Dave(at)AirCraftersLLC.co Guest
Posted: Mon Mar 10, 2008 8:49 pm Post subject: Plane Power's Friendly Warning Light |
B&C's flashing warning light is pretty annoying, so I was glad to see Plane Power's light is a steady, happy glow.
Trouble is, it turns out, that the annoying flash is pretty handy when you really need to see it...no equipment failures to report, just didn't use the checklist...twice >
So, does anyone have a suggestion as to how to wire a flasher into the PP light? Can I just use a simple automotive flasher, or do I need something designed for less current? I want a fairly high (annoying) flash rate.
Hope I don't need a horn.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
www.AirCraftersLLC.com
nuckolls.bob(at)cox.net Guest
Posted: Tue Mar 11, 2008 6:47 am Post subject: Plane Power's Friendly Warning Light |
At 09:46 PM 3/10/2008 -0700, you wrote:
| Quote: | B&C's flashing warning light is pretty annoying, so I was glad to see
If I recall correctly, the Plane Power warning
light drives from the alternator fail output of
the built-in regulator. While certainly better than
no light, it's not an independent monitor of
alternator/regulator performance.
You might consider a separate LV Warning
system that flashes the light.
Yup, when we crafted that system the flash rate
was set at approx 3 flashes per second. Supposedly
this is the rate most 'irritating', i.e. attention
getting for cockpit warning lamps.
Bill also supplied a 6v lamp for the 14V regulators
to increase intensity of the lamp for sunlight viewability.
The simplest method for adding flashing to
an existing lamp circuit is by means of a "two-wire
lamp flasher". There are a number of variations
on the theme. One such circuit is illustrated here:
http://www.aeroelectric.com/Pictures/Schematics/Lamp_Flasher_1.pdf
This circuit should be assembled with a C-Mos
version of the ubiquitous 555 timer. In this
case, the Intersil ICM7555 is called out.
This flasher will deliver a symmetrical ON-OFF
flash pattern at approx 3Hz.
An alternative is shown at:
http://www.aeroelectric.com/Pictures/Schematics/Lamp_Flasher_2.pdf
This is built from more generic discrete parts
and can probably be made to do what you want to
accomplish although its not likely to be a
symmetrical pattern.
( -Thomas Paine 1776- )
