AW: Re: 912 with low RPM--- new vibration problem-fixed
lgold(at)quantum-associat
PostPosted: Thu Mar 20, 2008 9:56 am    Post subject: AW: Re: 912 with low RPM--- new vibration problem-fixed Reply with quote
The vibration problem was not due to prop balance. It was a combination of
slightly loose bolts that mount the 912 engine and a slightly off carb sync.
The mechanic told me that the bottom-only mounts will loosen up because the
engine isn't support right. Unless you add mounts on top of the engine these
bolts need serious attention. He suggested changing the four 10mm bolts to
studs and using lock washers, which he said won't loosen.
Les
[quote] --
jack.kuehn(at)gmail.com
PostPosted: Thu Mar 20, 2008 10:34 am    Post subject: AW: Re: 912 with low RPM--- new vibration problem-fixed Reply with quote
What airplane is your Rotax in? Sorry, I've lost track!!
Jack
On Thu, Mar 20, 2008 at 11:51 AM, Les Goldner
Les
PostPosted: Thu Mar 20, 2008 2:41 pm    Post subject: AW: Re: 912 with low RPM--- new vibration problem-fixed Reply with quote
Jack,
The plane is a Zenith CH701 STOL/bush plane with 20 hours on it. I have
attached a picture but don't know if Matronics will post it. Zenith came out
with a better 912 mounting arrangement this year, but I don't want to spend
the bucks and time it would take to install it.
Les
[quote] --
 Filesize:  17.96 KB
 Viewed:  778 Time(s)
PostPosted: Thu Mar 20, 2008 3:12 pm    Post subject: AW: Re: 912 with low RPM--- new vibration problem-fixed Reply with quote
The picture came through fine. Nice Airplane!!!
On Thu, Mar 20, 2008 at 4:38 PM, Les Goldner
[quote] Jack,
Les
Roger Lee
PostPosted: Thu Mar 20, 2008 8:25 pm    Post subject: Re: AW: Re: 912 with low RPM--- new vibration problem-fixed Reply with quote
Congratulations Les,
I know that chasing a ghost can be very frustrating to say the least.
Your problem solving will help us all identify issues and where to look when the answer is not obvious.
Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056
