wcurtis(at)core.com Guest
Posted: Fri Jan 06, 2006 12:23 pm Post subject: Re: Negative Battery Cable Connection |
[quote]#4 would probably be fine unless you spend a lot of time in the >frozen tundra. Might be pushing it then. I, as Tim did, will be >putting in #2 for that exact reason. It gets mighty cold in WI >from time to time. If I never left the warmer climates I wouldn't >bother. Don’t understand this logic. Conductivity INCREASES as temperature decreases. If you are talking about battery performance with temperature, well that’s something else and AFAIK not dependant on the cable attached. That being said however the Van’s ES WH 10 Kit uses #2 positive cable and the airframe as ground per page OP37-12 of the electrical wiring harness instructions. William Curtis http://nerv10.com/
joeb47(at)verizon.net Guest
Posted: Fri Jan 06, 2006 12:53 pm Post subject: Re: Negative Battery Cable Connection |
The situation is thus:
The resistance of the cable, for any given size, does decrease
with decreasing temperature. NOT a large decrease however.
The ability of the battery to deliver full cranking current
decreases with decreasing temperature. This is a BIG
change.
The requirement to crank the engine GREATLY increases
Therefore the larger wire size WILL help some.
Best method to make a large improvement would be a
larger battery or a gear drive starter motor.
Joe Bienkowski, Bowling Green, OH
William wrote:
| Quote: | >#4 would probably be fine unless you spend a lot of time in the
>bother.
cable attached.
William Curtis
http://nerv10.com/
rvbuilder(at)sausen.net Guest
dlm46007(at)cox.net Guest
Posted: Fri Jan 06, 2006 4:32 pm Post subject: Re: Negative Battery Cable Connection |
I am using two Odyssey 680s individually or in parallel for starting through
a #2 cable to the starter relay. together they can supply 680 amps each for
the first five seconds and then about 300.
Posted: Fri Jan 06, 2006 8:20 pm Post subject: Re: Negative Battery Cable Connection |
[quote]The requirement to crank the engine GREATLY increases >with decreasing temperature. > >Therefore the larger wire size WILL help some. How so, as it relates to temperature? The original premise was that it may be fine at regular temperature but not so in the cold. I only submit that if the performance is sub-par at a lower temperature it will also be sub-par at normal temperature. Thicker cable is indeed better-there is no debate there. I only suggest that nothing with regard to the cable has any dependency on the temperature. Certainly the lowered temperature has an effect on the battery performance however. William Curtis http://nerv10.com/
kellym(at)aviating.com Guest
Posted: Fri Jan 06, 2006 8:29 pm Post subject: Re: Negative Battery Cable Connection |
You are only looking at the cable and battery performance. The colder it
is, the more force required to turn the engine(thicker oil, reduced
clearances, as well as more friction in the starter itself). More amps
needed to provide that torque, drastically more. If you look at the
stalled rotor draw of the starter you get an idea of what the peak draw
will be. Peak draw is what you are concerned with, not average draw. In
warm weather peak draw will be much lower, hence lighter cable can carry
the say 200 amps needed, where they might not carry the 350+amps drawn
in a cold start at or below freezing.
William wrote:
| Quote: | >The requirement to crank the engine GREATLY increases
Tim(at)MyRV10.com Guest
Posted: Fri Jan 06, 2006 9:00 pm Post subject: Re: Negative Battery Cable Connection |
I think he just means that the actual load on the starter to crank
the very cold engine with it's also thicker oil and
everything else requires more battery power...even if you had
a nice warm battery capable of delivering all of it's
summertime current, it would take more to get it to crank
than in the summer.
I know what Michael means when he talks about his 4ga jumper cables.
We have consistent periods of 10 to 20 day in a row each winter where
every day is below zero. I've used cheap jumper cables to try to
start cars with weak batteries, but eventually I got a nice pair
of thick ones as a gift. They'll crank a car over much better than
the smaller wired ones. I've also actually seen with my own eyes,
battery cables with the insulation melted and sliding off because
the person cranked too long on the starter during times trying
to start the engine.
I just know that whenever I've tried to go flying and it's between
10 below and 10 above zero (yes, I keep a preheater plugged in
all winter long) it definitely doesn't start as easily and
having a well charged battery, with a battery blanket
attached can help get things started much easier. The 2GA wire
won't hurt. Nothing against the 4 for those who are lucky
enough to have that as a viable option.
Yeah, you may not want to move up here.
Tim Olson -- RV-10 #40170
Current section: Panel Wiring
DO NOT ARCHIVE
Posted: Fri Jan 06, 2006 9:02 pm Post subject: Re: Negative Battery Cable Connection |
Forgot to mention...hence the reason I buy 1000+ CCA batteries
for my truck. You need it in the winter. The coldness
of the battery just adds to the need.
DO NOT ARCHIVE
Kelly McMullen wrote:
Posted: Fri Jan 06, 2006 9:45 pm Post subject: Re: Negative Battery Cable Connection |
For those looking for batteries; check out
http://www.enersysreservepower.com/ody b.asp?routine=ody spec&brandID=5 . I
am using dual 680s but a 925 mounted on a side will fit the kit battery
configuration.
ddddsp1(at)juno.com Guest
Posted: Fri Jan 06, 2006 10:31 pm Post subject: Re: Negative Battery Cable Connection |
Anyone using the FATWIRE battery cable from Periheliondesigns.com? Suppose to be 45% lighter and more flexible? Twice tha cost though!!! Also, was looking to do an Odessey 925 with a small SLA motorcycle battery as a backup in case of ALT/BAT failure. Anyone done this.....if so what does your wiring diagram look like and where did you mount the backup battery?. I would want the backup battery on a separate circuit just to switch on in case alt or main battery failed..........would like it to be charged while flying too.
DEAN
dav1111(at)cox.net Guest
Posted: Sat Jan 07, 2006 2:32 am Post subject: Re: Negative Battery Cable Connection |
I have installed the Pedriheliondesigns Fat Wire and although yet to start the engine I am real happy with the purchase and install. I installed as per Van's Wiring Harness design with a Concord Battery. The Fat Wire is really lite weight and everybody who has seen mine likes it.
I also am using the Fat Wire connection lugs and like them as well.
Russ Daves
N710RV Reserved - Flying to OSH 2006
Date: 2006/01/07 Sat AM 01:29:53 EST
Subject: Re: RV10-List: Re: Negative Battery Cable Connection
Posted: Sat Jan 07, 2006 6:27 am Post subject: Re: Negative Battery Cable Connection |
Sounds real close to what I did (the Battery stuff). I didn't use
Fatwire just because of cost, but I would think it would be
an excellent option for those so inclined.
My Batteries are an Odyssey 925 in the back (I didn't put it on it's
side, but enlarged the tray...either way works fine) and I wanted
a bit more juice from the Aux, so I have 4 thin SLA's that
just make it tucked into some wasted space.
http://www.myrv10.com/N104CD/panel/20051228/index.html
At present, I have it all wired up and working, but I don't have
photos yet.
My diagram is available too.
Today's is
http://www.myrv10.com/N104CD/electrical/N104CD Electrical Schematic Rev5.pdf
But I change it as I find small things as I'm currently wiring it.
It might be a bit different than what some people would do, but
I'm happy with it.
DO NOT ARCHIVE
ddddsp1(at)juno.com wrote:
| Quote: | Anyone using the FATWIRE battery cable from Periheliondesigns.com?
bob.condrey(at)baesystems Guest
Posted: Sat Jan 07, 2006 9:39 am Post subject: Re: Negative Battery Cable Connection |
I considered it but the wire, although lighter, is much larger diameter than standard. Space in my conduit is at a premium.
Sent from my BlackBerry Wireless Handheld
jerry(at)mc.net Guest
Posted: Sat Jan 07, 2006 10:43 am Post subject: Re: Negative Battery Cable Connection |
Tim ...
Your batt install is the best use of airframe space I've seen. I also like
your strap hold-down idea. I'm using a nylon strap as well ... secured with
velcro on top of batt plus velcro between the strap on the return fold.
Question:
What program did you use to to draw your wiring diagram? Did you down load
the symbols from Aeroelectric? I just ordered TurboCAD from ebay V9.2 ...
Thanks ...
Jerry Grimmonpre'
RV8A
Posted: Sat Jan 07, 2006 11:01 am Post subject: Re: Negative Battery Cable Connection |
Thanks Jerry. I used Autocad 2000, I think it is. I just loaded
up one of Bob's existing drawings and then moved things around.
I didn't use any symbol libraries until today when I finally
decided to replace the symbol for the ammeter shunt for something
more like a Hall Effect sensor.
I too was thinking of ordering TurbCAD from Ebay just because it's
so cheap and it might be a nice long-term program to use. The
Autocad I have is kind of a "loaner".
DO NOT ARCHIVE
Jerry Grimmonpre wrote:
lwalters2(at)cfl.rr.com Guest
Posted: Sat Jan 07, 2006 11:06 am Post subject: Re: Negative Battery Cable Connection |
William Curtis
http://nerv10.com/
Guys, Guys. William finally go to the point. The difference between #2
and #4 and down into the 00s boils down to resistance. The resistance
change with the temps we live in don't amount to a hill of beans ....
old electrical term, believe me ..... but the battery does suffer due to
low temperatures. When you're trying to push 200 or 250 or whatever
cold cranking amps down that starter wire, that insignificant difference
in resistance results in a major voltage drop change by the time you get
to the starter.
Having said that, if someone wants to plumb their bird with #10 house
wire .... well, just have at it. Think of it as an experiment. Also,
get some training on how to properly prop an airplane. (OSHA warning
goes here )
For myself, I like to use welding cable ..... far more flexible, less
prone to vibration failures, and it's able to handle the current just
fine. So what if I suffer a small weight penalty ..... I don't have to
worry about starving my starter when I need it.
JMHO
Linn
No virus found in this outgoing message.
Checked by AVG Free Edition.
Version: 7.1.371 / Virus Database: 267.14.15/223 - Release Date: 1/6/06
bcondrey(at)cox.net Guest
Posted: Sat Jan 07, 2006 12:54 pm Post subject: Re: Negative Battery Cable Connection |
The real issue with increased wire size is decreased resistance. #4 copper wire has a resistance of .000249 ohms per foot, #2 has .000156 ohms per foot. These numbers are small, however with a high current draw (starter for example) it makes a huge difference. There's also internal battery resistance to take into account (.004 ohms is a typical value). Bottom line is that you WILL have voltage drop across the wire, how much is dependent on total resistance and current draw. When the temperature is really cold the battery has less capacity AND the engine is harder to turn.
An excellent tutorial on the above is located at http://www.aeroelectric.com/articles/wiresize.pdf
Bob #40105
