Non-hinged ailerons with autopilot
rsteele(at)rjsit.com
PostPosted: Sun Mar 23, 2008 11:34 am    Post subject: Non-hinged ailerons with autopilot Reply with quote
At some point I'll want to add an autopilot to my 601xl. I seem to
remember seeing something about someone having a problem with the
hingeless ailerons because the force needed to move them caused the
clutch to slip. Anybody have any experience with autopilots on a
601? My kit ailerons are hingeless and I'm really not wanting to
modify them for hinges, but want to avoid problems down the road.
Ron
craig(at)craigandjean.com
PostPosted: Sun Mar 23, 2008 12:21 pm    Post subject: Non-hinged ailerons with autopilot Reply with quote
Actually I was told by an owner of an XL with *hinged* ailerons that his
Trio Avionics servo slipped. But since he had a two axis system I don't know
which servo was slipping. The installation of the altitude hold servo was a
little unusual on this plane. It was mounted on the firewall (pictures
attached).
BTW: this was one of the two "twin" XLs built at Quality Sport Planes in
California by Alan and Steve Smith. I can't recall if it was Alan or Steve
who mentioned the slippage. But their two planes are essentially identical.
http://www.qualitysportplanes.com/qsp-2006_072.htm
Others have said that in flight most of the stick force comes from the wind
over ailerons and that the type of hinge was only a small factor.
-- Craig
 Filesize:  76.67 KB
 Viewed:  1032 Time(s)
 Filesize:  70.81 KB
 Viewed:  1045 Time(s)
bryanmmartin
PostPosted: Sun Mar 23, 2008 3:53 pm    Post subject: Non-hinged ailerons with autopilot Reply with quote
One of the guys at my home field also has a Zodiac with the hingeless
ailerons. He installed an auto-pilot in his and seems to have no
problems with it. I believe it was a Tru-Trak system. A group of us
flew from the Detroit area to the Zenith open hangar day a few of
years ago and he had no issues with it on that trip.
Ron
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
Bryan Martin
do not archive.
PostPosted: Sun Mar 23, 2008 4:38 pm    Post subject: Non-hinged ailerons with autopilot Reply with quote
Great, this is just the kind of info I was hoping would show up.
Hingeless it is!
Ron
On Mar 23, 2008, at 7:49 PM, Bryan Martin wrote:
<bryanmmartin(at)comcast.net>
hingeless ailerons. He installed an auto-pilot in his and seems to
have no problems with it. I believe it was a Tru-Trak system. A
group of us flew from the Detroit area to the Zenith open hangar
day a few of years ago and he had no issues with it on that trip.
> to remember seeing something about someone having a problem with
> the hingeless ailerons because the force needed to move them
> caused the clutch to slip. Anybody have any experience with
> autopilots on a 601? My kit ailerons are hingeless and I'm really
> not wanting to modify them for hinges, but want to avoid problems
> down the road.
> Ron
Bryan Martin
N61BM, CH 601 XL,
do not archive.
jlivsey(at)bigpond.com
PostPosted: Tue Mar 25, 2008 12:41 am    Post subject: Non-hinged ailerons with autopilot Reply with quote
Hi Ron,
As per other replies I fitted a Trio Single axis autopilot (Wing
Leveller) to my CH601HDS and it was the best thing I have done. I think
the CH601-HDS has longer ailerons than the XL and they are "hingeless"
and I'm not aware of any real servo slip. Even if it does slip a bit in
real bumpy conditions occasionally it doesn't matter, it won't get
itself out of position, it will just take a bit longer to get back
straight and level. Remember you can always "assist" the servo with some
gentle stick input !!!
You can check out my installation at
http://camilla.homelinux.net/flying/modifications/auto%20pilot/ the real
mistake I made was that it was a retrofit and I couldn't get to the back
of the GPS easily so I had to cut an access panel in the fwd fuselage
top cover. Should have done the access panel when I was building. My
advice, make sure you can get at all the required wiring !!! (Or build
the access panel during construction)
Regards, John Livsey
steveadams
PostPosted: Tue Mar 25, 2008 4:22 am    Post subject: Re: Non-hinged ailerons with autopilot Reply with quote
Also be aware that trutrak has 3 different servos with progressively higher torque. They all fit in the same mount, so if you try the smallest one, and it slips, you can exchange it for a higher torque servo pretty easily. I don't know if trio has similar options. On my CH640, I had to use the highest torque servo.
Steve
CH640
PostPosted: Tue Mar 25, 2008 3:06 pm    Post subject: Non-hinged ailerons with autopilot Reply with quote
Thanks to everyone who has replied.
I looked over the pictures. Is there some sort of triangular fitting
where the control rod connects to the cables? It looks like there
would be a lot of slop in the connection. I'm sure it's just because
I can't make out how the connection works
Ron
On Mar 25, 2008, at 4:33 AM, John Livsey wrote:
Hi Ron,
think the CH601-HDS has longer ailerons than the XL and they are
"hingeless" and I'm not aware of any real servo slip. Even if it
does slip a bit in real bumpy conditions occasionally it doesn't
matter, it won't get itself out of position, it will just take a
bit longer to get back straight and level. Remember you can always
"assist" the servo with some gentle stick input !!!
You can check out my installation at http://camilla.homelinux.net/
flying/modifications/auto%20pilot/ the real mistake I made was that
it was a retrofit and I couldn't get to the back of the GPS easily
so I had to cut an access panel in the fwd fuselage top cover.
Should have done the access panel when I was building. My advice,
make sure you can get at all the required wiring !!! (Or build the
PostPosted: Wed Mar 26, 2008 1:18 am    Post subject: Non-hinged ailerons with autopilot Reply with quote
Hi Ron,
I assume you are talking about the pics on my web pages. I just had a
look at the pics and agree its perhaps a bit difficult to make out how
it fits together. So I'll try and describe it. Please remember my A/C is
a 601HDS, I don't have any drawings of the XL but I assume its similar.
1. The servo fits in a tray between a doubler and the rear spar
immediately behind the pilots seat. This is seen in the second last picture.
2. The control rod from the servo heads towards the centre of the A/C
and its bolted to the steel piece that is welded to the end of the
torque tube for the aileron cable attachment. It is bolted between the
aileron connection (above the aileron pick-up) and the actual torque
tube proper. This is shown in the fourth and fifth last pictures. The
steel piece I am talking about is painted black.
There is no connection onto the actual aileron cables, only the torque
tube. There is absolutely no slop in the system.
planecrazydld(at)yahoo.co
PostPosted: Wed Mar 26, 2008 5:02 am    Post subject: Non-hinged ailerons with autopilot Reply with quote
the only thing that would cause me to question the hingeless hinge is if the hinge protion were made from a heavier gage than designed. The forces climb and the fatigue capacity goes down.
Ronald Steele <rsteele(at)rjsit.com> wrote: [quote]--> Zenith-List message posted by: Ronald Steele
Hingeless it is!
Ron
[quote] --> Zenith-List message posted by: Bryan Martin
> down the road.
> Ron
Bryan Martin
N61BM, CH 601 XL,
do not Be a better friend, newshound, and [quote][b]
PostPosted: Wed Mar 26, 2008 12:53 pm    Post subject: Non-hinged ailerons with autopilot Reply with quote
Ah, got it. Makes perfect sense.
Ron
Gig Giacona
PostPosted: Wed Mar 26, 2008 1:16 pm    Post subject: Re: Non-hinged ailerons with autopilot Reply with quote
Since we are talking about autopilots. I just noticed that Dynon has announced the AP add-on for there line of EFIS.
At the low end of the line you can have a single servo unit for just $750
W.R. "Gig" Giacona
601XL Under Construction
hansriet
PostPosted: Wed Mar 26, 2008 1:54 pm    Post subject: Re: Non-hinged ailerons with autopilot Reply with quote
I've read about it in kitplanes, but can't find anything on thge dynonavionics website.
PostPosted: Wed Mar 26, 2008 2:12 pm    Post subject: Non-hinged ailerons with autopilot Reply with quote
Now that sounds interesting. I've been wondering why this hasn't
happened in the past. I'm sort of surprised that the Enigma didn't get
there first with it's everything in one approach.
I'm a software engineer by profession and I've been thinking it would be
fun to write an AP, but I'm completely clueless about hardware
interfaces. No time while building anyway.
Ron
601Xl wings
Gig Giacona
PostPosted: Thu Mar 27, 2008 7:32 am    Post subject: Re: Non-hinged ailerons with autopilot Reply with quote
Look in the support forums on the Dynon site. There is a thread with LOTS of info.
W.R. "Gig" Giacona
hansriet
PostPosted: Thu Mar 27, 2008 7:47 am    Post subject: Re: Non-hinged ailerons with autopilot Reply with quote
[quote="Gig Giacona"]Look in the support forums on the Dynon site. There is a thread with LOTS of info.
Thanks, that's great info and exciting news. Makes perfect sense to utilize the Dynon solid state gyros for this.
Gig Giacona
PostPosted: Thu Mar 27, 2008 8:37 am    Post subject: Re: Non-hinged ailerons with autopilot Reply with quote
Looks like the hardware is the hard, or at least, costly part. It seems that Dynon isn't even charging for the software.
Ron
601Xl wings
W.R. "Gig" Giacona
PostPosted: Thu Mar 27, 2008 9:40 am    Post subject: Non-hinged ailerons with autopilot Reply with quote
Actually Rainier (head of MGL) just announced they will be developing their
own servos on the Stratomaster users group on Yahoo:
<quote>
There have been on and off requests in the past for us to produce an
autopilot. I tended to answer this in the negative but it has been a low key
project. You can find a autopilot simulator in the Odyssey simulator. Active
a "goto", switch the HSI to GPS nav and engage the autopilot and it will fly
your track. This works with whatever you can throw at the HSI and of course
the altitude bug works as well as vertical source.
Due to "you know who" imminent release of their autopilot interface I have
decided to break cover to avoid the "why did you not tell us"
scenarios that could emerge - I suppose my hand has been "forced".
Effectively we will introduce CAN bus controlled intelligent servos that you
can plug into an Odyssey, Voyager or Explorer. Enigma will need a small
external CAN interface.
The servos are similar in principle to the ones produced by Trutrak, i.e.
based on a geared stepper motor. This allows simplicity and a high degree of
reliability due to few parts. Servos like this are "clutch-less" and have a
very small amount of residual drag when not engaged - but so little that is
not noticeable in flight. They have a number of good advantages -
effectively they are a magnetic clutch that cannot wear and the trip torque
(torque required to override the servo) can easily be programmed in a wide
range from the panel.
As the CAN bus is multi-master and multi-drop, there is no limit to the
number and configuration of servos which means you can have a single axis, 2
axis, 3 axis (with rudder control) and 4 axis (the forth axis is throttle).
Split servos are also possible (for example one for each aileron) The servos
can be controlled from either panel in a multi panel system for redundancy.
Of course the existing ARINC429 and NMEA based autopilot interfaces will
continue to be supported.
I was planning to announce this later in the year but have now decided to
bring this forward and should be showing them of at Osh.
Rainier
<end quote>
-- Craig
Gig Giacona
PostPosted: Thu Mar 27, 2008 12:34 pm    Post subject: Re: Non-hinged ailerons with autopilot Reply with quote
All these lower cost EFIS add-on APs have got to have the folks that make the AP only units wetting themselves.
W.R. "Gig" Giacona
engineerguy3737(at)yahoo.
PostPosted: Thu Mar 27, 2008 1:18 pm    Post subject: Non-hinged ailerons with autopilot Reply with quote
Although I am working on a different project, I get to
hear all of the discussions over the cube walls.
The software is just as difficult as the hardware.
The base algorithm has been flying for years in UAVs.
As with all of our products, we don't release them
until they are have been rigorously tested and we are
assured that they work as they should.
The autopilot information should be up on the website
in the next few days.
To answer the basic questions:
- Our servo is the same size/shape as TruTraks.
- It weighs less than the TruTrak servo.
- You can't use TruTrak servos with our autopilot.
- It can use the TruTrak mounting kit.
- You don't need to buy an AP-74 or AP-76 for our
autopilot to function.
- It uses only 4 wires.
- Each servo costs only $750.
My wife and I plan on being at the Cloverdale fly-in
in May. I'll do my best to bring along a servo and our
Zenith mounting kit if I can. We are looking forward
to seeing many of you again!
Dan Lykowski
601XL Builder( Tail finished / Wings underway )
Software Engineer
Dynon Avionics
for the software.
why this hasn't
about hardware
> Ron
> 601Xl wings
> do not archive
W.R. &quot;Gig&quot; Giacona
http://forums.matronics.com/viewtopic.php?p=173043#173043
browse
Un/Subscription,
FAQ,
Forums!
Admin.
Looking for last minute shopping deals?
PostPosted: Thu Mar 27, 2008 3:14 pm    Post subject: Non-hinged ailerons with autopilot Reply with quote
As well as those of us planning to install one. To me this is really
exciting. Maybe that means I'm basically a boring person! What I love
most is just watching the world slide by down below.
Ron
