poasttown(at)yahoo.com Guest
Posted: Sat Feb 16, 2008 6:01 pm Post subject: horizontal stabilizer |
This concerns the horizontal stabilizer struts on a Model IV. I purchased the beefed up horizontal stabilizer struts from Kitfox and was installing them and ran into a problem. When they made the struts they flatten one end ot the tubing to provide a flat area to attach to the single tab on the fuseledge. I attached the rod ends to the horizontal stabilizer but when I tried to attach the struts to the fuseledge tab the rounded portions of the struts touched preventing the flattened areas to go together. I suppose I could add washers to fix this problem but I would think the flattened areas of the struts should go together and touch the tab.
Any suggestions?
Mike Chaney
bigboyzt0yz
Joined: 29 Jan 2008 Posts: 29 Location: Centeral Maryland
Posted: Sat Feb 16, 2008 7:22 pm Post subject: horizontal stabilizer |
Mike Chaney,
Mine has a adjustment at the outboard end only. Just make sure you put a A/N washer under the head of the bolt on the adjustment end in case the joint fails it can not come completely off. If it fails in flight it might be a real problem getting back on the ground safely.
If you need me to send you a photo I will be at the hanger tomorow and could send it when I get back in the afternoon.
Lee
Keep your feet on the peddels and keep reaching for the sky!!!!
Lee
Be a better friend, newshound, and [quote][b]
_________________ Lee Fritz in Owings Mills Md. 2002 KitFox-IV Classic/912UL/Warp drive taper tip/100% Complete ( Extras Strut fairings08, Grove gear09,) 300 hrs since Aug 07 "Have your feet on the Pedals and keep reaching for the sky". |
Lynn Matteson
Posted: Sat Feb 16, 2008 7:43 pm Post subject: horizontal stabilizer |
Were there four individual struts, or two struts V'd together? From
your description it sounds like they sent you four struts/tubes. My
Model IV struts came from the factory as two V-shaped struts...one
left side and one right side. These V-shaped struts are welded
together such that the front one goes onto the fuselage tab, and the
rear tube gets cut at an angle to fit snugly up against the front
tube, then they are welded together. At least that's how mine were
received from the factory back in 1994. The result is that the
flattened part of one strut tube lays onto the fuselage tab, and is
bolted to it. Try looking at it in this way, and see if it makes
sense. Did they send you two or four rod ends? Mine has just two rod
ends, and they go to the front of the hort. stab. The rear
connections to the hort. stab are both the flattened tubes, as I
remember it.
Lynn Matteson
flying w/470+ hrs
On Feb 16, 2008, at 8:58 PM, Mike Chaney wrote:
Quote: | This concerns the horizontal stabilizer struts on a Model IV. I
Any suggestions?
Mike Chaney
www.matronics.com/Navigator?Kitfox-List _-
www.matronics.com/contribution _-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Lynn Matteson
Posted: Sat Feb 16, 2008 8:05 pm Post subject: horizontal stabilizer |
And make sure that the washer you use is an AN 970 washer, which is a
"large area" washer. A normal AN960 washer won't do any good. I think
that an AN960 washer will pull right through a failed rod end
bearing, if I'm not mistaken. My parts list calls for two AN 970
washers <L.A.> in this application. The larger 970 washer won't let
the failed rod end escape.
Lynn Matteson
flying w/470+ hrs
safely.
Lee
Lee
Be a better friend, newshound, and _-
N369LM |
Posted: Sun Feb 17, 2008 9:34 am Post subject: horizontal stabilizer |
Lynn
My original is the same as yours, one piece V shaped. The one I have been flying with for years has the 1/8 inch diameter threaded end that goes into the rod end. Skystar at the time suggested that all of the 1/8 in style be replaced with what was larger, it looks like about 1/4 inch bold welded into the end of the tube.
I finally decided to make the change so I placed the order. I received four tubes, two for each side. Each tube has a rod end and is flattened on the other end. This replacement seemed pretty simple, take the old off and put the new on. Kitfox did not send any instructions so I just figured it was obviously simple.
I was told by Skystar that I should make the modification as few years ago at Oshkosh. Is this modification for my 1994 model IV a one piece V shaped part as my origional and as you described or is it the two seperate tubes as they sent me?
Mike Chaney
Lynn Matteson <lynnmatt(at)jps.net> wrote:
[quote]--> Kitfox-List message posted by: Lynn Matteson
left side and one right side. ......
Lynn Matteson
flying w/470+ hrs
[quote] This concerns the horizontal stabilizer struts on a Model IV. I
and was installing them and ran into a problem. When Be a better friend, newshound, and [quote][b]
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Sun Feb 17, 2008 12:20 pm Post subject: Re: horizontal stabilizer |
Quote: | I attached the rod ends to the horizontal stabilizer but when I tried to attach the struts to the fuseledge tab the rounded portions of the struts touched preventing the flattened areas to go together. I suppose I could add washers to fix this problem but I would think the flattened areas of the struts should go together and touch the tab.
Any suggestions? |
Mike, the front strut goes on top of the fuselage tab and the rear strut goes on the bottom of the fuselage tab. Mine do not touch each other but if they did I would install washer(s) for clearance. You may need to use a longer bolt if you need the extra washers.
Also, the single piece V struts were the original struts. The modifications are the Two piece for each side (4 total) with two rod ends on each side for the outboard ends (front and rear).
Picture of inboard ends attached.
Description: |
Filesize: |
90.46 KB |
Viewed: |
706 Time(s) |
_________________ Tom Jones
Classic IV
Ellensburg, WA
Guy Buchanan
Posted: Sun Feb 17, 2008 3:22 pm Post subject: horizontal stabilizer |
At 05:58 PM 2/16/2008, you wrote:
Quote: | I suppose I could add washers to fix this problem but I would think
Two possibilities:
1. Bend the outboard edges of the fuselage tab up to conform to the
struts using a crescent wrench.
2. Grind the fuselage tab back. You only require one full hole
diameter of metal outside the hole for full strength. (Probably 3/16")
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
occom
Posted: Mon Feb 18, 2008 2:54 am Post subject: horizontal stabilizer |
I've never seen the arrangement you're using, but have you tried placing one
strut below the tab and one above it?
Dave Goddard- Mod IV 1050/582
Lynn Matteson
Posted: Mon Feb 18, 2008 9:46 am Post subject: horizontal stabilizer |
Mike-
I think you'll find that the original rod end was 3/16"...not
1/8"...at least mine was. No matter. What I was told was to replace
the 3/16" threaded end of the strut with a 1/4" threaded end, and use
a suitable rod end bearing on that new threaded end. What I did was
to buy AN490 threaded rod ends...at least that's what Aircraft Spruce
calls them. I was at Sun 'n' Fun and happened to find what I thought
I would need at one of the vendors there. I didn't know what size I
would need, as I hadn't cut the original strut open yet, so I bought
two each of three sizes. It turned out that the size I needed was the
one for use with 3/8" tubing of .035" wall thickness. Spruce calls
this part # AN490HT6P, and describes it as "used with tube size" ...
3/8"x .035" At $11.30 each, they aren't cheap...page 137 of the new
catalog. Then you'll have to find a rod end bearing of 1/4"-28
threaded female shank, with a .190" bore...or 3/16"...this is for
the #10 mounting bolt.
I just looked at the ends that I had cut off from my original struts,
and looking into the tubing I saw something that rather shocked
me...Skystar had used a socket head cap screw welded into the end of
the tubing instead of the proper AN490 threaded rod end. I suppose
this might be OK, but the AN490 has a MUCH longer area that goes into
the tube and therefore makes for a much more secure welded connection.
I looked at my plane yesterday, and the original (at least on my
plane) has the smaller diameter tube...3/8"...on the front, with the
threaded rod end bearing on it, and a larger diameter tube...didn't
measure it...on the rear. The rear tube is flat on both ends, and the
front tube intersects it at an angle, and is welded to it, near where
it attaches to the fuselage tab.
I can't speak to what Skystar had in mind sending you four tubes,
unless like Dave G. said, that you are to put one brace above the tab
and one below.
Lynn Matteson
flying w/475+ hrs
Mike Chaney
Lynn Matteson
flying w/470+ hrs
N369LM |
Lynn Matteson
Posted: Mon Feb 18, 2008 9:50 am Post subject: horizontal stabilizer |
Nice picture, Tom...it looks like you had to lower your horizontal
stab, eh? (I've got the same "extra" holes in my fairing too.) : )
Lynn Matteson
flying w/475+ hrs
> and touch the tab.
> Any suggestions?
bottom strut goes on the bottom of the fuselage tab. Mine do not
washers.
Tom Jones
Classic IV, Phase one
Ellensburg, WA
http://forums.matronics.com/viewtopic.php?p=164636#164636
http://forums.matronics.com//files/horizontal_stab_strut_160.jpg
N369LM |
l.morris(at)tx.rr.com Guest
Posted: Mon Feb 18, 2008 10:40 am Post subject: horizontal stabilizer |
You may have a defective strut that happened in the manufacturing process. I had one that was too short. Called the factory and they sent me a replacement. My struts are installed one above and one below the tab.---Leon Morris/Classic 4 (94)/60%/Flower Mound,TX
Tom Jones
Posted: Mon Feb 18, 2008 12:08 pm Post subject: Re: horizontal stabilizer |
For anyone that might be wondering about the modified Horizontal stab lift struts. I should correct my earlier post about them. I actually know of at least three versions. My Kit was delivered in 1994 with the one piece V struts with 3/16 threaded rod on the front outboard end. Skystar soon produced the first mod which was the two piece with 3/16 threaded rod on both outboard ends. Later they suggested going to their third version which is the two piece with 1/4 threaded rod on both outboard ends.
For what its worth there were a few builders that had the 3/16 rod ends break. I think all were noticed during preflight and don't know of any that were confirmed to happen in flight. At least two were found when preflighting to leave a fly in. My opinion is someone lifted the airplane by the horizontal stab and broke it or someone even sat on it at the fly in.
Quote: | it looks like you had to lower your horizontal
stab, eh? (I've got the same "extra" holes in my fairing too.) : ) |
Lynn, yes I started flight testing with the front bolt of the horizontal stab in the top hole. I was flying with the CG near the foreword limit and it took just a slight one finger back pressure on the stick to fly level. I couldn't trim nose up because pulling a little flaperon trims the nose down.
I then moved the front bolt of the Horizontal stab to the middle hole. Now It flys level hands off with the CG near the foreward limit and I can trim nose down with the flaperons as the CG moves back to fly hands off. It doesn't take much down flaperon trim and I can't see hardly any reduction in air speed.
I didn't want to add on a different pitch trim system. My Kitfox is very basic and I like it that way. The only electrical accessory is the starter and I often think about eliminating that.
Classic IV
Ellensburg, WA |
clint_bazzill(at)hotmail. Guest
Posted: Mon Feb 18, 2008 12:14 pm Post subject: horizontal stabilizer |
If you decide to change out the rod end, it makes little sense to put another rod of larger size in its place. Just add a flattend tube as all the adjustments that you needed for first flights etc are finshed. Clint
[quote] From: lynnmatt(at)jps.net
Subject: Re: horizontal stabilizer
Date: Mon, 18 Feb 2008 12:43:48 -0500
--> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net>
Mike-
threaded rod end bearing on it, and a larger diameter tube..didn't
and one below.
Lynn Matteson
flying w/475+ hrs
> Lynn
> Mike Chaney
> Lynn Matteson
> Kitfox IV Speedster w/Jabiru 2200
> flying w/470+ hrs
pwmac(at)sisna.com Guest
Posted: Mon Feb 18, 2008 2:42 pm Post subject: horizontal stabilizer |
Its NOT ok to weld a socket head cap screw the thing will become
brittle and would be subject to easy fracture with a little
vibration. They should all be replaced with the AN490 insert and the
appropriate rod end. Plenty of tube length when carefully measured, a
Simple fix. It is my belief that a stronger tube (thicker wall
thickness) is not required.
Be sure to switch from #10 threads to 1/4" threads.
Paul
Lynn Matteson
flying w/475+ hrs
Posted: Mon Feb 18, 2008 3:04 pm Post subject: horizontal stabilizer |
Thanks to everyone who responded to my problem with the horizontal stabilizer struts. I went back to the hanger today and decided that I could make it work if I did sandwich the fuseledge tab and a thin spacer between the two struts. The struts were too long so I had to cut off about 1/8 to 3/16 inch off the length of the struts at the flatened area where it attaches to the fuseledge.
Mike Chaney
Clint Bazzill <clint_bazzill(at)hotmail.com> wrote:
[quote] .hmmessage P { margin:0px; padding:0px } body.hmmessage { FONT-SIZE: 10pt; FONT-FAMILY:Tahoma } If you decide to change out the rod end, it makes little sense to put another rod of larger size in its place. Just add a flattend tube as all the adjustments that you needed for first flights etc are finshed. Clint
Mike-
and one below.
Lynn Matteson
flying w/475+ hrs
> Lynn
> Mike Chaney
> Lynn Matteson
> flying w/470+ hrs
> www.matronics.com/Navigator?Kitfox-List _- Be a better friend, newshound, and [quote][b]
Lynn Matteson
Posted: Mon Feb 18, 2008 6:32 pm Post subject: horizontal stabilizer |
If they were too long, I'd check and see if the hort. stab is
straight and level, and not drooping. If it is, it will make the
elevator hard to work, as the hinge line will be curved instead of a
straight line.
Lynn Matteson
flying w/475+ hrs
On Feb 18, 2008, at 5:59 PM, Mike Chaney wrote:
Quote: | Thanks to everyone who responded to my problem with the horizontal
Mike Chaney
are finshed. Clint
> To: kitfox-list(at)matronics.com
> Mike-
use
Spruce
the
struts,
into
connection.
the
where
tab
> and one below.
> Lynn Matteson
> flying w/475+ hrs
> > Lynn
> > Mike Chaney
From
tubes. My
> > Lynn Matteson
> > flying w/470+ hrs
> > www.matronics.com/Navigator?Kitfox-List _-Be a better friend,
newshound, and_-
============================================================ _-
http://www.matronics.com/Navigator?Kitfox-List_-
forums.matronics.com_-
contribution_-
N369LM |
