bigboyzt0yz
Joined: 29 Jan 2008 Posts: 29 Location: Centeral Maryland
Posted: Sat Feb 16, 2008 7:10 pm Post subject: Door Latching you really Like? |
OK Group,
Yes I have posted a lot because there is no sense in re inventing the wheel, there are so great Kitfox minds to pull from on the list. So what is the VERY best way to make, build, adapt some type of latching unit for the doors? I saw a really cool setup on a helicopter it has pins that came out and was operated from a central turning latch doohickey.
I am getting ready to install some bubble doors and was looking for some kind of latching unit that is going to keep the door in place and sealed tight.
I am thinking of building the door frames either from scratch or by altering a set that some one might have and wants to part with reasonably.
I could Tig, Machine, ETC. something together that would not be any problem so there is no limit to your creativity.
Thanks to All
Lee
Keep your feet on the peddels and keep reaching for the sky!!!!
Lee
_________________ Lee Fritz in Owings Mills Md. 2002 KitFox-IV Classic/912UL/Warp drive taper tip/100% Complete ( Extras Strut fairings08, Grove gear09,) 300 hrs since Aug 07 "Have your feet on the Pedals and keep reaching for the sky". |
darinh
Posted: Sat Feb 16, 2008 8:12 pm Post subject: Re: Door Latching you really Like? |
Lee,
Here is how my Series 7 latches are done. Don't know what model you have but something like this could be fitted to any door with some thought. These are the optional door latches that Skystar supplied with the kits...I would assume John McBean is still using this same setup and so you could get them from him.
Description: |
Filesize: |
1.28 MB |
Viewed: |
751 Time(s) |
_________________ Darin Hawkes
Series 7
914 Turbo
Kaysville, Utah |
Guy Buchanan
Posted: Sun Feb 17, 2008 3:22 pm Post subject: Door Latching you really Like? |
At 07:07 PM 2/16/2008, bigboyz toyz wrote:
Quote: | I saw a really cool setup on a helicopter it has pins that came out
Hi Lee,
Please put your aircraft type / status in your signature, it
helps with the answers. (I also like to see full names and locations, too.)
If you have a IV or earlier, then Lynn just posted a very
neat installation last week. It uses two pins fore and aft with a
center crank. I went for a simple latch down low. Murle Williams
makes one that I couldn't get to work so I fabricated one out of
aluminum. (Pictures tomorrow.)
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
clint_bazzill(at)hotmail. Guest
Posted: Sun Feb 17, 2008 3:29 pm Post subject: Door Latching you really Like? |
What is wrong with the single nylon wing vent type on bottom of door. Simple, easy and full proof and perfect fit, fast and cheap. Clint
[quote] Date: Sat, 16 Feb 2008 19:07:28 -0800
Subject: Door Latching you really Like?
OK Group,
Thanks to All
Lee
Lee
Quote: |
arget=_blank>http://www.matronics.com/Navigator?Kitfox-List
p://forums.matronics.com
blank>http://www.matronics.com/contribution
| [b]
dave
Posted: Sun Feb 17, 2008 4:14 pm Post subject: Re: Door Latching you really Like? |
Quote: | What is wrong with the single nylon wing vent type on bottom of door. Simple, easy and full proof and perfect fit, fast and cheap. Clint |
goes back to building101 = K>I>S>S and don't add extra weight that is not needed.
btw had a great day yesterday Ski flying - I would rate it the best of season so far. Today Fz rain and now rain. freeze up and snow tomorrow looks like . Winter flying is great, hard to believe that alot just put theirs away when the best performance can be had plus a Zillion places to land.
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Fox5flyer Guest
Posted: Sun Feb 17, 2008 5:07 pm Post subject: Door Latching you really Like? |
Clint, that is what I have on my Five. Very simple, weigh almost nothing, and best of all, they work. I think Murle Williams sells them as a kit.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 355+ TT
"The aim of an argument or discussion should not be victory, but progress."
- Joseph Joubert
Lynn Matteson
Posted: Mon Feb 18, 2008 10:19 am Post subject: Door Latching you really Like? |
I've heard of occasions where the door blew open due to flex...Michel
in Norway comes to mind, but I may be wrong. I may be all wet, but
wasn't the double-pin door latch utilized on the Speedster for
exactly that reason? When I ran into turbulence in Tennessee last
year, that last thing I needed was to have the doors open. If you
think of the distance between the door hinges and a bottom-of-door
latch, and think of the flex that might occur in the aluminum-framed
door (mine, anyway) I feel a lot safer with a mid-door (vertically
speaking) latch.
Perhaps the later models with their square-tubing doors (they are,
aren't they?) are built stronger and don't require this almost bullet-
proof latch. Sometimes in building, extra weight IS needed.
Lynn Matteson
flying w/475+ hrs
cheap. Clint
OK Group,
reasonably.
Thanks to All
Lee
Lee
arget=_blank>http://www.matronics.com/Navigator?Kitfox-Listp://
forums.matronics.comblank>http://www.matronics.com/contribution_-
http://www.matronics.com/Navigator?Kitfox-List_-
forums.matronics.com_-
contribution_-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
dave
Posted: Mon Feb 18, 2008 1:39 pm Post subject: Door Latching you really Like? |
I don't believe the door blows open. It is a cam lock like a window vent and when installing the doors, bend frame slightly so the front closes first, then the rear gets pulled in with perfect wind seal. I cut notches in the nylon to be able to open the door about 3/4 inch on bottom. This lets in a lot of air on those hot days. Also, have a small bunge that is used to hold tarps etc connected in the old welding on the door. This allows me to reach and close the doors if I decide to fly with them open, taking pictures etc. Also have a small bolt and washer mounted just under the instrument panel that I connect this little bunge to to prevent the door from flying open when in the cut out notch. Simple and easy, 10 times as good as my friends double latch, also 10 times as cheap.
300 hours on this setup, would do it over again
Clint
P.S. I have flown in a number of planes with front and rear door latches, I just do not like them.
> From: lynnmatt(at)jps.net
Quote: | Subject: Re: Door Latching you really Like?
Date: Mon, 18 Feb 2008 13:14:18 -0500
--> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net>
speaking) latch.
Lynn Matteson
flying w/475+ hrs
> cheap. Clint
> From: bigboyzt0yz(at)yahoo.com
> To: kitfox-list(at)matronics.com
> OK Group,
> reasonably.
> Thanks to All
> Lee
> Lee
> ========== _-
> contribution_-
Guy Buchanan
Posted: Mon Feb 18, 2008 7:52 pm Post subject: Door Latching you really Like? |
speaking) latch.
The bubble doors are incredibly stiff, (and incredibly
heavy,) and will mitigate this problem.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
Michel
Posted: Tue Feb 19, 2008 12:09 am Post subject: Door Latching you really Like? |
Affirm, Sir! But only with heavy passenger and under hard landing.
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200
