New Fuel Servo AD?
steve2(at)sover.net
PostPosted: Thu Mar 13, 2008 7:03 am    Post subject: New Fuel Servo AD? Reply with quote
New Emergency AD.
RSA-5 and RSA-10 servos....... Precision Airmotive (They holding the certificate for the servos now?)
No flight until compliance.
The way the AD is written, it would seem repetitive every 50 hours with no means of terminating the inspection requirement.
http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgAD.nsf/0/2321ADE8B9025A138625740A00622E71?OpenDocument
Steve
2008-06-51_Emergency.pdf
 Filename:  2008-06-51_Emergency.pdf
 Filesize:  23.81 KB
 Downloaded:  226 Time(s)
steve2(at)sover.net
PostPosted: Thu Mar 13, 2008 7:24 am    Post subject: New Fuel Servo AD? Reply with quote
Ok, P.S.......
Here's the Service Bulletin. It has a picture of the affected part.
Our servo doesn't even have the affected hex plug in the regulator cover........
Steve
PRS-107%20Rev1.pdf
 Filename:  PRS-107%20Rev1.pdf
 Filesize:  486.15 KB
 Downloaded:  237 Time(s)
kamala(at)MSN.COM
PostPosted: Thu Mar 13, 2008 7:45 am    Post subject: New Fuel Servo AD? Reply with quote
which servo is this? gmc
[quote] From: steve2(at)sover.net
Subject: Commander-List: New Fuel Servo AD?
Date: Thu, 13 Mar 2008 10:59:26 -0400
.ExternalClass .EC_hmmessage P {padding-right:0px;padding-left:0px;padding-bottom:0px;padding-top:0px;} .ExternalClass EC_BODY.hmmessage {font-size:10pt;font-family:Tahoma;} New Emergency AD.
Steve
steve2(at)sover.net
PostPosted: Thu Mar 13, 2008 8:14 am    Post subject: New Fuel Servo AD? Reply with quote
In our application its an IO-540. As far as I know, these things are everywhere...... An awful lot of stuff runs on RSA-5 and -10 Bendix servos........ But we don't even have the plug they're talking about.
I did find the spreadsheet that lists the individual servos the 'Service Bulletin' refers to. I'll read the AD to see if the Service Bulletin list applies, but the short of it is this......
"The listing in this column shows all RSA-5 and RSA-10 model fuel injection servos manufactured or rebuilt by Precision Airmotive between 8/22/06 and 3/7/08. Please note that there may be other servos that are affected by service bulletin PRS-107 if they were overhauled or repaired after 8/22/06"
But I've got to get some work done before I can look at this stuff again......
The good news is it appears to be restricted to a couple year window when the servos were rebuilt or repaired.........
PRS-107_Serial_Number_Listing.xls
 Filename:  PRS-107_Serial_Number_Listing.xls
 Filesize:  638.5 KB
 Downloaded:  186 Time(s)
dowens(at)aerialviewpoint
PostPosted: Thu Mar 13, 2008 1:33 pm    Post subject: New Fuel Servo AD? Reply with quote
Steve...
Invaluable information as always guys... Thanks for the heads up... It applied to our Navajo... No problem this time... we'll see the next 50 hrs... Thanks again!!!!!
David Owens
Aerial Viewpoint
N14AV
AC-500A-Colemill
