90 Degree Oil Filter Housing
dmaib@me.com
PostPosted: Tue Mar 11, 2008 7:02 am    Post subject: 90 Degree Oil Filter Housing Reply with quote
Does anybody know if the 1.5 inch spacer for the Casper Labs 90 degree oil filter housing would be the right one for the IO-540 installation on the RV-10? Vans has three different sizes and they say that the 1.5 inch will fit most RV installations, but when I called and asked specifically about this installation, they did not have an answer. I would love to hear from anyone who has installed this adapter.
I notice that this product as advertised in Spruce does not mention any spacers.
Anybody know how to get in touch with Casper Labs? Google does not get me there.
David Maib
RV-10 #40559
New Smyrna Beach, FL
ricksked(at)embarqmail.co
PostPosted: Tue Mar 11, 2008 7:30 am    Post subject: 90 Degree Oil Filter Housing Reply with quote
Thats the spacer I used...1.5" from B & C products heres the link, scroll to the bottom of the page.
http://www.bandc.biz/cgi-bin/ez-catalog/cat_display.cgi?20X358218
Rick Sked
40185
Dave(at)AirCraftersLLC.co
PostPosted: Tue Mar 11, 2008 9:44 am    Post subject: 90 Degree Oil Filter Housing Reply with quote
I'm not sure if Casper Labs is different but here is a B&C adapter with a
1.5" spacer on my -10.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
www.AirCraftersLLC.com
 Filesize:  98.07 KB
 Viewed:  581 Time(s)
 Filesize:  76.19 KB
 Viewed:  611 Time(s)
bcondrey
PostPosted: Tue Mar 11, 2008 9:59 am    Post subject: 90 Degree Oil Filter Housing Reply with quote
Dave,
What sort of tubing did you use on the crankcase vent line?
Bob #40105
dmaib@me.com
PostPosted: Tue Mar 11, 2008 11:20 am    Post subject: Re: 90 Degree Oil Filter Housing Reply with quote
I have not done the crankcase vent line yet. The engine is hanging on the hoist in my hangar. Probably won't mount it for another couple of weeks.
Thanks for the responses on the spacer. Sounds like the 1.5 is the right one.
David Maib
RV-10 #40559
PostPosted: Tue Mar 11, 2008 1:23 pm    Post subject: 90 Degree Oil Filter Housing Reply with quote
I've used SCAT tube there on a couple installations. It seems to work
nicely and it's much easier to manage.
apilot2(at)gmail.com
PostPosted: Tue Mar 11, 2008 5:18 pm    Post subject: 90 Degree Oil Filter Housing Reply with quote
Anyone considered the 45 degree adapter ECI sells?
On Tue, Mar 11, 2008 at 12:20 PM, dmaib(at)mac.com (dmaib(at)mac.com) <dmaib(at)mac.com (dmaib(at)mac.com)> wrote:
[quote]--> RV10-List message posted by: "dmaib(at)mac.com (dmaib(at)mac.com)" <dmaib(at)mac.com (dmaib(at)mac.com)>
David Maib
RV-10 #40559
http://forums.matronics.com/viewtopic.php?p=169073#169073
flysrv10(at)gmail.com
PostPosted: Wed Mar 12, 2008 4:03 am    Post subject: 90 Degree Oil Filter Housing Reply with quote
I have one on mine with 310 hrs on the plane. What do you need to know?
The breather tube has to be talked to in order to clear the filter. Otherwise, nothing else to worry about.
I drain my oil overnight and have zero drip when I remove the filter the next day.
Rob.
On Mar 11, 2008, at 9:15 PM, Kelly McMullen wrote:
[quote]Anyone considered the 45 degree adapter ECI sells?
David Maib
RV-10 #40559
PostPosted: Wed Mar 12, 2008 6:02 am    Post subject: 90 Degree Oil Filter Housing Reply with quote
Great. Exactly what I wanted to know. Looks like the tach drive might
be a bit tight. I gather there is no issue with the engine mount or
cowling clearance.
next day.
Rob.
one.
> David Maib
> RV-10 #40559
PostPosted: Wed Mar 12, 2008 7:48 am    Post subject: 90 Degree Oil Filter Housing Reply with quote
The tach drive is indeed very close but I can't tell you how close,
based on my memory. Of course, if you are using any kind of glass
panel, you will not need the tach cable.
If you need to know how close they are, I will have to look when I
take the cowl off. Let me know.
There are no issues with the mount or cowl. You will need the 1.5
inch spacer for the adopter.
Rob
cowling clearance.
> know?
> filter the
> next day.
> Rob.
>> on the
> weeks.
>> right
> one.
>> David Maib
>> RV-10 #40559
> href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
> href="http://forums.matronics.com">http://forums.matronics.com
> href="http://www.matronics.com/contribution">http://www.matronics.com/contribution
Kellym
PostPosted: Wed Mar 12, 2008 8:01 am    Post subject: 90 Degree Oil Filter Housing Reply with quote
Thanks. That covers all I need to know.
Rob
> cowling clearance.
>> know?
>> the
>> next day.
>> Rob.
Kelly McMullen
KCHD
