n616tb(at)btsapps.com Guest
Posted: Wed Mar 05, 2008 8:36 am Post subject: Pre-presurizing the oil system |
I have a pressure pot and need to pre-pressurize the oil system on a Lycoming IO540 (no, this isn’t in my RV-6). My question is where is the best place to connect the hose from the pressure pot to make sure we get oiling throughout the engine and not just dumped into the pan. I was thinking the oil pressure gage port but not sure what gets bypassed. The repair was a top overhaul only so oiling the bottom wouldn’t be as necessary, but I suspect that is the end of the oil chain anyway.
RV-6
862 Bytes |
2865 Time(s) |
Posted: Wed Mar 05, 2008 9:59 am Post subject: Pre-presurizing the oil system |
Posted: Wed Mar 05, 2008 12:51 pm Post subject: Pre-presurizing the oil system |
Posted: Wed Mar 05, 2008 2:03 pm Post subject: Pre-presurizing the oil system |
Linn, did you have an idea to add to this? Your posts came up empty twice.
[quote] --
Posted: Wed Mar 05, 2008 2:10 pm Post subject: Pre-presurizing the oil system |
Tim Bryan wrote:
| Quote: | | Quote: | --> RV-List message posted by: "Tim Bryan" <n616tb(at)btsapps.com> (n616tb(at)btsapps.com)
Do Not Archive | | Don't know what's going on!!! That's the first time it's happened to me!!!
On the front of the engine you'll find two (one each side) 1/4" plugs with an allen wrench hole. Adapt from the pressure pot and hook it in there.
Linn
[quote] [quote]
[quote]--
khorton01(at)rogers.com Guest
Posted: Wed Mar 05, 2008 5:53 pm Post subject: Pre-presurizing the oil system |
I don't know why this happens, but every once in a while some
messages appear empty. But, there is often content that can be seen
if you can select an option in your mail program to view raw source.
On Safari on OS X, you go to the View menu, select Message -> Raw
Source. Both Linn's messages had content if you did that.
Kevin Horton
empty twice.
Posted: Wed Mar 05, 2008 6:24 pm Post subject: Pre-presurizing the oil system |
Also works with Netscape!!!
Thanks Kevin!!!
Linn
Kevin Horton wrote:
Kevin Horton
