Posted: Sun Mar 30, 2008 2:33 pm Post subject: Re: Rudder Cable Adjustment? |
Thanks Dan, these should fit just fine in the center console.
Series 7
914 Turbo
Kaysville, Utah |
