sonar1@cox.net
Joined: 02 Oct 2007 Posts: 55 Location: Santa Barbara, Ca
Posted: Mon Mar 17, 2008 12:05 am Post subject: My figures don't compute |
I ran some figures on the XL wing attachments and do not get good answers.
Can someone who has done statics calculations more recently than my 48 years ago check my work and tell me where I went wrong?
Not trying to revive last weeks discussions on the list - just want to talk to an engineer before I go flying.
Do not archive ....................Fred Sanford....N9601....98%.......California
33.88 KB |
526 Time(s) |
ashontz
Posted: Mon Mar 17, 2008 6:12 am Post subject: Re: My figures don't compute |
There are six bolts in there. I think you'd need to redo the analysis using the six bolts. I was going to get my Statics textbook out for this one myself, but I don't think this is a problem, albeit, I'd be damn sure to make sure those bolts were drilled right on the money AND reamed which it of course does call for. Even so, the NTSB never mentioned that joint failing. In fact, the folding occurred further outboard. I think that joint is fine, albeit pretty hairy looking at first glance.
A rough calculation around that fixed center virtual pivot would give about 13,577lbs on one bolt, divided by 6 bolts is 2,262lbs, times 6Gs is still only 13,577lbs per bolt.
That joint is fine.
| sonar1(at)cox.net wrote: | I ran some figures on the XL wing attachments and do not get good answers.
Do not archive ....................Fred Sanford....N9601....98%.......California |
moorecomp
Posted: Mon Mar 17, 2008 6:49 am Post subject: Re: My figures don't compute |
Fred,
I am an A&P, not an aeronautical engineer, but I did work as a structures engineer (liaison engineer) for a major regional airline. My boss was a structures DER and I did design structural repairs and computed the substantiation for repairs that required a form 8130. The simple answer to your calculations, is that we always used the B basis values from the MIL-HDBK-5 (since obsolete). The value for Ftu is 43ksi, but the Fbru is 90ksi (assuming ed > 2.0). If you use the ultimate strength in bearing, I get 7.165 g max. Usually the only time a joint like this is bearing limited, is in very thin materials. Instead of arbitrarily using lower values, normally a published value is used, and then a margin of safety is applied. So after you do your calculations, you then have to correct for your margin of safety (typically 1.5 for transport catagory a/c). Hope this refreshs the memory.
Craig Moore A&P
701 builder wannabe
Mancelona, MI
ashontz
Posted: Mon Mar 17, 2008 6:53 am Post subject: Re: My figures don't compute |
| ashontz wrote: | There are six bolts in there. I think you'd need to redo the analysis using the six bolts. I was going to get my Statics textbook out for this one myself, but I don't think this is a problem, albeit, I'd be damn sure to make sure those bolts were drilled right on the money AND reamed which it of course does call for. Even so, the NTSB never mentioned that joint failing. In fact, the folding occurred further outboard. I think that joint is fine, albeit pretty hairy looking at first glance.
You're leverage around those bolts with the virtual pivot in the center is roughly 20:1 = 74 inches /3.5 inches.
A rough calculation around that fixed center virtual pivot would give about 13,577lbs on one bolt, divided by 6 bolts is 2,262lbs at 1G, 6Gs is still only 13,577lbs per bolt.
That joint is fine.
Posted: Mon Mar 17, 2008 7:25 am Post subject: My figures don't compute |
Does anything in the calculation speak to the tolerances of the six bolt
holes in the spars? I think that the ones in my QBK kit are too sloppy but
ZAC says that the tolerance is 12/1000". Since it is the outside two holes
on each side that are the worse (about 8/1000") it seems to me that those
two bolts won't be supporting a load at all. I'm looking for a tolerance
spec from an independent source.
| Quote: | From what little I have seen some of the RVs use a similar spar joint. Does
Van's specify a tolerance?
-- Craig
notsew_evets(at)frontiern Guest
Posted: Mon Mar 17, 2008 7:33 am Post subject: My figures don't compute |
WHAT ?
22.98 KB |
437 Time(s) |
ashontz
Posted: Mon Mar 17, 2008 7:42 am Post subject: Re: My figures don't compute |
That's pretty damn sloppy, 12 thou. Isn't a human hair like 1 or 2 thousands?
12 thou is almost the thickness of the aileron skin. 12 thou clearance under the fourth leg of a chair on a solid floor is noticable even.
I reamed my own holes and that reamer is the EXACT same size as the Aircraft Spruce bolt I put in there. The difference isn't even measureable with my dial caliper and that's accurate to 1/1000th. The hardest hole to drill and ream is the second one because it's only clamps and one bolt keeping things in alignment. Once you've got two, the rest are easy.
| craig(at)craigandjean.com wrote: | Does anything in the calculation speak to the tolerances of the six bolt
-- Craig
Posted: Mon Mar 17, 2008 9:36 am Post subject: My figures don't compute |
Craig,
The thing here not mentioned is torque compression values that provide
surface friction. This friction offers more load-capability than simple
bolt-to-hole contact-loading and should eliminate your concern for
having less than a perfect fit at the spar holes. It's a best reason
for multiple bolts in this type of assembly.
Craig Payne wrote:
-- Craig
Jeyoung65(at)aol.com Guest
Posted: Mon Mar 17, 2008 9:56 am Post subject: My figures don't compute |
First this is my $0.01 because I do not know how this joint is made. But think you have bolts on top of the spar and bolts on bottom of the spar so you have a compression and a tension joint at the two location. Second the bolts will be the last part to fail so you need to look at the aluminum. The one in compression will fail last, I think, without running the numbers. Also the joint will fail due to tear. Now run the numbers using the cross section of the angle (if there is one there). Don"t forget the webb material. Jerry DO NOT ARCHIVE
In a message dated 3/17/2008 11:03:31 A.M. Eastern Daylight Time, ashontz(at)nbme.org writes:
| Quote: | --> Zenith-List message posted by: "ashontz" <ashontz(at)nbme.org>
ashontz wrote:
| Quote: | There are six bolts in there. I think you'd need to redo the analysis using the six bolts. I was going to get my Statics textbook out for this one myself, but I don't think this is a problem, albeit, I'd be damn sure to make sure those bolts were drilled right on the money AND reamed which it of course does call for. Even so, the NTSB never mentioned that joint failing. In fact, the folding occurred further outboard. I think that joint is fine, albeit pretty hairy looking at first glance.
That joint is fine.
Andy Shontz
CH601XL - Corvair
www.mykitlog.com/ashontz
http://forums.matronics.com/viewtopic.php?p=170377#170377
It's Tax Time! Get tips, forms and advice on AOL Money & Finance.
ashontz
Posted: Mon Mar 17, 2008 10:01 am Post subject: Re: My figures don't compute |
I'm sure the clamping action provides quite a bit of friction, but I can't imagine the friction being the main shear resistance, nor the intended main shear resistance.
| larry(at)macsmachine.com wrote: | Craig,
Craig Payne wrote:
-- Craig
Gig Giacona
Posted: Mon Mar 17, 2008 10:23 am Post subject: Re: My figures don't compute |
This entire thread is an excellent example of mental masturbation. It starts out with a calculation that is wrong primarily because it takes into account 4 bolts instead of 14 (because from a quick glance it doesn't even take into account the rear attach points and then goes down hill from there.
Sorry for the language if it offends anyone but I fine the thread rather offensive.
Is there anyway we could get back to questions regarding building and flying Zeniths?
DO NOT ARCHIVE
601XL Under Construction
ashontz
Posted: Mon Mar 17, 2008 10:38 am Post subject: Re: My figures don't compute |
Just for the record, I was actually defending that joint.
| Gig Giacona wrote: | This entire thread is an excellent example of mental masturbation. It starts out with a calculation that is wrong primarily because it takes into account 4 bolts instead of 14 (because from a quick glance it doesn't even take into account the rear attach points and then goes down hill from there.
DO NOT ARCHIVE |
Gig Giacona
Posted: Mon Mar 17, 2008 11:15 am Post subject: Re: My figures don't compute |
Yes you did and you even tried to correct the first wildly wrong calculation but even you forgot to take into account the rear attach bolt. Which just goes to prove my point that this level of calculations needs to be left to professionals with ALL the data available to them.
[quote="ashontz"]Just for the record, I was actually defending that joint.
DO NOT ARCHIVE |
bryanmmartin
Posted: Mon Mar 17, 2008 11:35 am Post subject: My figures don't compute |
You should also remember that the lift is not distributed evenly over
the length of the wing. The wing is tapered so the lift distribution
also tapers off as you approach the tip. In fact, a tapered wing like
this produces a fair approximation of an elliptical lift distribution.
This puts the centroid of the lift closer to the root than the mid span
point and reduces the lever arm and, therefore, the torque at the root.
I suspect the centroid of lift is closer to one third the span than one
half, say 50 inches instead of 74. It's been a long time since I used my
aero engineering training, so this is just a rough estimate off the top
of my head.
I'm not worried about that joint failing.
ashontz wrote:
That joint is fine.
Bryan Martin
B.S.A.E, U of Mich, '91
Zenith 601XL N61BM
Ram Subaru, Stratus redrive
_________________ --
Bryan Martin
do not archive. |
Posted: Mon Mar 17, 2008 12:21 pm Post subject: My figures don't compute |
not being into that particular activity - but being interested in the mental gymnastics taking place here it is only fair to point out that Andy was correct in ignoring the single bolt common to the aft spar connection on each side - it is a simple pivot in panel bending. Total loads should include them though due to restraints on the planform due to the triangulation stability they add to the installation.
Gig Giacona <wr.giacona(at)suddenlink.net> wrote:[quote] --> Zenith-List message posted by: "Gig Giacona"
Gig Giacona wrote:
| Quote: | This entire thread is an excellent example of mental masturbation. It starts out with a calculation that is wrong primarily because it takes into account 4 bolts instead of 14 (because from a quick glance it doesn't even take into account the rear attach points and then goes down hill from there.
DO NOT ARCHIVE
W.R. "Gig" Giacona
Read this topic online [quote][b]
kmccune
Joined: 22 Sep 2007 Posts: 577 Location: Wisconsin, USA
Posted: Mon Mar 17, 2008 12:30 pm Post subject: Re: My figures don't compute |
I think they were discussing building a Zenith 601. I was enjoying the thread, mental masturbation? If it really is profane or racist or sexist, then contact the administrator. If you find it annoying hit backspace!
Kevin
DO NOT ARCHIVE |
_________________ “Always do what you are afraid to do.”
R.W. Emerson (1803-1882)
Dorothy McCune |
ashontz
Posted: Mon Mar 17, 2008 12:55 pm Post subject: Re: My figures don't compute |
If I'm not mistaken, the rear attach bolt is a single bolt and provides no upward resistance, it merely holds the rear of the wing in line with the front of the wing, no? The rear bolt only keeps the spar in line to take all of the bending moment.
There is no center spar on the rear because there is no bending force being acted upon on the rear of the spar. The main spar carries the load. Any bending moments on the the rear spar are transmitted to the main spar. Considering the center of lift of the wing is near the main spar, it shouldn't be a problem.
[quote="Gig Giacona"]Yes you did and you even tried to correct the first wildly wrong calculation but even you forgot to take into account the rear attach bolt. Which just goes to prove my point that this level of calculations needs to be left to professionals with ALL the data available to them.
| ashontz wrote: | Just for the record, I was actually defending that joint.
DO NOT ARCHIVE |
Gig Giacona
Posted: Mon Mar 17, 2008 1:12 pm Post subject: Re: My figures don't compute |
This forum has been overrun with first bad accident analysis and and now bad engineering data. This does NOTHING to help anyone either make an informed decision to build or not build a Zenith and it doesn't help anyone with questions or problems in building.
You guys said you were going to hire outside "expert" analysis. Why don't you do it and wait for the answer.
DO NOT ARCHIVE
ashontz
Posted: Mon Mar 17, 2008 1:22 pm Post subject: Re: My figures don't compute |
Uh, we're talking about the forces in the spar and how the spar connects and the loads transmitted through them. As far as I'm concerned this part of this thread has nothing to do with accidents. The spar connect looks fine to me, plus, it's never been indicated in a NTSB report as a failure point.
I think, even without being an aeronautical engineer, pretty much anyone can calculate a rough estimate of the leveraged force through a beam with a force applied at distance x and a counteracting force or forces at distance y. And it's not too far of a stretch of the imagination to see that the spar will do just that, provided that the ribs and skins keep it in line. So, we've got ribs, spars and skins defining the shape of the wing as well as holding the main spar in line so that it can ultimately transmit that moment to the airframe to lift it. Not too complicated once you get down to the business end of the wing spar fitting in the center spar via 6 bolts and the rear bolt on the back of the wing keeping the wing from changing it's pitch relative to the fuselage. Sounds about right to me.
Now where I'd like to see the 3rd party analysis is on some of the internal structures in the wing itself.
| Gig Giacona wrote: | This forum has been overrun with first bad accident analysis and and now bad engineering data. This does NOTHING to help anyone either make an informed decision to build or not build a Zenith and it doesn't help anyone with questions or problems in building.
DO NOT ARCHIVE |
bryanmmartin
Posted: Mon Mar 17, 2008 2:04 pm Post subject: My figures don't compute |
Another point to remember is that the wings and included fuel make up a
significant fraction of the gross weight of the airplane. The weight of
the wings is not transmitted through the main spar attachment in flight.
The swings support their own weight plus half the weight of the
fuselage, instead of each wing supporting 660 lbs at the wing root, it's
more like 500 lbs. This further improves the load situation at the wing
root.
| Quote: | You should also remember that the lift is not distributed evenly over the length of the wing. The wing is tapered so the lift distribution also tapers off as you approach the tip. In fact, a tapered wing like this produces a fair approximation of an elliptical lift distribution. This puts the centroid of the lift closer to the root than the mid span point and reduces the lever arm and, therefore, the torque at the root. I suspect the centroid of lift is closer to one third the span than one half, say 50 inches instead of 74. It's been a long time since I used my aero engineering training, so this is just a rough estimate off the top of my head.
> That joint is fine.
Bryan Martin
Zenith 601XL N61BM
Bryan Martin
do not archive. |
