Jaybannist(at)cs.com Guest
Posted: Sat Mar 08, 2008 10:39 am Post subject: Dynon's OAT sensor |
Out of curiosity, I just took my electronic temp probe out into the sunlight. In the shade it read 45.3 degF; in the sun, 73.9 degF after about 4 minutes.
Jay in Dallas
David Downey <planecrazydld(at)yahoo.com> wrote:
| Quote: | ...could be - but the purpose is to give a reading while flying - and it would take a very black probe and flying very near the sun to have more than a very very small influence after the first several minutes of flight.
Jaybannist(at)cs.com wrote:
Dave,
If I'm not mistaken, those probes were shielded so that the probe was not exposed to direct sunlight. The Dynon probe is not shielded.
Jay in Dallas
David Downey
wrote:
>I would have thought that the OAT was intended to read OAT - in flight. In the past the probes were direct reading dial thermometers and on many aircraft stuck right through the canopy bow.
>Dave Nixon wrote:
>I mounted mine in the fuselage bottom in the access hole of the co-pilot's seat just aft of the main carry thru spar. This keeps it out the sun (very important) and away from the exhaust gas. It works very good.
>Dave Nixon
>Read this topic online here:
>http://forums.matronics.com/viewtopic.php?p=168400#168400
> Dave Downey
> Harleysville (SE) PA
> 100 HP Corvair
>Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now.
Dave Downey
100 HP Corvair
Never miss a thing. Make Yahoo your homepage.
planecrazydld(at)yahoo.co Guest
Posted: Sat Mar 08, 2008 11:26 am Post subject: Dynon's OAT sensor |
very good point.
Craig Payne <craig(at)craigandjean.com> wrote:[quote] <![endif]--> <![endif]--> Well in my instrument (MGL Enigma) the OAT drives the density altitude display – something I want to know *before* I try to take off.
-- Craig
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of David Downey
Sent: Saturday, March 08, 2008 10:47 AM
Subject: Re: Re: Dynon's OAT sensor
--> Zenith-List message posted by: Jaybannist(at)cs.com
Dave,
Jay in Dallas
>Dave Nixon wrote: --> Zenith-List message posted by:
| Quote: | | http://www.matronics.com/Navigator?Zenith-List | 0123456[quote][b]Be a better friend, newshound, and [quote][b]
Posted: Sat Mar 08, 2008 2:20 pm Post subject: Dynon's OAT sensor |
My answer (worth exactly what I charged for it!) was based on the documented facts that our rotor blades cool rapidly as soon as they start turning. If they did not (and they have been instrumented to prove they do) the materials we engineered them from would fail structurally very soon after loading. My error was in making the assumption that the passing air would remove heat from the probe?
Jaybannist(at)cs.com wrote:[quote] --> Zenith-List message posted by: Jaybannist(at)cs.com
Dave, I don't understand why flying would influence a temperature probe. Probes are not sensitive to "wind chill" or "heat index". They ARE influenced by direct sunlight, which is why temps are always taken in the shade (if they are to be accurate).
Jay in Dallas
David Downey wrote:
[quote]...could be - but the purpose is to give a reading while flying - and it would take a very black probe and flying very near the sun to have more than a very very small influence after the first several minutes of flight.
Jaybannist(at)cs.com wrote: --> Zenith-List message posted by: Jaybannist(at)cs.com
Dave,
Jay in Dallas
David Downey
>Dave Nixon wrote: --> Zenith-List message posted by: "Dave Nixon"
>Dave Nixon
> Dave Downey
> 100 HP Corvair
Dave Downey
100 HP Corvair
Never miss a thing. [quote][b]
601zv(at)ritternet.com Guest
Posted: Sun Mar 09, 2008 1:49 pm Post subject: Dynon's OAT sensor |
What does it read in the sun in a 100mph airstream?
Posted: Sun Mar 09, 2008 2:53 pm Post subject: Dynon's OAT sensor |
I can't answer that 'cause I don't have a 100 mph airstream in my back yard. An aircraft's temperature probe, sitting on the ramp, is not in a 100 mph airstream, either. Wouldn't you like an accurate temperature reading on the ground BEFORE charging off into a high density situation?
Jay in Dallas
Posted: Sun Mar 09, 2008 3:34 pm Post subject: Dynon's OAT sensor |
Most certainly, and I'm planning to avoid a sunny location. I was just
curious about what effect the cooling airstream might have for in flight
readings if someone did do a sunny mount, and thought someone knowledgeable
might chime in. I would guess that the cooling airstream would for the most
part offset the sun heating, but was wondering if, as is frequently the
case, I'm guessing wrong.
rsteele(at)rjsit.com Guest
Posted: Sun Mar 09, 2008 3:58 pm Post subject: Dynon's OAT sensor |
If you are sitting on hot pavement, seems to me the heat coming off
the pavement going to affect reading too. You could have a little
oven between the skin and the pavement. I'm not saying this is worse
than the sun, just that like everything else about flying, it's a
compromise.
Ron
Jeyoung65(at)AOL.COM Guest
Posted: Sun Mar 09, 2008 7:22 pm Post subject: Dynon's OAT sensor |
I think you are correct. The wind will transfer the heat from radiated heat and bring your reading down to air temp. Jerry of Ga.DO NOT ARCHIVE
In a message dated 3/9/2008 7:35:07 P.M. Eastern Daylight Time, 601zv(at)ritternet.com writes:
| Quote: | --> Zenith-List message posted by: "Robin Bellach" <601zv(at)ritternet.com>
It's Tax Time! Get tips, forms and advice on AOL Money & Finance.
Posted: Mon Mar 10, 2008 2:21 am Post subject: Dynon's OAT sensor |
we discovered that the hottest surface on a 737 was the underside of the polished horizontal stabilizer when the aircraft was parked at a particular orientation on blacktop.
Ronald Steele <rsteele(at)rjsit.com> wrote:[quote] --> Zenith-List message posted by: Ronald Steele
compromise.
Ron
[quote] --> Zenith-List message posted by: "Robin Bellach"
leo(at)zuehlfield.com Guest
Posted: Mon Mar 10, 2008 9:56 am Post subject: Dynon's OAT sensor |
45 years ago when I was a navigator in C-124s, I had to deduct 1 degree
centigrade from the in-flight OAT reading due to air friction on the
probe at our TAS (200K).
Jeyoung65(at)aol.com wrote:
| Quote: | I think you are correct. The wind will transfer the heat from radiated
