Flying with VGs
Possums
PostPosted: Wed Mar 12, 2008 6:19 pm    Post subject: Flying with VGs Reply with quote
Shot some more videos this afternoon.
I'll keep the clips shorter - so as not to bore you all.
I mounted a new Hall ASI close to the camera.
It goes from 0 to 55 mph. They are very accurate in clean air.
It was easy to read in the original clip (32MB), but hard to see
after it was uploaded to Goggle. Guess I need to put it closer to the camera
next time.
Anyway - here is a clip flying at 25 mph at about 4200 RPM.
http://video.google.com/videoplay?docid=8643180947591432536&hl=en
 Filesize:  51.76 KB
 Viewed:  689 Time(s)
Possum
Possums
PostPosted: Wed Mar 12, 2008 6:33 pm    Post subject: Flying with VGs Reply with quote
Here is a clip flying at about 5800 RPM with the
stick pulled all the way back to the seat.
It is hard to stall with full power unless you pull
the stick back pretty quick and make it.
http://video.google.com/videoplay?docid=-8361300167482330203&hl=en
 Filesize:  33 KB
 Viewed:  655 Time(s)
Possum
Possums
PostPosted: Wed Mar 12, 2008 6:38 pm    Post subject: Flying with VGs Reply with quote
Here is our field - it's getting kind of crowded with all the
new houses they've built next to it. But the new neighbors don't
seem to mind - so far. Just gotta watch those antennas.
http://video.google.com/videoplay?docid 63159682459782825&hl=en
 Filesize:  53.14 KB
 Viewed:  677 Time(s)
Possum
Possums
PostPosted: Wed Mar 12, 2008 7:33 pm    Post subject: Flying with VGs Reply with quote
Here's some turns at 25 - 30 mph - no stall.
http://video.google.com/videoplay?docid=8126295785191222670&hl=en
 Filesize:  50.3 KB
 Viewed:  664 Time(s)
Possum
Possums
PostPosted: Wed Mar 12, 2008 7:46 pm    Post subject: Flying with VGs Reply with quote
And the last one - a clean stall break.
But it recovers pretty quick.
http://video.google.com/videoplay?docid=-1724203084033037294&hl=en
 Filesize:  28.5 KB
 Viewed:  661 Time(s)
Possum
ElleryWeld(at)aol.com
PostPosted: Thu Mar 13, 2008 3:41 am    Post subject: Flying with VGs Reply with quote
Hey there Possum you say in this pic Video  it was a clean stall break the Hall indicator is indicating 35 I had a firestar that weighed in at 338 dry and did not have VG's and it would stall under 30 indicated good thing I didn't put the VG's on ...chuckle ...chuckle
Ellery in Maine sick of all this snow and ready for spring
In a message dated 3/12/2008 10:46:51 P.M. Eastern Standard Time, possums(at)bellsouth.net writes:
It's Tax Time! Get tips, forms and advice on AOL Money & Finance.
Possums
PostPosted: Thu Mar 13, 2008 6:33 am    Post subject: Flying with VGs Reply with quote
At 07:38 AM 3/13/2008, you wrote:
Hey there Possum you say in this pic Video it was a clean stall break the Hall indicator is indicating 35 I had a firestar that weighed in at 338 dry and did not have VG's and it would stall under 30 indicated good thing I didn't put the VG's on ...chuckle ....chuckle
You've gotta remember that I'm not dragging the plane thru the
air with three notches of flaps either. I don't even have flaps or flaperons.
I don't even have the old "barn door" style ailerons on this plane.
Possum
Jim ODay
PostPosted: Thu Mar 13, 2008 6:52 am    Post subject: Re: Flying with VGs Reply with quote
Wow Possum! Great demo video.
The steep turns are very impressive. Thanks for sharing them.
Fly safe,
Jim
Jim O'Day
Fargo, ND
Former Firestar II Builder/Pilot
jb92563
PostPosted: Thu Mar 13, 2008 12:00 pm    Post subject: Re: Flying with VGs Reply with quote
Possums,
Love that landing movie.....looks like you are barnstorming the neighborhood and the way the ground is moving by makes it look like you have engaged the Warp engines.....cool Laughing
Could you mount the camera above the wing showing the VG's and then pour some engine oil on your leading edge and take a flight.
I'm curious how the air is moving around the VG's and where the flow separation occurs compared to your VG placement.
The oil trails will show what is happening up there. Wink
Ray
Moni MotorGlider
Schreder HP-11 Glider
Grob 109 Motorglider
Possums
PostPosted: Thu Mar 13, 2008 1:22 pm    Post subject: Re: Flying with VGs Reply with quote
Can I attach a file to this part of the list without bogging down everyone's computer?
Like this one - I think you would have to open it with "Quicktime"
Possum
Jim ODay
PostPosted: Thu Mar 13, 2008 1:35 pm    Post subject: Re: Flying with VGs Reply with quote
Love your videos so if you would be kind enough to send me it, I use this service below for large files and it is smooth.
https://www.sendthisfile.com
I don't know if large files bog down some Kolbers on the list, probably does. I recall some time ago, some folks had issues with large pics so a video file may be like drinking from a fire hose.
Thanks and fly safe.
Jim
Jim O'Day
Fargo, ND
Possums
PostPosted: Fri Mar 14, 2008 2:35 pm    Post subject: Flying with VGs Reply with quote
At 04:00 PM 3/13/2008, you wrote:
Possums,
The oil trails will show what is happening up there. [Wink]
I'd have to wash my plane first - you can see how dusty my wings are.
 Filesize:  65.72 KB
 Viewed:  649 Time(s)
Possum
ulflyer(at)verizon.net
PostPosted: Sat Mar 15, 2008 4:46 pm    Post subject: Flying with VGs Reply with quote
What is the do-dad on you nose cone right in front of you?
Are you using it for slip indicator? First I thought it was a
pivoting airspeed probe like they often use on aircraft during
certification testing.but it looks like it acts more like a ground
direction indicator?
jerb
beauford173(at)verizon.ne
PostPosted: Sat Mar 15, 2008 6:10 pm    Post subject: Flying with VGs Reply with quote
jerb
.actully it sorta is, jerb.... when it points directly back at the
Possum, then spins ten or
fifteen times, it means he is firmly emplaced betwen the Posture-Pedic and
the crapper
in the second story master bedroom of that big 'ol house he passed within 30
feet of on
very short final into the Possum Patch in the video... and if he is lucky
it will then swing
yet again to point toward the stairs so he can beat-feet out of the house
before the
authorities show up...
helpful beauford
FF-076
Brandon, FL
Possums
PostPosted: Sun Mar 16, 2008 6:32 am    Post subject: Flying with VGs Reply with quote
jerb
Using it as a slip indicator - it came off a sail boat.
A string works just as well if I have my windshield on, but not so good
when I fly out in the open.
Possum
Possums
PostPosted: Sat Mar 22, 2008 5:13 pm    Post subject: Re: Flying with VGs Reply with quote
[quote="jb92563"]Possums,
Love that landing movie....quote]
So .......I'm trying to find out how you can add attachments to this part of the list "Read this topic online here" without affecting the "email" part of the list and forcing people to have to download something they don't choose to?
Got any idea? or "How do you do it"?
Possum
biglar
PostPosted: Sat Mar 22, 2008 5:42 pm    Post subject: Flying with VGs Reply with quote
Only way I know of is to publish it, then put the link in the email to
the List. A regular attachment will open automatically with the message
and cause grief to those on dial up. Not fair to
'em. Lar. Do not Archive.
Possum
http://forums.matronics.com/viewtopic.php?p=171827#171827
Larry Bourne
Santa Fe, NM
www.gogittum.com
www.gogittum.com/blog
Larry Bourne
Palm Springs, CA
Building Kolb Mk IIIC
"Vamoose"
ez(at)embarqmail.com
PostPosted: Sat Mar 22, 2008 7:25 pm    Post subject: Flying with VGs Reply with quote
Possum,Just sign up for a free Google Gmail account and you will have all the space you need to up load photos, documents, videos and more.
Then you can link it to any email you wish.
Here is an example of a document I just did.
http://docs.google.com/Doc?id=d3jhg27_0fr7x2tcf
On Mar 22, 2008, at 9:13 PM, Possums wrote:[quote] [quote][b]
