jsflyrv(at)verizon.net Guest
Posted: Sat Mar 15, 2008 8:14 am Post subject: Garmin 296 |
Hi all,
Been a while since I have been here, but I see things are still going
along pretty much the same
I have been looking through the archives seeing if anyone has had the
same problem
and come up with a solutions to Garmins not locking onto Sats. I have
read all the threads about
dead internal batteries and selecting the options etc. I cannot believe
that the internal
memory battery is dead as this unit is not that old. It is very
frustrating to go fly and
not get a GPS lock on.
My 296 use to lock on almost immediately but now takes a long time to
find the satellites,
Some flight it well not lock on at all if it sits more than a few days
Has anyone that I read about having this problem come up with a real
solution?
It seems like everyone's problem started around the same time, could
this have been the result
of a version of upgrade? I always upgrade when Garmin notifies me one is
available.
My old Flybuddy GPS memory battery went dead after about 10 years, I
took it apart and
replaced it with one I found online. has anyone took a Garmin 296 apart?
Jerry
darnpilot(at)aol.com Guest
Posted: Sat Mar 15, 2008 9:50 am Post subject: Garmin 296 |
I have the same issues with my 496. I concur in that it seems to have started suddenly for quite a few of us. Mine started this past July. Has anyone contacted Garmin and gotten a reasonable answer? I plan to visit with them when I attend SNF next month.
Jeff
gyoung
Joined: 09 Jan 2006 Posts: 211 Location: Republic of Texas
Posted: Sat Mar 15, 2008 10:03 am Post subject: Garmin 296 |
I just got my 396 back from Garmin after they confirmed my real time clock battery was the problem. They wound up giving me an exchange unit. One of the hoops I had to jump thru was a master reset. In reading about that procedure it appears there are cases of memory corruption that mimic the battery problem and are fixed by th reset.
The master reset procedure is complex and will flush all your user waypoints and routes so you should do a backup using Mapsource or other. I Googled for the proc b ut someone may have it handy. It may differ slightly for the 296 vs 396. Garmin complained that these lists make it sound like the batt is a huge problem when it is really rare. They'll take care of it if it is but can walk you thru other steps to fix or confirm it.
Greg
Sent via BlackBerry from T-Mobile
Jerry Cochran
Joined: 10 Jan 2006 Posts: 111 Location: Wilsonville, OR
Posted: Sun Mar 16, 2008 11:29 am Post subject: Garmin 296 |
Hi Jerry,
I had similar symptoms with my 296, but mine turned out to be the antenna. Bad shield splice by builder, Me. Took same apart, went to Knuckolls site for how to do it right, and now working better than ever.
Jerry Cochran
Supercharge your AIM. Get the AIM toolbar for your browser.
Posted: Sun Mar 16, 2008 12:27 pm Post subject: Garmin 296 |
Jerry:
That's not the case here. Those of us experiencing this problem, it is the unit losing the time/date, not a signal problem. When the unit does not properly store the date, it does not know where to look for the satellites when its next turned on, therefor it is "lost" for a long time until it figures out where it is and updates the clock. Then the unit works fine until the next time its shut off for any length of time.
Its definitely an internal clock issue and not an antenna issue. The problem is this: is it a software issue, or a battery issue? Most of the problems are being experienced by relatively new units, and all within the last year. Seems like there must be a Garmin common problem, and thus a Garmin "fix"?
Jeff
sportav8r(at)gmail.com Guest
Posted: Sun Mar 16, 2008 6:39 pm Post subject: Garmin 296 |
I was the first to comment on this, and mine's not a new unit. Perhaps 5 years old now. I last flew on 3/3, then went again yesterday and the unit thought the date was 3/11, so the thing seems to wander off into the weeds after a week of inactivity. Fixes itself rather promptly if the new location, automatic detect menu features are stepped through, otherwise it gives up trying to find a fix after a few m inutes and asks if I want to start simulator mode.
-Bill B
On Sun, Mar 16, 2008 at 4:23 PM, <darnpilot(at)aol.com (darnpilot(at)aol.com)> wrote:
[quote] Jerry:
Jeff
Leland Collins
Posted: Fri Mar 21, 2008 10:12 am Post subject: Re: Garmin 296 |
I've had the same problem with my 4-year old Garmin 296 being unable to lock onto satellites after loosing its internal date. I think its a dead battery problem because the battery looses about 20% of its charge overnight. I just ordered a new battery from www.batteriesamerica.com for $59 plus $11 shipping. Garmin supposedly now has the part number 010-10517-01 as a replacement for the original 011-00955-00 unit. The replacement part has a larger capacity rating. The replacement unit is the same for the 396 and 496.
Leland
Posted: Fri Mar 21, 2008 11:30 am Post subject: Garmin 296 |
Leland- please let us know if this solves the problem. If it does, alot of us will be ordering replacement batteries!
-Bill
On Fri, Mar 21, 2008 at 2:12 PM, Leland Collins <federigo(at)pacbell.net (federigo(at)pacbell.net)> wrote:
[quote]--> RV-List message posted by: "Leland Collins" <federigo(at)pacbell.net (federigo(at)pacbell.net)>
Leland
http://forums.matronics.com/viewtopic.php?p=171523#171523
Steve Glasgow
Posted: Sat Mar 22, 2008 6:19 am Post subject: Garmin 296 |
Do you guys make all the software updates from Garmin? Mine is almost 56
years old and no problems yet.
Steve Glasgow-Cappy
N123SG RV-8
Cappy's Toy
_________________ Steve Glasgow-Cappy
Cappy's Toy
RV-8 N123SG |
tracy(at)rotaryaviation.c Guest
Posted: Sat Mar 22, 2008 6:53 am Post subject: Garmin 296 |
Wow, that was foresite on Garmin's part. Building it even before the first GPS satelite went up!
Tracy Crook (I make typos too <G>)
On Sat, Mar 22, 2008 at 10:15 AM, Steve Glasgow <willfly(at)carolina.rr.com (willfly(at)carolina.rr.com)> wrote:
[quote]--> RV-List message posted by: "Steve Glasgow" <willfly(at)carolina.rr.com (willfly(at)carolina.rr.com)>
wdleonard(at)gmail.com Guest
Posted: Sat Mar 22, 2008 8:55 am Post subject: Garmin 296 |
Problem is, that you never know there is a problem until it is too late.
Early in my flying career I was doing a cross country and borrowed my friends new-fangled GPS, - a garmin 95. The database was a little over a year old and I figured that not much could have changed.
The problem is that they had moved the Denver airport, and it never occured to me that the database was using the old airport and class B. I remenber cruising on into Boulder at night thinking "Boy, look at all those airliners lined up. Sure seems like I am flying right through the middle of the final approach. GPS says I am outside class B though, so I'm OK." ....
Name withheld to protect the guilty.
On Sat, Mar 22, 2008 at 7:15 AM, Steve Glasgow <willfly(at)carolina.rr.com (willfly(at)carolina.rr.com)> wrote:
[quote] --> RV-List message posted by: "Steve Glasgow" <willfly(at)carolina.rr.com (willfly(at)carolina.rr.com)>
Steve Glasgow-Cappy
N123SG RV-8
Cappy's Toy
Posted: Sat Mar 22, 2008 9:49 am Post subject: Garmin 296 |
Does not the 296 have an internal memory battery? Are you talking about
the battery that powers the GPS, I understand it is the internal memory
battery that
is causing the problems?
Jerry
Leland Collins wrote:
Leland
Steve Glasgow
Posted: Sun Mar 23, 2008 2:57 am Post subject: Garmin 296 |
<Do you guys make all the software updates from Garmin? Mine is almost 56 years old and no problems yet.>
Should read almost 5 years old.
Steve Glasgow-Cappy
N123SG RV-8
Cappy's Toy
Cappy's Toy
RV-8 N123SG |
Leland Collins
Posted: Sat Apr 26, 2008 6:15 pm Post subject: Re: Garmin 296 |
[quote="Leland Collins"]I've had the same problem with my 4-year old Garmin 296 being unable to lock onto satellites after loosing its internal date. I think its a dead battery problem because the battery looses about 20% of its charge overnight. I just ordered a new battery from www.batteriesamerica.com for $59 plus $11 shipping. Garmin supposedly now has the part number 010-10517-01 as a replacement for the original 011-00955-00 unit. The replacement part has a larger capacity rating. The replacement unit is the same for the 396 and 496.
Leland[/quote]
I changed the main battery and the problem is still there. If I do not fly the plane for several days, the unit stops tracking the date/time. Now the question is: Is it possible to change the "time" battery without sending it to Garmin?
gyoung
Posted: Sat Apr 26, 2008 8:04 pm Post subject: Garmin 296 |
Call Garmin first and let them take you through the troubleshooting steps.
There is a memory corruption issue that causes the same symptoms. If they
can confirm the real time clock battery really is bad, they might replace
it.
Greg Young
[quote] --
