Door Latches
fklein(at)orcasonline.com
PostPosted: Wed Feb 27, 2008 5:43 pm    Post subject: Door Latches Reply with quote
Hi Guys,
Thanks for the helpful comments on my previous post re: Rudder Cables!
Regarding door latches...the build manual speaks of bending an offset
into the inner latch arm, DL03 but makes no mention of the distance of
the offset...What works? 1/8 inch? 1/4 inch?
Also, is there a clever locksmith among us who has added a keyed lock
which keeps the shoot bolts in place?..or provides security in some
other fashion? Any references to pictures would be much appreciated.
Some time ago, there was concern about the window frames bulging and as
I recall, Cliff Shaw had a very clever albeit complex third (vertical I
believe) shoot bolt. Might not "bulging" be more easily handled by
adding a bid stiffening angle along the interior bottom edge of the
window frame? (Or is the bulging the result of failure to relieve
cabin air pressure by not venting the baggage bay bulkhead thence out
thru the recommended drain holes at the underside of the fuselage?)
Fred
A194
believed to be clean.
rehn(at)rockisland.com
PostPosted: Wed Feb 27, 2008 7:18 pm    Post subject: Door Latches Reply with quote
Fred
Yes Cliff did have that cool extra center shoot bolt. But others have done
the same with just a Fixed post in the center that they just pulled the
window down over and was a much simpler mod. I have neither and really don't
notice a problem. Man you need to get done! I need another Europa up here in
the islands to fly with! Take care.
Jerry
g-iani(at)ntlworld.com
PostPosted: Thu Feb 28, 2008 1:20 am    Post subject: Door Latches Reply with quote
The attached is the Club door lock Standard mod. It has been with the
LAA for two years for approval as a standard mod but they have yet to
get round to it.
It has been flying on my aircraft for some 3 years. The intention was
to publish it when approved as standard.
Ian Rickard #505 G-IANI XS Trigear
Europa Club Mods Rep (Trigear)
e-mail mods(at)europaclub.org.uk
or direct g-iani(at)ntlworld.com
Door_Lock.pdf
 Filename:  Door_Lock.pdf
 Filesize:  278.4 KB
 Downloaded:  288 Time(s)
cptimm(at)telus.net
PostPosted: Fri Feb 29, 2008 1:40 pm    Post subject: Door Latches Reply with quote
terrys(at)cisco.com
PostPosted: Fri Feb 29, 2008 3:42 pm    Post subject: Door Latches Reply with quote
Hi Fred,
We heard stories of doors bowing out in flight and added a latch in the
middle of the door frame to prevent it. As it turns out, the newer
doors are stiffer and do not need any additional latch in the middle.
Even though we have the extra latches, we never use them.
Terry Seaver
A135 / N135TD
Mono-wheel XS
erichdtrombley(at)juno.co
PostPosted: Sat Mar 01, 2008 6:35 pm    Post subject: Door Latches Reply with quote
Regarding the door latch; I choose not to offset it. There is plenty of clearance between the latch and plexi without the offset. Furthermore, without the offset there is next to nil of a chance that you will accidentally open the door in flight. I tapped the small hole used for mounting a handle and threaded a stainless hex cap screw for looks instead of a bulky handle which might possible catch on a sleeve, etc. Also, I did not install a protective cover. BTW I have over 500 hours logged over the last 5 years and have never had a close call with the latches. Good luck.
Erich Trombley
N28ET
Classic Mono 914
_____________________________________________________________
Click to find local singles for dating, romance and fun.
http://thirdpartyoffers.juno.com/TGL2111/fc/Ioyw6iif6R8dLACUFk6odZTlFZgReFKMgMUCUQt8007JkppEjncA04/
