toaster73(at)embarqmail.c Guest
Posted: Wed Mar 12, 2008 10:56 am Post subject: Infinity Grip...am I crazy? |
So I am trying (again) to decide what buttons to put on my grip. If I understand things correctly I can do the following:
Trigger - PTT
China Hat - Trim
Top Right (use toggles w/ center off, mom - on up and down): frequency flip flop from standby on com1 (up) and com 2 (down) via SL30 and 430
Top Left (use toggles w/ center off, mom -on up and down): screen paging on GRT1 and GRT 2 via GRT
Middle (NO 8632 push button) : Autopilot control wheel steering via trutrak
Bottom pinky (NO 8632 push button) : swap com1 and com2 via GMA 340
Does this seem like a good setup or is it overkill with stuff I won't use? Also does it appear to all be doable?
Chris Lucas
#40072
electrics - cabin top - doors- overhead console - door locks - stick grips - panel - landing gear - engine mount
Tim Olson
Posted: Wed Mar 12, 2008 11:25 am Post subject: Infinity Grip...am I crazy? |
I like it, but I don't know if I'd do the com swap on the pinky like that.
If you have audio mute-able items you may want that button for that.
It's nice to turn off bogus voice alerts without pulling your hands
off the stick. The com flip-flop should be enough on the stick
to do what you really would use.
Chris wrote:
| Quote: | So I am trying (again) to decide what buttons to put on my grip. If I
Trigger - PTT
China Hat - Trim
Chris Lucas
#40072
Posted: Wed Mar 12, 2008 11:32 am Post subject: Infinity Grip...am I crazy? |
Make sure you have a heads up display with the directions on how to use the stick. While you at it, push forward--down, Pull Back --Up and side to side. Top of the list should read, Look out window and fly plane.
can't help myself.
John G.
[quote] From: toaster73(at)embarqmail.com
Subject: RV10-List: Infinity Grip...am I crazy?
Date: Wed, 12 Mar 2008 14:53:57 -0400
Trigger - PTT
China Hat - Trim
Chris Lucas
#40072
get=_blank>http://www.matronics.com/Navigator?RV10-List
p://forums.matronics.com
| [b]
Posted: Wed Mar 12, 2008 11:33 am Post subject: Infinity Grip...am I crazy? |
I used the top left and right buttons for the TT Autopilot control wheel steering, pinky for AP disengage hat for trim, trigger for PTT. But then again I have the CH grip
Rick Sked
40185
Posted: Wed Mar 12, 2008 11:57 am Post subject: Infinity Grip...am I crazy? |
I use push, houses get bigger, pull houses get smaller...for awhile, then they get bigger again.
Rick Sked
40185
don not archive
I usually have the coolie hat be elevator and aileron trim, toggle for flaps and toggle for rudder trim on the top, then side thumb button for A/P disconnect and pinky button either momentary to acknowledge or turn an interior light on and off.
Jesse Saint
Saint Aviation, Inc.
Cell: 352-427-0285
Fax: 815-377-3694
On Mar 12, 2008, at 2:53 PM, Chris wrote:
| Quote: | So I am trying (again) to decide what buttons to put on my grip. If I understand things correctly I can do the following:
Trigger - PTT
China Hat - Trim
Chris Lucas
#40072
| Quote: | http://www.matronics.com/Navigator?RV10-List
CJohnston(at)popsound.com Guest
Posted: Wed Mar 12, 2008 12:00 pm Post subject: Infinity Grip...am I crazy? |
Won’t the CWS button also disengage the AP? I’m in the process of figuring out what should control what with my stick grip.
cj
Tim Olson
Posted: Wed Mar 12, 2008 12:57 pm Post subject: Infinity Grip...am I crazy? |
Yeah, they're one in the same.
Chris Johnston wrote:
| Quote: | Won’t the CWS button also disengage the AP? I’m in the process of
cj
rene(at)felker.com Guest
Posted: Wed Mar 12, 2008 1:31 pm Post subject: Infinity Grip...am I crazy? |
Here is what I did.
Top left -- Autopilot Disconnect
Hat -- Trim
Top Right -- Flaps
Trigger -- PTT
Middle -- Comm 1 Flip-Flop
Pinky -- Ident
Works great......for the first two hours
Rene' Felker
N423CF Flying
40322
801-721-6080
Posted: Wed Mar 12, 2008 2:10 pm Post subject: Infinity Grip...am I crazy? |
423 Charlie Fox Vegas approach, again, squawk 4363 and ident, we see you decending.
vegas approach 423 Charlie fox, sorry pinky and thumb had an identity crisis, or never mind
[quote] From: rene(at)felker.com
Subject: RE: Infinity Grip...am I crazy?
Date: Wed, 12 Mar 2008 15:26:39 -0600
--> RV10-List message posted by: "Rene Felker" <rene(at)felker.com>
Here is what I did.
Hat -- Trim
Top Right -- Flaps
Trigger -- PTT
Pinky -- Ident
Rene' Felker
N423CF Flying
40322
801-721-6080
wcurtis(at)nerv10.com Guest
Posted: Wed Mar 12, 2008 2:19 pm Post subject: Infinity Grip...am I crazy? |
Here is what I'm doing. CH products stick
Hat - Trim
Top right - PTT (top left on co-pilot side)
Top left - autopilot CWS (top right on co-pilot side)
pinky - comm transfer
Trigger - Multi function depending on 4 position switch (1-IDENT, 2-?, 3-?, 4-Starter) maybe 2 will be missiles and 3 will be guns:-)
William
http://nerv10.com/wcurtis/
"Be who you are and say what you feel because those who mind don't matter and those who matter don't mind."
-- Dr. Suess
GenGrumpy(at)aol.com Guest
Posted: Wed Mar 12, 2008 6:34 pm Post subject: Infinity Grip...am I crazy? |
The really neat thing about the Infinity grip is that you can wire up each button to do what you want it to do and not have to live with somebody else's idea of which button should do what!
grumpy
In a message dated 3/12/2008 3:59:32 P.M. Central Daylight Time, Tim(at)MyRV10.com writes:
| Quote: | --> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com>
It's Tax Time! Get tips, forms and advice on AOL Money & Finance.
dlm46007(at)cox.net Guest
Posted: Wed Mar 12, 2008 7:12 pm Post subject: Infinity Grip...am I crazy? |
So you have a button to switch from guns to missles?
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of GenGrumpy(at)aol.com
Sent: Wednesday, March 12, 2008 7:32 PM
Subject: Re: RV10-List: Infinity Grip...am I crazy?
grumpy
Ray.R.Doerr(at)sprint.com Guest
Posted: Thu Mar 13, 2008 4:49 am Post subject: Infinity Grip...am I crazy? |
Here is what I have, and I love it.
Red Trigger – PTT
Hat (Up/Dn) – Elevator Trim
Hat (Left/Right) – Ailron Trim
Hat (Left/Right) while Blue Pinky switch is pressed for longer than .5 seconds – Rudder Trim
Top Toggle (Center Off) – Flaps
Top Green Switch – Audio Panel Com Swap
Black (Thumb) – AutoPilot Engage/Disengage
Blue (Pinky) – Com Act/Stby Swap if pressed less than .5 second.
I also have Transponder Ident wired, but I don’t use it, it’s just an easy to hit the ident on the unit when you change a squak code.
Thank You
Ray Doerr
40250 N519RV (352 hours on the Hobbs)
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris
Sent: Wednesday, March 12, 2008 1:54 PM
Subject: Infinity Grip...am I crazy?
Trigger - PTT
China Hat - Trim
Chris Lucas
#40072
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 0123456789
Posted: Thu Mar 13, 2008 5:20 am Post subject: Infinity Grip...am I crazy? |
That's on the throttle...
ncol(at)xtra.co.nz Guest
Posted: Thu Mar 13, 2008 8:27 am Post subject: Infinity Grip...am I crazy? |
As an option, we put one of the switches to use as a Trim Disconnect.
Press once to disconnect, again to reconnect. That way, once in cruise,
trimmed out & autopilot on, there are no worries about someone bumping
the trim switch.
Neil
On 14 Mar 2008, at 1:42, Doerr, Ray R [NTK] wrote:
Red Trigger – PTT
code.
Thank You
Ray Doerr
Trigger - PTT
China Hat - Trim
trutrak
Chris Lucas
#40072
Posted: Thu Mar 13, 2008 5:37 pm Post subject: Infinity Grip...am I crazy? |
Well that sounds just as crazy as my possible plan. ;>)
And you like it ok? and remember it all ok?
So maybe I'll press forward and see what happens - possibly with yet another configuration before I actually order.
Thanks to all for the replies on the set ups!
-Chris
#40072
