rhdudley1(at)bellsouth.ne Guest
Posted: Sun Jan 27, 2008 1:55 pm Post subject: Carpet Security |
Listers,
On my RV-6A forward floor I have sound insulation between the fore and
aft angles. It is the thickness of one side of the angles. So the
surface of the insulation is flush with the edges of the angles. Over
the insulation I have placed carpeting with a foam back. So far, I have
used common double-stick carpet tape to hold the carpet in place. It has
been minimally successful in keeping the carpeting from moving under my
feet and the passenger's feet. After a few flights, I find that the
carpeting slid a few inches and has buckled under my feet.
My question is: have you found other means of keeping carpeting in place?
Thanks in advance.
Richard Dudley
| - The Matronics RV-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
n616tb(at)btsapps.com Guest
Posted: Sun Jan 27, 2008 3:19 pm Post subject: Carpet Security |
Hi Richard,
I have installed my carpet and insulation exactly the same as you. I have
had the same problem and used a little contact cement around the edges. My
last flight I had a passenger that had wrestles legs and he managed to get
it all loose and waded up on that side again. I think a bit more contact
cement will go on unless someone else comes up with something from your
post.
[quote] --
eddyfernan(at)aol.com Guest
Posted: Sun Jan 27, 2008 4:09 pm Post subject: Carpet Security |
I had the same problem in my 9A and nothing would hold long term. I ended up "pop riveting" (the horror) a couple of small pieces of 1/8" angles at the aft end of the floor angles each with a nut plate for a #8 screw. Then I put the carpet back on and placed a #8 screw with a larger diameter washer through the carpet and into the nut plate. No more buckled up carpet in the last year. Hope that helps.
Eddy Fernandez
RV9A
210 hrs
Mark Phillips in TN
Joined: 10 Jan 2006 Posts: 431 Location: Columbia, TN
capsteve
Joined: 09 Jan 2006 Posts: 111 Location: NIAGARA FALLS NY
Posted: Sun Jan 27, 2008 8:18 pm Post subject: Carpet Security |
a great way to secure carpets but keep them removable is to install snaps in
the corners. in the picture, #1845 would be riveted to the floor and
1825 and 1830 get squeezed to the carpet. very common in the marine world,
the press and snap tool costs about 95$ so you might just visit a local
canvas expert. the hardware is very inexpensive (stainless).
Steven dinieri
capsteve(at)adelphia.net
Iflyrv10.com
[quote] --
Description: |
Filesize: |
10.4 KB |
Viewed: |
664 Time(s) |
![image_resize[1].jpg](files/thumbs/t_image_resize_1__888.jpg)
sam95037(at)yahoo.com Guest
Posted: Mon Jan 28, 2008 9:15 am Post subject: Carpet Security |
Steve
Any recommendations on where to get 1845, 1825, 1830
online?
Sam
80262
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
rv9jim(at)juno.com Guest
Posted: Mon Jan 28, 2008 9:38 am Post subject: Carpet Security |
Richard,
I thought that Van's had a web site where someone had solved that
problem. I believe that it was glued down. The bottom of the carpet was
covered with contact glue and allowed to dry and then glued down with a
second layer of glue that is allowed to almost dry. The contact cement
provided the attachment to the aluminum floor and having the glue put on
the backing of the carpet made sure that the joint would be very tough.
Jim Nelson
dwntzl(at)yahoo.com Guest
Posted: Mon Jan 28, 2008 10:24 am Post subject: Carpet Security |
Hello
I also used foam for insulation (heat and noise) but decided rather than carpet to install an aluminum floor over it. R & L half cut to fit - .016 Alum (McMaster Carr), 4 screws each side, lightweight, doesn't shift, easy to keep clean.
David Wentzell, Port St. Joe, FL
RV6 - 233DW - 280 hrs.
Painless
Joined: 10 Jan 2006 Posts: 40 Location: Peshtigo, Wisconsin
Posted: Mon Jan 28, 2008 10:26 am Post subject: Carpet Security |
This is a timely thread, as I too have been dealing with my carpeting
getting all bunched up. I submit the following as a possible fix that I
wanted to bounce off the list....
I have used (as many others have) Flightline interior's kit, which included
a very stiff, durable styrofoam for insulating the floor. It is thick
enough to be flush with with foor stiffeners, and the carpet is then laid
over it. Mine is held in place just by the snug fit the separate pieces
have between the floor stiffeners.
I suggest that a channel of aluminum is made or pruchased to fit the
thickness of that foam. Then rivet that to the underside of the carpet at
the edge which goes up against the wing spar and positioned between where
the floor stiffeners are. This could be done by several pop rivets with
washers on the carpet side, or a strip of aluminum can be used to sandwich
the carpet between it and the aluminum channel.
Get the carpet in postion fore, aft, side to side, and then lift the pack
edge of the foam up from between the stiffeners to expose its aft edge.
Insert the aft edge of the foam into the channel and then press the whole
works back down between the stiffeners.
This should keep the carpet from shifting forward, which is the only
direction that mine wants to move. The foam shouldn't buckle up by the
force on its back edge, because your feet will still be pressing down on it
as well. This is all relative to getting in and out.
You can then use carpet tape or even velcro on the forward edge and the
sides.
How does this sound, folks? I'd appreciate any comments, refinements.
Jeff Orear
RV6A N782P
Peshtigo, WI
_________________ Jeff Orear
RV6A N782P
Peshtigo, WI |
Posted: Mon Jan 28, 2008 4:35 pm Post subject: Carpet Security |
Thanks to all who responded so far with a great variety of 9 approaches.
I believe that I will try the Velcro approach next. It appears the
easiest for me to me to try now while I have things apart for my annual.
If that works for me I'll stop there. If not, I'll try one of the others
that requires some more drilling and riveting.
Best regards,
Richard Dudley
stevea(at)svpal.org Guest
Posted: Mon Jan 28, 2008 6:01 pm Post subject: Carpet Security |
Sam,
No idea....I haven't looked for them. They may be available at a local
fabric store.
Steve
bobbyhester(at)newwavecom Guest
Posted: Mon Jan 28, 2008 6:25 pm Post subject: Carpet Security |
I have Classic Aero's carpet, it has thick sound proofing foam glued to
the back and it is slotted to fit between the angles. It comes with
velcro but I didn't use it.
It stays in place pretty good since the thick foam is glued to it, it
keeps it from bunching up.
http://www.classicaerodesigns.com/
Surfing the web from Hopkinsville, KY
Visit my flying RV7A web page:
http://home.newwavecomm.net/bobbyhester/MyFlyingRV7A.htm
others that requires some more drilling and riveting.
Best regards,
Richard Dudley
capsteve
Posted: Mon Jan 28, 2008 6:35 pm Post subject: Carpet Security |
try
http://www.atrim.com/Page106.html
there is a snap kit #K22920--$6.95 EA that installs the snaps onto the
carpet.
if you can find somehow to install the snaps on the carpet i will give you
the rest of the stuff to do it..
Steven dinieri
Iflyrv10.com
[quote] --
HCRV6(at)comcast.net Guest
Posted: Mon Feb 04, 2008 6:58 pm Post subject: Carpet Security |
Re Velcro, a word of caution. If you use the self stick kind you can expect it to start shifting and slipping around before long and making a real mess, I'm sure you can guess how I know. Get the Velcro that doesn't have an adhesive backing and glue it down to stay with a good quality, like 3M, contact cement.
Harry Crosby
RV-6 N16CX, flying - 432 hours
-------------- Original message ----------------------
Best regards,
Richard Dudley
Vanremog(at)aol.com Guest
Posted: Mon Feb 04, 2008 8:03 pm Post subject: Carpet Security |
In a message dated 2/4/2008 7:00:33 P.M. Pacific Standard Time, HCRV6(at)comcast.net writes:
Quote: | Re Velcro, a word of caution. If you use the self stick kind you can expect it to start shifting and slipping around before long and making a real mess, I'm sure you can guess how I know. Get the Velcro that doesn't have an adhesive backing and glue it down to stay with a good quality, like 3M, contact cement. |
Or Gorilla Glue.
N1GV (RV-6A, Flying 883hrs, O-360-A1A, C/S, Silicon Valley)
Who's never won? Biggest Grammy Award surprises of all time on AOL Music.
Posted: Tue Feb 05, 2008 5:54 am Post subject: Carpet Security |
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Vanremog(at)aol.com
Sent: Monday, February 04, 2008 9:59 PM
To: rv-list(at)matronics.com
Subject: Re: Carpet Security
Or Gorilla Glue.
[Tim]
Yikes!! What out for that stuff it foams and multiplies in quantity by as much as three times. If you use this, be warned.
emrath(at)comcast.net Guest
Posted: Tue Feb 05, 2008 5:54 pm Post subject: Carpet Security |
I seem to recall that Bob Nuckolls of Aeroelectric-list recommends heating
the self sticking side of Velcro prior to attaching and you will have a
horible time getting it off later if needed!
Marty
Time: 08:03:46 PM PST US
expect
mess,
contact
cement.
Or Gorilla Glue.
Marty ҿӬ
