fuel cap faring
kirkhull(at)kc.rr.com
PostPosted: Tue Mar 11, 2008 5:39 pm    Post subject: fuel cap faring Reply with quote
When I was at osh last year I saw a # of kitfoxes with some faring behind
the fuel caps. Does anybody know where to find these and how much they
cost? If anybody has these installed was there any noticeable effects?
dcsfoto
PostPosted: Tue Mar 11, 2008 6:34 pm    Post subject: Re: fuel cap faring Reply with quote
got mine from Kitfox
David
patreilly43(at)hotmail.co
PostPosted: Tue Mar 11, 2008 6:52 pm    Post subject: fuel cap faring Reply with quote
Murle Williams has the gas cap fairings (at) Williams Aviation. He's in AZ, but will ship anywhere.
Pat Reilly
Mod 3 Rebuild
Rockford, IL
Subject: fuel cap faring
Date: Tue, 11 Mar 2008 19:37:20 -0600
--> Kitfox-List message posted by: "kirk hull" <kirkhull(at)kc.rr.com>
cost? If anybody has these installed was there any noticeable effects?>
Fox5flyer
PostPosted: Wed Mar 12, 2008 3:47 am    Post subject: fuel cap faring Reply with quote
I made my own. It was fairly simple. Just used 3/4" blue foam carved to
shape, sanded, covered with a thin layer of glass/epoxy, paint to match,
then epoxied to the wing. Photos attached. Sorry about the photo quality.
They were taken a long time ago when digital cams were infantile.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 355+ TT
"The aim of an argument or discussion should not be victory, but progress."
- Joseph Joubert
 Filesize:  70.86 KB
 Viewed:  603 Time(s)
 Filesize:  73.63 KB
 Viewed:  597 Time(s)
n85ae
PostPosted: Wed Mar 12, 2008 6:38 am    Post subject: Re: fuel cap faring Reply with quote
Ah, the gas cap fairings!
The main thing is you need to install speed brakes, and a an F-4 Phantom
style drag chute for landings!
On my plane, I can switch between 6.00x6 tires, and 8.50x6 tires and barely
notice any speed change, so I'm a bit skeptical about the gas cap fairings.
My cruise speed with an IO-240B is about 120 at 2400 rpm's, and at full
power at 2800 I can hit 140 in level flight. This is pretty consistent for
me regardless of what tires I hang under it, or if I put my landing light
bar under the plane (three 6" dia. lights).
It obviously won't hurt to put them on, but I wouldn't expect to gain any
speed from it.
Jeff.
PostPosted: Wed Mar 12, 2008 7:09 am    Post subject: fuel cap faring Reply with quote
Jeff, I can get the drag chute from JEGS or Summit. Where can I get those speed brakes?
Do not archieve
Pat Reilly
Mod 3 Rebuild
Rockford, IL
Subject: Re: fuel cap faring
Date: Wed, 12 Mar 2008 07:38:04 -0700
--> Kitfox-List message posted by: "n85ae" <n85ae(at)yahoo.com>
speed from it.
Jeff.
http://forums.matronics.com/viewtopic.php?p=169234#169234
Fox5flyer
PostPosted: Wed Mar 12, 2008 7:26 am    Post subject: fuel cap faring Reply with quote
Ahhh, Jeff, my old draggy friend. Skepticism is good. Nothing wrong with
that. In the past you have made it well known how you feel about fairings,
which is fine, but we all have our opinions here. The vast majority of us
don't have 125hp to play with. Most have 100hp or less. I'm a firm
believer that every little bit counts when it comes to cleaning up the
airplane. It's probably not linear, but it all adds up, no matter how small
each item is. Some things are more effective than others, depending on what
part of the airplane is causing the drag.
As for my reason for the fairings, it wasn't so much as to reduce drag, but
to clean up the top surface of the wing. A long time ago, one of our list
members did a oil drop test to see how much the air was disturbed behind the
gas caps. Oil drop is where you take a thick oil and put a bunch of drops
on top of the wing all around the spot you want to test. Then you go fly
and when you get on the ground, jump out and take a quick photo of what you
see. What he found was that immediately behind the gas cap the air was
stalled and it widened out to a point about 18" at the trailing edge of the
wing. In my opinion, when you add both wings together, that was a pretty
big chunk of lifting surface not providing any lift. So, since it was a
long winter, and nothing much else was going on, I decided to kill two birds
with one fairing, well two. Regarding the gas caps, most of the parasitic
drag and loss of lift were resolved. I can't quantify in numbers what it
adds up to, but the weight was probably less than 2oz total and they sure
don't hurt anything. The benefits are increased speed with less throttle
meaning better efficiency which translates to fuel saved. Seems like a no
brainer to me.
As for a drag chute, I can recall a couple landings when I wish I'd had one.
Would have saved a go round.
Slick is good. Smile
Deke Morisse
Mikado Michigan
- Joseph Joubert
avidfox
PostPosted: Wed Mar 12, 2008 8:12 am    Post subject: fuel cap faring Reply with quote
"How many people make themselves abstract to appear profound. The most useful part of abstract terms are the shadows they create to hide a vacuum. "
Joseph Joubert......also.
n85ae
PostPosted: Wed Mar 12, 2008 8:41 am    Post subject: Re: fuel cap faring Reply with quote
Hey Deke -
You are correct, that every little bit helps. Also it is a hobby, so nothing
wrong with it in the least.
My points more come from - That in he world of basic aerodynamics,
regardless of what you do, the basic design itself IS the REAL issue. No
matter how much you tweak a Kitfox, you will only ever make minor
improvements.
I think some times from the list, you get the impression that people
think they will get a 40 mph gain from all these enhancements. You
simply can't.
The higher horsepower IO-240B really brings this to light. I have a good
bit of power however it becomes clear when I fly that the drag is very
much increasing exponentially and it hits a wall at about 120-140 mph
where you either need another 200 or so horsepower, or some pretty
significant drag reductions to go faster.
When I say significant, I mean like an entirely different wing and
fuselage.
Anyway, that's the only real point.
Jeff
P.S. I really posted it to - antagonize Deke. But that's another story ... Smile
n85ae
PostPosted: Wed Mar 12, 2008 8:47 am    Post subject: Re: fuel cap faring Reply with quote
You might try http://www.jamestowndistributors.com
Look under "anchors"
Jeff
[quote="patreilly43(at)hotmail.co"]Jeff, I can get the drag chute from JEGS or Summit. Where can I get those speed brakes?
Do not archieve
Pat Reilly
Mod 3 Rebuild
Rockford, IL
--> Kitfox-List message posted by: "n85ae" <n85ae>
speed from it.
Jeff.
propellerdesign(at)tele2.
PostPosted: Wed Mar 12, 2008 10:08 am    Post subject: fuel cap faring Reply with quote
Kitfoxers!
Even small improvement help to gain speed, or reduce fuel burn, but it all
is relative, just as intelligence is.
small wheels and wheelpants might make 2-3 miles on a kitfox, 10-15 miles on
a KR-2.
I ones read about a EUROPA that had perfect made fillets between wing and
fuselage, when sealing the fillets to fuselage with tape it was going 10
knots faster, like flying with parking brake set! This one hade a constant
speed prop!
With a fixed pitch prop, and cruising at a curtain RPM you will not notice
much improvement until you calculate your fuel consumption. at WOT you will
see increase in RPM and speed.
going from 65 hp and say 102 MPH to a 125 hp will gain 24% more speed in
theory, = 127 MPH
In practice - maybe - maybe not, the whole concept is often designed for a
predetermined speed range, wing area, airfoil and incidence is chosen for
this speed, flying with tail scraping the sky and propeller pointing towards
the earth isn't optimal. a different airfoil, smaller wing, higher weight or
little of all three will make a difference.
Weight cost speed too.
With today's fuel price aerodynamic improvement isn't all wrong, it isn't
1-2 dollar a gallon any more. but as the blond girl said: "I just buy gas
for one hundred anyway" blinked here eye and drove away!
It is easy to add drag to a airplane but difficult to reduce it!
Jan
Fox5flyer
PostPosted: Wed Mar 12, 2008 10:33 am    Post subject: fuel cap faring Reply with quote
Jeff, the perennial smartass, but thanks for adding some humor to this list.
Smile
Deke
Jeff
Fox5flyer
PostPosted: Wed Mar 12, 2008 10:40 am    Post subject: fuel cap faring Reply with quote
Jeff, you are absolutely correct in that the Kitfox is only capable of so
much cleanup. I can't argue that. If you want lift, you gotta compromise
with drag, so it's a draggy airplane, but not as bad as many others out
there and there is room to get some more knots out of it without derogating
the mission. When it comes to buying gas, I'm a real cheapskate and if I
can get a few more miles per gallon without adding much weight, that's what
I'll do. Like you said, it's a hobby, a quest, a mission, or perhaps even
an obsession.
Antagonized in Mikado, MI
Sunny, warming up and spring is springing
Whaoo!
Deke Morisse
Mikado Michigan
- Joseph Joubert
Hey Deke -
nothing
improvements.
simply can't.
fuselage.
Jeff
Smile
http://forums.matronics.com/viewtopic.php?p=169283#169283
n85ae
PostPosted: Wed Mar 12, 2008 10:55 am    Post subject: Re: fuel cap faring Reply with quote
Ah, when it comes to buying gas, my wife is a real cheapskate. When
I built mine I was single, and working as a consultant ($$$) and trying
to figure out how to put a 5000 hp Allison T-56 Turboprop on it.
Now that I'm married, I'm looking at solar power ...
Jeff
PostPosted: Wed Mar 12, 2008 12:00 pm    Post subject: fuel cap faring Reply with quote
Deke, I see your gas cap fairings have a piece in front as well as behind the cap. I think the ones you buy have only a piece behind the cap. Being an old canoe builder I know that the increased lineal length to part and return the air is more efficient. Was there any "testing" done in your design or was it an eyeballed design?
Pat Reilly
Mod 3 Rebuild
Rockford, IL
[quote] From: fox5flyer(at)idealwifi.net
Date: Wed, 12 Mar 2008 11:21:36 -0400
--> Kitfox-List message posted by: "fox5flyer" <fox5flyer(at)idealwifi.net>
brainer to me.
Deke Morisse
Mikado Michigan
- Joseph Joubert
Fox5flyer
PostPosted: Wed Mar 12, 2008 1:43 pm    Post subject: fuel cap faring Reply with quote
Nah, it was eyeballed. I was just bored and decided I liked the look of putting the piece in front to make it look more aerodynamic. Probably no measurable difference at my speeds.
Deke
