rv10builder(at)bellsouth. Guest
Posted: Sun Mar 02, 2008 4:56 pm Post subject: Jacking up the -10 |
Hey all,
I'm trying to figure out the best way to jack up my 99% completed -10 so
that I can complete the fitting of the main gear fairings.
Suggestions? I've got a harbor freight nearby...
Brian
40308
Main gear fairings then inspection!
Tim Olson
Posted: Sun Mar 02, 2008 5:36 pm Post subject: Jacking up the -10 |
May as well do it right and prepare for years of future maintenance...
http://www.myrv10.com/tips/generaltips.html#Jacking_the_RV-10
I just used mine this weekend, because the last flight I did had
4" of snow on field that wasn't plowed....and I had to dig it all
out of the wheel fairings this weekend. Basically, all of the
fairing that wasn't occupied by tire, was occupied by snow. Amazing
how much came out.
rv10builder wrote:
Hey all,
Brian
40308
Posted: Sun Mar 02, 2008 6:13 pm Post subject: Jacking up the -10 |
Very nice Tim! So I can assume you were using the tie down ring
locations under the wing as the jack point? I was concerned that it may
not be strong enough, but it sounds like like a non-issue.
Thanks!
Brian
Tim Olson wrote:
how much came out.
rv10builder wrote:
> Hey all,
> so that I can complete the fitting of the main gear fairings.
> Thanks,
> Brian
> 40308
Posted: Sun Mar 02, 2008 6:24 pm Post subject: Jacking up the -10 |
We built a set like Tim's and they work great. Make sure you have a
head that goes on the top of the jack that will allow it to swivel a
little bit so you don't put undue side loads on the tie down bases.
I talked to Van's and they said this is the preferred way to jack it
up. Also, the same jack is a great way to hold up the tail without
the engine installed. As Tim said, you will use these in the future
for maintenance.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
On Mar 2, 2008, at 8:33 PM, Tim Olson wrote:
how much came out.
rv10builder wrote:
> Hey all,
> -10 so that I can complete the fitting of the main gear fairings.
> Thanks,
> Brian
> 40308
Tim Olson
Posted: Sun Mar 02, 2008 6:47 pm Post subject: Jacking up the -10 |
Yep, as Jesse said, it's the preferred location.
rv10builder wrote:
Thanks!
Brian
> how much came out.
> Tim Olson - RV-10 N104CD - Flying
> do not archive
> rv10builder wrote:
>> Hey all,
>> Thanks,
>> Brian
>> 40308
Jim Berry
Posted: Mon Mar 03, 2008 12:20 pm Post subject: Re: Jacking up the -10 |
To all,
Has anyone developed a good method to jack and support the completed fuselage before the wings are attached. I want to raise the fuselage off the wheels and fit the wheel pants before mounting the wings.
Jim Berry
40482
N15JB(reserved)
Posted: Mon Mar 03, 2008 12:49 pm Post subject: Jacking up the -10 |
With or without the engine? If without, then using a jack/stand on
the engine mount and one on the tail tie down base and then something
to stable it works. With the engine, then you could possible use an
engine hoist to hold up the front and a jack/stand on the tail, also
with something to stabilize it.
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
On Mar 3, 2008, at 3:20 PM, jim berry wrote:
To all,
Jim Berry
40482
N15JB(reserved)
http://forums.matronics.com/viewtopic.php?p=167445#167445
Posted: Mon Mar 03, 2008 1:02 pm Post subject: Jacking up the -10 |
I went down to harbor freight, and they were having a sale on lift
tables. I bought one, modified it a bit, and it worked like a charm.
See here:
http://www.perfectlygoodairplane.net/Perfectlygoodairplane/Landing_Gear.
html
it was just the ticket for doing the wheelpants and gear leg fairings.
I used a heavy duty saw horse under the tail, and adjusted the height so
that the aircraft was level.
cj
Jim Berry
Posted: Mon Mar 03, 2008 1:38 pm Post subject: Re: Jacking up the -10 |
Jesse,
The engine and prop are on. I thought about using my engine hoist to lift the fuselage, but am reluctant to hang all the weight from the engine mount or the engine lifting ring.
cj,
The link to your landing gear does not work, and I could not find the table you mentioned searching manually.
Jim Berry
40482
N16JB(reserved)
taildragon(at)msn.com Guest
Posted: Mon Mar 03, 2008 1:39 pm Post subject: Jacking up the -10 |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Jim,
Here is how I do it...
20.15 KB |
895 Time(s) |
ricksked(at)embarqmail.co Guest
Posted: Mon Mar 03, 2008 1:52 pm Post subject: Jacking up the -10 |
Thats a great but TINY picture...can you descibe what the jack is pushing on and how it's attached to the gear.
Rick Sked
40185
Posted: Mon Mar 03, 2008 1:58 pm Post subject: Jacking up the -10 |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Her is how I do it...
[img]cid:005801c87d79$34314c60$1AEB6440(at)ROGERsPC[/img]
109.65 KB |
946 Time(s) |
capsteve
Joined: 09 Jan 2006 Posts: 111 Location: NIAGARA FALLS NY
Posted: Mon Mar 03, 2008 2:14 pm Post subject: Jacking up the -10 |
when you install the wheel pants you might want to jack the fuse itself and leave the gear legs in an "in-flight position" or relaxed position to ensure alignment with the airflow. i had one already installed when i started to think about it. when i jacked the plane and refit the wheel pant there was a difference. it wasn't major, but probably enough to affect trim flight....
steve dinieri
[quote] From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Roger Standley
Sent: Monday, March 03, 2008 4:55 PM
Subject: Re: Re: Jacking up the -10
[img]cid:005500122(at)03032008-00B8[/img]
109.65 KB |
902 Time(s) |
Posted: Mon Mar 03, 2008 2:18 pm Post subject: Jacking up the -10 |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Hi Rick,
Yes, I welded a bolt at about a 45 degree angle to a cut piece of galvanized pipe, and covered it with epoxy and micro-balloons. Wrapped the inside of the pipe with a strip of inter-tube to prevent scratching and to add friction. The bolt fits in a hole drilled in the top of the scissor jack (from Kragens). Using an electric drill with a "tee" makes for easy jacking.
Roger
Oops. The link wrapped to the next page. Try this
www.perfectlygoodairplane.net/Perfectlygoodairplane/Landing_Gear.html
if it wrapped to the next line again, just make sure the .html is on there
or go to the finishing section, and select "landing gear"
cj
Posted: Mon Mar 03, 2008 2:30 pm Post subject: Jacking up the -10 |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Rick, here is another pic of the "gear grabber. After cutting the pipe, open it up to allow it to slide over the gear near the wheel but tighten against the gear leg as it is raised toward the fuselage.
[img]cid:00a401c87d7d$6e4f1680$1AEB6440(at)ROGERsPC[/img]
8.52 KB |
17469 Time(s) |
Posted: Mon Mar 03, 2008 2:50 pm Post subject: Jacking up the -10 |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Hi Steve,
You are right. When we did the wheel pants, we let the gear "sag", but it didn't sag much. We braced from the spar carry-thru and fitted the wheel pants.
[img]cid:00cf01c87d80$7feb6bc0$1AEB6440(at)ROGERsPC[/img]
25.43 KB |
894 Time(s) |
109.65 KB |
921 Time(s) |
Tim Olson
Posted: Mon Mar 03, 2008 2:55 pm Post subject: Jacking up the -10 |
Actually, I think that's the Per-plans way...you're supposed to
let the gear hang and align the fairings while they're in the
in-flight hanging position.
Steven DiNieri wrote:
| Quote: | when you install the wheel pants you might want to jack the fuse itself
steve dinieri
flywrights(at)yahoo.com Guest
Posted: Mon Mar 03, 2008 4:06 pm Post subject: Jacking up the -10 |
Two or three pallets with the top one covered with a carpet scrap. Then use various shims to ensure level across the fuselage. That ws my method and it seemed fine, especially after dropping many plumb lines and square lines on the floor to cross-check in-plane.
Rob Wright
#392
looking at a LOT of sanding when I do the body prep for the door-canopy prep. Just didn't seem to cure flush even after many many clamps held it correctly.
But I DID hang then engine today!
Posted: Mon Mar 03, 2008 4:28 pm Post subject: Jacking up the -10 |
Very cool, I was looking for a way to jack mine easily from the gear, I have mine on Harbor Freight dollys and I can see using them once flying to get the most from our hangar space (Bob Kauffman and I) we have 3500 SF and rent out what we don't need. The dollys allow us to move the aircraft easily into the corners...we inconvience ourselves but not our tenants...looks like an aerolift may be on the way. Hangar space at North Las Vegas is sparce...we are lucky to own the facility we have. Once the fly off is done and the fairings are on for good I'll have to jack from the wing tie down to put it on the dollys...small price to pay for "free" hangar space.
Rick Sked
40185
