Lost Mold
craig.nelson(at)heraeus.c
PostPosted: Wed Mar 05, 2008 10:18 am    Post subject: Lost Mold Reply with quote
<<DSCN1907.JPG>> <<DSCN1893.JPG>> <<DSCN1894.JPG>>
<<DSCN1900.JPG>> <<DSCN1902.JPG>> <<DSCN1904.JPG>>
<<DSCN1906.JPG>>
I do use dry wall plaster in making lost mold techniques along with
paper..on this mold I used gauze and it worked out very well.. I also
use clay to do little fixes-- after the plaster is shaped to the final
contours and ready for composite I seal the surface with a dental
separator used to make dentures and then the residual plaster can easily
be rinsed away with water. After the part is removed from the plaster
and trimmed the surface is smoothed and prepared for paint.
Uncle craig
 Filesize:  54.36 KB
 Viewed:  559 Time(s)
 Filesize:  58.48 KB
 Viewed:  580 Time(s)
 Filesize:  53.6 KB
 Viewed:  574 Time(s)
 Filesize:  71.94 KB
 Viewed:  603 Time(s)
 Filesize:  77.04 KB
 Viewed:  607 Time(s)
 Filesize:  37.91 KB
 Viewed:  609 Time(s)
 Filesize:  59.92 KB
 Viewed:  570 Time(s)
PostPosted: Wed Mar 05, 2008 5:02 pm    Post subject: Lost mold Reply with quote
<<DSCN1909.JPG>> In a few hours from start to finish custom farings
Uncle craig
 Filesize:  31 KB
 Viewed:  610 Time(s)
ElleryWeld(at)aol.com
PostPosted: Wed Mar 05, 2008 5:48 pm    Post subject: Lost mold Reply with quote
Uncle Craig that's not the color I wanted ......Just Kidding they look like every thing else you make Like Factory
Ellery
In a message dated 3/5/2008 8:03:59 P.M. Eastern Standard Time, craig.nelson(at)heraeus.com writes:
Uncle craig
It's Tax Time! Get tips, forms and advice on AOL Money & Finance.
Bill Vincent
PostPosted: Wed Mar 05, 2008 5:57 pm    Post subject: Lost mold Reply with quote
wow! It looks great
DO NOT ARCHIVE
Uncle craig
Bill Vincent
Firestar II
Upper Peninsula of Michigan
NeilsenRM(at)comcast.net
PostPosted: Thu Mar 06, 2008 8:27 am    Post subject: Lost Mold Reply with quote
I'm going to ask a stupid question. Why the extra step of the lost mold? Why
don't you just form the composite on the plane?
Rick Neilsen
Redrive VW Powered MKIIIC
mdnanwelch7(at)hotmail.co
PostPosted: Thu Mar 06, 2008 10:06 am    Post subject: Lost Mold Reply with quote
Rick Neilsen
Mr. Rick,
Excellent question. I guess in some case, especially where outer surface appearance isn't that important, you could do that.
However, when making most items to be installed on your Kolb airplane, you want them to have the high quality and beauty that Uncle Craig creates. In order to get that level of perfection, you pretty much need to build that "perfect" part, in position, on your plane......and then copy it (with the "lost mold", and then recreate it.
Here's why; If you do all that "rough" build up, like with tape, or wood strips or plaster, or whatever you choose to use, you have is the approximate shape. Say you go ahead and add some smoothing agent, like the joint compound, or bondo, of carving foam, etc., and you've shaped your fairing....real nice.
Ok, so now you start the fiberglass for the finished piece. Remember, the really nice surface is on the INSIDE of your layers of fiberglass, not the outside. But, let's continue. So if we put a few layers of fiberglass on the outside, and once it's cured, pull it apart. You will find you have something that is similar in shape as your build-up, but, boy, is the outside in rough shape. You will have to sand, and sand, and sand, on, and on. And I'm here to tell you, fiberglass impregnated with resin is darn near rock hard. Shaping after the fact is a living nightmare!!!! It will be the same process you just went through, making that "perfect shape" on your plane, only this time you won't be smoothing bondo, or joint compound, you be trying to smooth....well, glass!!!
Even though making a "lost mold" is a lot of work, and on the face of it, APPEARS to be double the effort, it really isn't. You will spend much more time trying to enhance the appearance of the shortcut method.
Another very big difference between the proper mold method, and the quick "lay on some fiberglass layers" method is weight. Think about it. If we make our sculptured shape flawless...on the plane...in position, and then make a thick rigid mold, whatever we build on the inside is going to be just as flawless (on its outer surface...the important surface). We can probably get away with as little as 2-3 coats of glass. This piece will be virtually perfect, needing only very minor and easy edge trimming. Lightly sand and then paint.
But if we try to get away with 2-3 coats of an outside build, the piece will have all kinds of flex and give as we try to make it "perfect". We'll need 5-7 coats of material, to have the necessary rigidity to sand the heck out of it.
While I understand your logical question, the industry standard is to build a mold of a "finished product", then recreate that finished product INSIDE the mold. BTW, not all mold are "lost". Obviously, many molds are built to withstand the ability to make hundreds of copies. (bathtubs, , boats, etc) That is why the release agent is so critical. It leaves to mold unharmed by trying to pry out your beautiful artwork.
Best regards, Mike Welch
Helping your favorite cause is as easy as instant messaging. You IM, we give.
PostPosted: Thu Mar 06, 2008 11:07 am    Post subject: Lost Mold Reply with quote
I can shape the piece with plaster make the contours perfect. The
plaster sometimes gets up to 1 inch thick. The part ends up one layer of
s glass one layer of carbon and one layer of s glass extremely light and
not much filler to smooth it out.
Uncle craig
PostPosted: Thu Mar 06, 2008 11:32 am    Post subject: Lost mold Reply with quote
<<DSCN1915.JPG>> <<DSCN1890.JPG>> <<DSCN1891.JPG>>
<<DSCN1892.JPG>> <<DSCN1913.JPG>> <<DSCN1914.JPG>>
.Lost mold means just that. The mold is lost when the part is made. I
make a positive mold out of tape to get the basic shape then the plaster
is used to make the mold strong enough to remove from the plane.. More
plaster is used to get the proper contour of the part .. Then I apply
separator to the plaster called Aislar a dental denture material in
dentistry it is call tin foil substitute used to fill the pours plaster
so acrylic does not stick to it. Then I wax the plaster form and apply
the layers of glass and resin, when this sets up I remove the part from
the mold. The plaster brakes up on removal because it is not strong
enough to stay in one piece when removing the part.( lost mold it is
only good for one part) Then I fill the weave of the cloth with filler
and paint it
Uncle craig
 Filesize:  69.83 KB
 Viewed:  602 Time(s)
 Filesize:  68.93 KB
 Viewed:  570 Time(s)
 Filesize:  57.2 KB
 Viewed:  572 Time(s)
 Filesize:  42.51 KB
 Viewed:  567 Time(s)
 Filesize:  86.57 KB
 Viewed:  589 Time(s)
 Filesize:  87.16 KB
 Viewed:  563 Time(s)
MKIIIX040
PostPosted: Fri Mar 07, 2008 8:00 am    Post subject: Lost Mold Reply with quote
Mike, Stupid Question # 2
Would the finished fairing have a larger ID than the plaster mold (1st build up)?
Seems like you would have to extend the finished fairing out beyond the edges so it would meet the strut cover or whatever it contacts. How is that done if your doing a layup inside your mold?
Note: 10 layers of glass mat ( video), if I used that much my part would weigh 100 lbs. and be an inch thick.
Vic
N740VP
If you can still see out your house windows you didn't shovel as fast as you could have.
MKIIIX040
912UL
PostPosted: Fri Mar 07, 2008 9:15 am    Post subject: Lost Mold Reply with quote
Hi Vic,
Again, nice observation. If you shaped a perfect fairing (on your plane), and you took a mold off that perfect fairing, and then you built your part on the inside of that mold, your finished part (fairing) would be slightly smaller, not larger.
With this understanding, that your part will be slightly smaller (by the width of you glass layers) you may want to build up your sculpted prototype, with extra tape, etc.
This is especially important if you are building something that has an opening, like our fairing. Our fairing has two area of interest...the part that fastens to the fuselage. A tiny bit smaller, or bigger would never be noticed. But the part that has a hole, that slips up the wing strut, won't fit unless you've made that opening a little oversize". No doubt, Uncle Craig allowed for this.
I know it seems to get a little confusing, but if you take into consideration that male, female, male, undersize, oversize, etc., etc. changes, it really isn't hard.
Example, if I were to make that exact same part as Uncle Craig made, I would wrap the wing strut with...oh, about 3 layers of duct tape, since duct tape is "close" to the thickness of fiberglass cloth. 3 layers of tape gives you room for 3 layers of glass. So, now, when you build a mold around that wing strut, the hole in your mold will be oversize. Right? Therefore, when you start putting in the layers of fiberglass, or carbon fiber, inside your mold....you will be closing in on that original wing strut diameter (prior to the duct tape).
The portion of the mold near the fuselage doesn't matter if it's 1/6"-3/32" smaller, you'd never know. But the part of your fairing that needs to slide up and down the wing strut won't fit, unless you accomodate for it.
The video of mold making was just that....only the mold. That's why the 10 layers. He was making a mold, not the finished part. With this mold he made, he can now apply plenty of mold wax, then gel-coat, and then 3-4 layers of cloth (whether it is carbon fiber, E glass, S glass, etc.) Because his mold is 10 layers thick of fiberglass, it should last for years, and hundreds of "take-offs".
Mike Welch
Vic
N740VP
MKIIIX040
PostPosted: Fri Mar 07, 2008 11:12 am    Post subject: Lost Mold Reply with quote
Thanks Mike. By jove I think I've got it Finaly
Vic
N740VP
MKIIIX040
912UL
