		haavard-iversen(at)c2i.ne Guest
				 Posted: Sun Feb 26, 2006 11:11 pm    Post subject: Yak-52 hydraulic lock? |
				Hello!
  Me and my friend have been opertaing our Yak during  wintertime now, operating the engine below 5 degrees Celsius, even down to -5.  STarting the engine really hasn´t ben difficult, but have learned that you  should not without pre-heating. We have drained for oil every 3 days without a  flight, turning 20 blades before priming and another 10.
  After the last flight at Saturday, we notice some  oil dripping out of the exhaust imediatly after shut down.(maybe a  teaspoon  full)
  That we didn´t like much! How common is this? May  this be a sign of a minor hydraulic lock, with bent engine parts?
  Please advise, and from only those serius  guys!
  Thanx!
  Håvard N. Iversen
 Televeien 14A
 2020  skedsmokorset
 mobil: +47 928 93 546
 www.yaknorway.com
 e-mail: haavard-iversen(at)c2i.net (haavard-iversen(at)c2i.net)
 I am using the free version of SPAMfighter for private users.
 It has removed 421 spam emails to date.
 Paying users do not have this message in their emails.
 Try SPAMfighter for free now!
		pa3arw(at)euronet.nl Guest
				 Posted: Mon Feb 27, 2006 5:58 am    Post subject: Yak-52 hydraulic lock? |
				Dear Håvard,
 I have never seen this with our Yak.
 Do you run de engine at 60% for about 20 sec. before shutting down??
 Hans Oortman
 Van: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] Namens Håvard N. Iversen
  Verzonden: maandag 27 februari 2006 8:09
  Aan: yak-list(at)matronics.com
  Onderwerp: Yak-52 hydraulic lock?
 Hello!
 Thanx!
 Håvard N. Iversen
  Televeien 14A
  2020 skedsmokorset
  www.yaknorway.com
		cjpilot710(at)aol.com Guest
				 Posted: Mon Feb 27, 2006 6:25 am    Post subject: Yak-52 hydraulic lock? |
				Havard,
  I do not think you have a real problem.  I've seem my 1,200 hour M-14p do this on a number of occactions.  It might be that the ring gaps on one piston have shifted around and line up, allowing some oil to seep by, or you may have a small leak in your induction system seal.  Anyway a "tea spoon" of oil is not a big deal.
  It sounds that you are taking good precaution during the pre-start which where bending a rod would happened.
  There are a number of ways you can check to see if you've bent a rod but this little bit of oil is not (at least to me) not something to worry about.
  Jim "Pappy" Goolsby
				 Posted: Mon Feb 27, 2006 1:38 pm    Post subject: Yak-52 hydraulic lock? |
				The oil leaking from the exhaust after shutdown is not that uncommon. More than likely you shut down with the exhaust valve on one of the lower 3 cylinders open so that oil drained down and out the stack. I have the manifold drain kit installed, so it is not uncommon to see oil drain out when I open the stop cock after pushing the plane back into the hanger.
  Doc
