rcsfca
Joined: 22 Feb 2008 Posts: 10 Location: San Francisco Bay Area
Posted: Fri Mar 28, 2008 8:43 pm Post subject: Black paint |
Paint jobs that are predominantly black are rather rare but I've come up with a re-paint scheme that is exactly that, although the design includes substantial red and orange stripes for contrast.
Has anyone taken a close look at the use (or rejection) of black paint as it relates to excessive cabin heating on sunny days, gas tank expansion, or navigation perception problems? Or other troubles, if any?
Rich Cunningham
Model IV - 1200/912
SF Bay Area
avidfox
Posted: Sat Mar 29, 2008 12:04 am Post subject: Black paint |
Michel
Posted: Sat Mar 29, 2008 12:48 am Post subject: Black paint |
| Quote: | From: rcsfca [r66rc-matronics(at)yahoo.com]
If I remember correctly, someone on this list once wrote that the US air force found out that black is the most visible colour for an aircraft in the sky. My Kitfox is dark blue and even in the Norwegian climate, it warms up the wing tanks in the summer and I can see petrol evaporating from the cover vents.
One solution is then to paint the top fuselage and wing tanks white as the French Broussard aircraft were. (here is the link of a Norwegian Broussard with the original French paint work): http://www.airliners.net/open.file?id=0442553
If, in addition you paint the nose, wing tips and rudder in bright orange, you'll get a quite visible aircraft in the air and on the ground. I am not too sure how sexy it will look but, at least, it will be functional.
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200
Lynn Matteson
Posted: Sat Mar 29, 2008 3:01 am Post subject: Black paint |
It looks pretty visible to me, Michel, as viewed on page 45 of
Kitplanes, April 2008 issue. : )
Lynn Matteson
flying w/480+ hrs/down for annual
On Mar 29, 2008, at 4:45 AM, Michel Verheughe wrote:
| Quote: | If, in addition you paint the nose, wing tips and rudder in bright
will be functional.
Michel Verheughe
Norway
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Mdkitfox(at)aol.com Guest
Posted: Sat Mar 29, 2008 3:55 am Post subject: Black paint |
I believe it was Don Smythe, Newport News, VA (formerly on the list and one hell of a nice guy) that had the problem with his model IV. I saw his aircraft (can't remember the color right now) and it had heated up enough to shrink the tapes at a different rate than the cover fabric on the top of the wing. The temps inside the wing were measured and they were very high. I would avoid the dark colors just based on his experience. Also, there is no doubt, if the tanks were filled in the cool of the evening and subsequently left in the sun, the fuel would expend and run out the vents.
Rick Weiss
Series V Speedster - N39RW, 912S Power
DO NOT ARCHIVE
In a message dated 3/29/2008 12:48:00 A.M. Eastern Daylight Time, r66rc-matronics(at)yahoo.com writes:
| Quote: | --> Kitfox-List message posted by: "rcsfca" <r66rc-matronics(at)yahoo.com>
Rich Cunningham
Model IV - 1200/912
SF Bay Area
http://forums.matronics.com/viewtopic.php?p=173371#173371
Create a Home Theater Like the Pros. Watch the video on AOL Home.
dcsfoto
Posted: Sat Mar 29, 2008 4:10 am Post subject: Re: Black paint |
the covering manual warns about problems with tapes and use of dark green or black
David
do not arcive
Michel
Posted: Sat Mar 29, 2008 4:13 am Post subject: Black paint |
| Quote: | From: Lynn Matteson [lynnmatt(at)jps.net]
.. now you got me really puzzled, Lynn. We can't get Kitplanes in the newsstands, here in Norway, so I have no way to find out myself. Yesterday, I received an email from Chuck Bodeen, an old friend from the X-Plane simulator, mentionning the new issue of Kitplanes and his article about safety by simulation, if I remember correctly. Is it what you refer to?
Michel Verheughe
Norway
kitfoxpilot(at)msn.com Guest
Posted: Sat Mar 29, 2008 4:22 am Post subject: Black paint |
Windows Live Hotmail is giving away Zunes. Enter for your chance to win. [quote][b]
Float Flyr
Posted: Sat Mar 29, 2008 5:59 am Post subject: Black paint |
Something like this Michel
In flight
Noel Loveys
Campbellton, NL, Canada
CDN AME intern, PP-Rec
C-FINB, Kitfox III-A
582 B box, Ivo IFA, Aerocet 1100 floats
[url=noelloveys(at)yahoo.ca]noelloveys(at)yahoo.ca[/url]
Do not Archive
7.29 KB |
14698 Time(s) |
44.71 KB |
785 Time(s) |
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
patreilly43(at)hotmail.co Guest
Posted: Sat Mar 29, 2008 6:14 am Post subject: Black paint |
Michel, Thanks for the picture of the french plane with the white top. I am rebuilding a mod 3. I had to recover the fusalage and plan on leaving the wings yellow as the whole plane was, and painting the fusalage black. The yellow cowel, wings, rudder, elevator and horiz stabilizer will be almost exactly as you describe a highly visable plane to be. I might play with painting the top half of the fusalage yellow. Might work? And, the answer to the energy solution is to get our government out of it. Let the market pay for and develope alternative fuels when the price of present fuels gets too high. Fossile fuels are the most efficient economical source of power presently. Our main source of food supply is corn and now the government is mandating that we burn our food for fuel. As usual a government solution to any problem is futile. Most Americans are economically ignorant, including most of the politians that pander to the rank and file buying their votes. I also saw your name in Kitplanes.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
| Quote: | Date: Sat, 29 Mar 2008 09:45:06 +0100
Subject: RE: Black paint
Michel Verheughe
Norway
<pre><b><font size=2 color="#000000" face="courier new,courier">> _-========================.com/contribution">http://www.matronics.com/contribution</a>
&g============
</b></font></pre></body></html>
Float Flyr
Posted: Sat Mar 29, 2008 6:34 am Post subject: Black paint |
Ray:
Your last three or four posts have been completely blank... all the others are coming through.
Noel
Do not archive.
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of RAY Gignac
Sent: Saturday, March 29, 2008 9:50 AM
Windows Live Hotmail is giving away Zunes. Enter for your chance to win. | Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 0123456789
Kitfox III-A
darinh
Posted: Sat Mar 29, 2008 7:22 am Post subject: Re: Black paint |
Rich,
My Series 7 has a bunch on black on it but I avoided (with the exception of wing tips & stab tips) painting any horizontal surfaces black. I pirated the scheme of one of the best looking Aviat Husky's (in my opinion) I have seen. I have not had it out in the sun yet but I don't think there will be any problems with my particular scheme. Another problem with the dark colors is they show nearly every scratch. Attached is a picture of the Husky...my Kitfox has nearly an identical scheme.
106.94 KB |
847 Time(s) |
_________________ Darin Hawkes
Series 7
914 Turbo
Kaysville, Utah |
Lynn Matteson
Posted: Sat Mar 29, 2008 9:12 am Post subject: Black paint |
Yup, that's the one. Shows a picture of your plane landing amidst a
flock of seagulls, and mentions landing at ENFB, and you informing
him of the difficulty of landing there now that it has closed.
Lynn Matteson
On Mar 29, 2008, at 8:11 AM, Michel Verheughe wrote:
| Quote: | > From: Lynn Matteson [lynnmatt(at)jps.net]
... now you got me really puzzled, Lynn. We can't get Kitplanes in
Michel Verheughe
Norway
List">http://www.matronics.com/Navigator?Kitfox-List</a>
forums.matronics.com</a>
</b></font></pre>
N369LM |
rcsfca
Posted: Sat Mar 29, 2008 9:51 am Post subject: Re: Black paint |
Thanks, everyone, for chiming in on the black paint issue.
I did a little digging across the web and found a graph (attached below) that portrays surface temperature as a function of paint colors. This comes from a website run by a Long-EZ owner-builder who said that "Uncle Burt (Rutan, the Long EZ designer) has essentially said 'you can have a fiberglass airplane in any color you want, as long as it's white.'"
(No doubt a twist of phrase on Henry Ford's famous line that said, I believe, "You could have your Model T in any color as long as it was black.")
Note the reference to the dreaded fiberglass, which is probably the surface material used to compile the graph. For those of you who are interested in reading the whole page, the link is:
http://hallert.net/cozy/paintideas.htm
One interesting aspect of the graph is that the color red is not necessarily your friend either (my KFox is currently red) when compared to the lighter colors, although it does stand a clear 20 degrees lower than black.
Rich Cunningham
Model IV-1200 / 912
SF Bay Area
50.53 KB |
759 Time(s) |
Float Flyr
Posted: Sat Mar 29, 2008 6:42 pm Post subject: Black paint |
Ever notice how the big composite planes all have white skins? 777 engine nacelles only come in white. On the other hand ever try to polish a black car on a sunny day??
Composite or cloth stick to white on top.
Ok to archive.
Noel Loveys
7.29 KB |
14695 Time(s) |
Kitfox III-A
mdkitfox(at)aol.com Guest
Posted: Sat Mar 29, 2008 7:14 pm Post subject: Black paint |
Darin,
Nice looking mean machine! Those tires are awesome. I do like the paint scheme. Keep an eye on the tapes, especially on sunny days.
Rick
In a message dated 03/29/08 11:26:27 Eastern Daylight Time, gerns25(at)netscape.net writes:
| Quote: | .aolmailheader {font-size:8pt; color:black; font-family:Arial} a.aolmailheader:link {color:blue; text-decoration:underline; font-weight:normal} a.aolmailheader:visited {color:magenta; text-decoration:underline; font-weight:normal} a.aolmailheader:active {color:blue; text-decoration:underline; font-weight:normal} a.aolmailheader:hover {color:blue; text-decoration:underline; font-weight:normal} --> Kitfox-List message posted by: "darinh" <gerns25(at)netscape.net>
Rich,
Darin Hawkes
Series 7 (Painting)
914 Turbo
Kaysville, Utah
http://forums.matronics.com/viewtopic.php?p=173422#173422
http://forums.matronics.com//files/husky4_139.bsp; -Matt Dralle, List Admi=========
Supercharge your AIM. Get the AIM toolbar for your browser.
