Nick(at)Scholtes1.com Guest
Posted: Tue Mar 18, 2008 8:47 pm Post subject: Gas Cap Gaskets |
Hi KitFoxers!
I have a quick question, and I apologize in advance for not going
directly to the archives for this, as I'm sure this info is in the
archives somewhere.
Seems as though my gas caps are leaking, and the gaskets need to be
replaced. My question is: Where might I be able to find replacement
gaskets?
Thanks in advance!
Nick Scholtes
grassoe(at)enter.net Guest
Posted: Wed Mar 19, 2008 2:22 am Post subject: Gas Cap Gaskets |
Nick,
Go to your local Mercedes dealer and get part # 140-471-00-79 seal ring.
Works great !
Ed Grasso
dcsfoto
Posted: Wed Mar 19, 2008 4:05 am Post subject: Re: Gas Cap Gaskets |
just had the same problem. got mine from Kitfox along with a spare cap also.
David Model 7,3
n85ae
Posted: Wed Mar 19, 2008 8:05 am Post subject: Re: Gas Cap Gaskets |
Go to the auto parts store and buy some gasket material. That's what I did
and I have been using the ones I made for 3 years now with no leaks.
Plus I got enough material to replace them from time to time for the life
of the plane.
Five minutes work with an exacto knife.
Jeff.
Float Flyr
Posted: Wed Mar 19, 2008 10:28 am Post subject: Gas Cap Gaskets |
I went to my local hardware store an bought a new bayonet mount gas cap. I drilled it an soldered in a short piece of stem tubing for a toilet (it was chromed like the cap) and bent it forward once installed... Total cost about $5.00
A word to the wise is the bayonet type of gas cap is quickly disappearing but they do come with the gaskets installed! I won’t say what happened to my old gas cap only I didn’t fly without a cap.
Noel Loveys
Campbellton, NL, Canada
CDN AME intern, PP-Rec
C-FINB, Kitfox III-A
582 B box, Ivo IFA, Aerocet 1100 floats
[url=noelloveys(at)yahoo.ca]noelloveys(at)yahoo.ca[/url]
7.29 KB |
3530 Time(s) |
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
