grantr
Posted: Mon Mar 24, 2008 5:28 pm Post subject: Mark III Landing gear wheel alignment |
The Wheels on my plane are not set right as of now they are set like this:
Left gear: toe out 2.5*
Right gear: toe in 5.5*
This gives my plane a left sideways track.
What is the easiest way to correct this? We were thinking to ream out the hole in the (axle holder) the steel piece on the end of the landing gear leg so that the axle holder can be rotated on the gear leg to the right position. Once the right position is set the enlarged hole will be welded partially shut and re drilled to round the hole in the correct position.
What are your thoughts on this?
ElleryWeld(at)aol.com Guest
Posted: Mon Mar 24, 2008 6:14 pm Post subject: Mark III Landing gear wheel alignment |
without looking at your particular problem there are a couple ways to look at it you could drill the holes out bigger on the 4130 axle piece that slips over the aluminum gear leg install big enough washers ,align the gear and weld the washers in place to hold it in place I would tack weld it make sure the gear is where you want it then remove to finish welding it or You could look at re drilling on the upper end of the gear leg to get your gear lined up mabe slide the leg in or out a bit to give you a good solid hole placement
worth what you paid for it have fun
Ellery in Maine
In a message dated 3/24/2008 8:31:48 P.M. Eastern Standard Time, grant_richardson25(at)yahoo.com writes:
| Quote: | --> Kolb-List message posted by: "grantr" <grant_richardson25(at)yahoo.com>
http://forums.matronics.com/viewtopic.php?p=172400#172400
Create a Home Theater Like the Pros. Watch the video on AOL Home.
Posted: Mon Mar 24, 2008 6:17 pm Post subject: Mark III Landing gear wheel alignment |
At 06:28 PM 3/24/08 -0700, you wrote:
Grant,
Do you have aluminum legs?
Jack B. Hart FF004
Winchester, IN
Wade Lawicki
Joined: 27 May 2007 Posts: 31 Location: Nashville Tn.
Posted: Mon Mar 24, 2008 7:37 pm Post subject: Re: Mark III Landing gear wheel alignment |
Grant,
I did my FS a couple months ago. Took the wheels off, axles out, used a fiberglass rod or electric conduit through both axles to align. I pulled my aluminum gear legs out a half inch and re drilled the top holes. I did lower the axles to the ground and load the gear before drilling.
Fly Safe,
Wade
_________________ Fly Safe! Wade
Nashville Tn.
FS 2 |
