ELTs
tdawson-townsend(at)auror
PostPosted: Fri Mar 21, 2008 4:42 am    Post subject: ELTs Reply with quote
Jose wrote:
“I have an Ameriking AK450 ELT (121.5/243.0MHz)”
After next January, the satellites are going to stop listening for 121.5 MHz (too many false alerts), and instead only listen for 406 MHz. So you best bet is to buy a new ELT next year.
Bob wrote:
“On the other side of the coin, the probability that this piece
of equipment will be a major contributor to your surviving the
unplanned arrival with the earth is low. An article published
in one of the journals a couple of years ago cited something
much less than 10% of recovery situations where the ELT figured
strongly in the success of the operation.”
The poor performance of 121.5 MHz probably contributes to that. The 406 MHz signal will offer better accuracy at determining your position, and do it faster, too. Remember the accident that spurred closing a loophole that allowed business jets to fly without ELTs: A Learjet with no ELT went down within 30 miles or so of taking off of Lebanon, NH, but due to snow cover and then dense forest, they didn’t find it for over a year . . .
TDT
Tim Dawson-Townsend
RV-10 N52KS
tdt(at)aurora.aero (tdt(at)aurora.aero)
617-500-4812 (office)
617-905-4800 (mobile)
paula.alvary(at)verizon.n
PostPosted: Fri Mar 21, 2008 11:58 am    Post subject: ELTs Reply with quote
Admittedly, my 121.5/243.0MHz ELT offers little insurance in case of a crash. Not only is it old technology, but in the best scenario it will probably go undetected for the various reasons that Bob stated. (Case in point, who knows what direction the antenna will wind up in after a crash?) That is why I did not go to the extent of doing the antenna in the best fashion that we know how to do. However, even after emergency services stop listening, it still meets the FAA requirement for an ELT as detailed in the recent EAA Sport Aviation article. My question was simply trying to determine if what I did was next to useless or had a reasonable chance of radiating some RF energy.
--Jose
BobsV35B(at)aol.com
PostPosted: Fri Mar 21, 2008 12:19 pm    Post subject: ELTs Reply with quote
Good Afternoon Jose,
Please understand that I am not an expert on the FARs and I have very little electronic knowledge, but I do have a question concerning your antenna installation.
Is it not true that the ELT is a required piece of requirement?
Because of that, is it not true that the emission from the ELT must meet some certain standard?
The last one that I installed did have specifications concerning the available signal emission. It said the antenna that came with the set OR an antennae that met specified standards must be used before the ELT met the regulatory standards.
I realize that many regulations do not apply to OBAM aircraft, but I would not be surprised if the regulations concerning the ELT must be followed.
Any thoughts thereon?
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
628 West 86th Street
Downers Grove, IL 60516
630 985-8502
Stearman N3977A
Brookeridge Air Park LL22
In a message dated 3/21/2008 2:59:52 P.M. Central Daylight Time, paula.alvary(at)verizon.net writes:
--Jose
Create a Home Theater Like the Pros. Watch the video on AOL Home.
frank.hinde(at)hp.com
Answer Steve Fossett!
Just the chance of the g switch not working, the antenna being ripped off is enough to push me to the PLB...Ya sure its another chore to set it off...buts its #2 on my emergency list.
I also make sure I am talking to ATC when going across the rocks..I just file an IFR flight plan because I can, but VFR flight following is as good as long as they will do it for you.
I migth also look into an APHRS datalogger at some point.
Frank
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Palvary
Sent: Friday, March 21, 2008 1:54 PM
Subject: Re: AeroElectric-List: ELTs
--Jose
ist">http://www.matronics.com/Navigator?AeroElectric-List
ics.com
.matronics.com/contribution
nuckolls.bob(at)cox.net
PostPosted: Fri Mar 21, 2008 12:23 pm    Post subject: ELTs Reply with quote
Sounds like you have a realistic understanding of the
capabilities/limitations for the system. The simple answer
is, "yes, the thing will radiate . . . and probably no worse
than some less-than-ideal installations found on some certified
aircraft." Best yet, it keeps those-who-know-more-about-airplanes-
than-we-do at arms length . . . for awhile.
( -Thomas Paine 1776- )
PostPosted: Fri Mar 21, 2008 12:37 pm    Post subject: ELTs Reply with quote
Oh yes, the 125.5 ELT has to have an RF power output of just 100mW...PLB's (or 406MHz ELTS) have an output of 5W...I.e a 50 times stronger signal...Apparently the signal even punches through tree cover.
Its the emergency equivilent of a big battery drill compared to a screwdriver...Smile
frank
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Hinde, Frank George (Corvallis)
Sent: Friday, March 21, 2008 1:16 PM
Subject: RE: ELTs
Frank
--Jose
ics.com
ics.com
Bill Denton
PostPosted: Fri Mar 21, 2008 12:43 pm    Post subject: ELTs Reply with quote
I’m not 100% sure, but if you are talking about an Artex ELT, I believe that the TSO covers the unit AND the antenna. If you don’t install the correct antenna properly, you won’t meet the TSO. And that could lead to an inspection problem.
You might want to check the manufacturer’s website…
Thanks!
Bill Denton
bdenton(at)bdenton.com
Sent: Friday, March 21, 2008 3:54 PM
Subject: Re: ELTs
--Jose
mprather(at)spro.net
PostPosted: Fri Mar 21, 2008 1:21 pm    Post subject: ELTs Reply with quote
What was the question??
There's a good amount of the western US over which I have flown where the
minimum radar altitude is above 11000MSL. The MEA on the route between
BOI and TWF is 10000MSL and there aren't any passes to cross; the route
can be comfortably flown at 5500 - and not be even slightly close to
terrain. Having to climb to 10000 on such a short trip isn't particularly
efficient... I agree with the philosophy you are proposing however.
Frank
Matt-
PostPosted: Fri Mar 21, 2008 1:37 pm    Post subject: ELTs Reply with quote
Hi Bob S.,
[quote] Because of that, is it not true that the emission from the ELT must meet some certain standard?
------A good point worth considering. I do not have an anwer nor meter to check the output. Best I can do for now is just do a tower check on the hour. I do know that my ELT came with a simple (non-loaded) telescoping antenna (which had broken and dissappeared) and I think the solid wire antenna I made is hopefully as good as that one.
Eventually, 406MHz and/or APRS is the way to go.
--Jose
PS-This is the best list ever. Thanks everyone.
Kellym
PostPosted: Fri Mar 21, 2008 5:20 pm    Post subject: ELTs Reply with quote
You are correct. All ELTs must meet TSO, and TSO includes antenna spec.
Even a different brand antenna for ELT does not meet letter of the law.
And yes, it doesn't matter whether experimental or type certified, both
are required by reg to have TSOd ELT.
Thanks!
Bill Denton
Kelly McMullen
KCHD
