jb92563
Joined: 23 Mar 2007 Posts: 314 Location: Southern California
Posted: Fri Feb 08, 2008 11:40 am Post subject: Good light 4 stroke Alternative for Kolbs |
This looks like a good engine alternative for Kolbs.
-4 Stroke
-Weight 100 lbs
-55-65 Hp at 4200-4900 rpm
-Turbo Charged option(65hp)
-Fuel Injection
-CDI Ignition
-Dual Spark plugs per cylinder
-Cheap $6,900
-Availability & Parts in USA, Henderson NV.
-Dry Sump design
http://www.aerotwinmotors.com/newpages/features.htm
_________________ Ray
Moni MotorGlider
Schreder HP-11 Glider
Grob 109 Motorglider
Do Not Archive |
jindoguy(at)gmail.com Guest
Posted: Fri Feb 08, 2008 12:20 pm Post subject: Good light 4 stroke Alternative for Kolbs |
Ray, Did you want to put a link with this or do I have to get out my Oiuja Board?
Okay the board says it's the Hexadyne. Must have been run out of Utah.
Rick
On Feb 8, 2008 1:40 PM, jb92563 <jb92563(at)yahoo.com (jb92563(at)yahoo.com)> wrote:
[quote]--> Kolb-List message posted by: "jb92563" <jb92563(at)yahoo.com (jb92563(at)yahoo.com)>
-4 Stroke
-Weight 100 lbs
-Fuel Injection
-CDI Ignition
-Cheap $6,900
-Dry Sump design
Ray
Moni MotorGlider
Riverside County, CA
http://forums.matronics.com/viewtopic.php?p=163044#163044
bartmo(at)sbcglobal.net Guest
Posted: Fri Feb 08, 2008 3:27 pm Post subject: Good light 4 stroke Alternative for Kolbs |
Sounds like the Aero-Twin engine. $6900 is the price for 50 HP non turbo engine. By the time you add for the re-drive, exhaust, oil tank, oil cooler, etc you are close to $10000.
Bart
-4 Stroke
-Weight 100 lbs
-Fuel Injection
-CDI Ignition
-Cheap $6,900
-Dry Sump design
Ray
Moni MotorGlider
Read this topic online [quote][b]
Dana
Posted: Fri Feb 08, 2008 5:45 pm Post subject: Good light 4 stroke Alternative for Kolbs |
At 02:40 PM 2/8/2008, jb92563 wrote:
-4 Stroke
-Weight 100 lbs
-55-65 Hp...
And the engine is???
-Dana
Artificial intelligence usually beats real stupidity.
JetPilot
Posted: Sat Feb 09, 2008 12:44 pm Post subject: Re: Good light 4 stroke Alternative for Kolbs |
The HKS 4 stroke engine looks like much better design, more refined, and advanced engine for basically the same price... HKS has been around for a while now, and looks like a stable, growing company...
Without parts, your engine is a pile of metal, why would anyone risk an off brand engine, with less development and reliability, when a proven engine like the HKS is available at the same price ???
Mike
Kolb MK-III Xtra, 912-S |
The BaronVonEvil
Joined: 23 Jun 2006 Posts: 76 Location: Walla Walla, WA.
Posted: Sat Feb 09, 2008 1:23 pm Post subject: Re: Good light 4 stroke Alternative for Kolbs |
Hi All,
Is there anyone in our group that can stop by Henderson NV and take a look at this engine up close and get pictures to post here? It would be good if there was bit more info regarding this engine besides what the manufacturer's web page.
As far as engines go it would be nice to have some more four stroke alternatives out there. Yes HKS has been around for awhile but even they were new at one time. I imagine the same things being said about them regarding if they are going to be around or if they are just another flash in the pan.
If BRP /Rotax would get off their duff and offer the ETEC fuel injection system on their a/c engine line I think it would greatly improve its reliability. I just doubt that this will ever happen.
Best Regards
Carlos G
Posted: Sat Feb 09, 2008 3:01 pm Post subject: Good light 4 stroke Alternative for Kolbs |
Ray
I never did hear what engine you were talking about. Do you have a web site,
name or anything?
Rick Neilsen
Redrive VW powered MKIIIC
HShack(at)aol.com Guest
Posted: Sat Feb 09, 2008 7:32 pm Post subject: Good light 4 stroke Alternative for Kolbs |
Too much plumbing would be necessary for the average guy.
Howard Shackleford
FS II
SC
In a message dated 2/9/2008 4:26:52 P.M. Eastern Standard Time, grageda(at)innw.net writes:
| Quote: | If BRP /Rotax would get off their duff and offer the ETEC fuel injection system on their a/c engine line I think it would greatly improve its reliability. I just doubt that this will ever happen.
Who's never won? Biggest Grammy Award surprises of all time on AOL Music.
Posted: Sun Feb 10, 2008 10:50 am Post subject: Good light 4 stroke Alternative for Kolbs |
This is not the Hexadyne P-60, but the Aero-twin.
On paper, the P-60 looks good, but it is a radial mounted engine instead of bed mounted.
The Aero-twin looks REALLY good, but that $10k price [w/ all the necessary goodies] for an un-tried engine [at least on a Kolb] is a bit much.
If I's rich I'd get an HKS. Looks like I'll just de-carb the old trusty 503................................
Howard Shackleford
FS II
SC
| Quote: | This looks like a good engine alternative for Kolbs.
-4 Stroke
-Weight 100 lbs
-Fuel Injection
-CDI Ignition
-Cheap $6,900
-Dry Sump design
JetPilot
Posted: Sun Feb 10, 2008 10:52 am Post subject: Re: Good light 4 stroke Alternative for Kolbs |
| The BaronVonEvil wrote: | Hi All,
Best Regards
Carlos G |
Not true, it is not at all the same situation. When the HKS came out, there was no good, reliable, light aircraft designed 4 stroke 2 cylinder engine available on the market that was suitable for very light aircraft, at that time trying something new made sense. Also the HKS design is very good for reliability and aircraft use, NOT so with the Aero Twin.
Now, the HKS is available, proven reliable, and in use on many types of aircraft for the same price as the new engine... So why be the test case with an inferior engine, when the reliable, proven HKS is available at the same price ? If you took the time to look at the manufacturers website, there are plenty of pictures of the engine from many angles. Given what I see of the pictures, the design of the Aero Twin is inferior to the HKS, I would not want one, to many mistakes and compromises in their basic design to make it a good airplane motor.
Mike
lucien
Posted: Sun Feb 10, 2008 7:07 pm Post subject: Re: Good light 4 stroke Alternative for Kolbs |
| JetPilot wrote: |
Mike |
It also appears as if the Oleniks are working on a mount for it for the Kolb, as there's a slingshot with an HKS on it for sale by them on barnstormers.
The Oleniks are smart guys and do good work, so I'm sure they're going to come up with a reliable mount.
The HKS looks like the best contender for that gap between the 503 and the 912 which is currently occupied by the 582 and some other 2-strokes. The clever thing they did with the HKS is made the operating RPM's and gearbox ratios very similar to the 582 and its gearboxes. So you're not in totally unknown territory when it comes to prop selection and operating rpm etc.....
I still think it's a bit heavy for something like the FS II, though it does seem to work. It looks tailor-made for something like the Slingshot tho....
LS
_________________ LS
Titan II SS |
