jb92563
Joined: 23 Mar 2007 Posts: 314 Location: Southern California
Dana
Posted: Mon Feb 04, 2008 3:05 pm Post subject: Ultrastar Update |
At 05:31 PM 2/4/2008, jb92563 wrote:
| Quote: | Ran it at full throttle for a few minutes and observed about 1425 EGT and
420 CHT. Not sure what normal would be....any ideas?
Max CHT should be 400°F
Max EGT should be 1275°F
Best power EGT is 1200°F
The EGT probe is supposed to be 1½" from the manifold flange gasket. You
really only need gauges in the #1 (rear) cylinder (unless you're running
dual carbs) as that one runs hotter. Mine is located farther away, where
the two pipes join, and reads higher... but the CHT is lower, the engine
runs OK and the plugs look fine so I tend to distrust the gauge.
-Dana
To Be Old And Wise You Must First Be Young And Stupid
jb92563
Posted: Mon Feb 04, 2008 4:25 pm Post subject: Re: Ultrastar Update |
I better try that again and double check the numbers as mine seem high, but I was recalling them from what I remembered a couple days ago so perhaps I remembered them wrong.
Are those numbers the Max from Cuyuna manual, or from your own engine?
I guess looking at the plugs should give an idea to what is happening as well.
I wonder if a couple minutes running is enough to get an indication on the plugs?
I have a single carb setup....still need to add a KFN filter.
EGT probe is just before the Y junction on the rear cylinder exhaust.
CHT is on the rear cylinder as well
_________________ Ray
Moni MotorGlider
Schreder HP-11 Glider
Grob 109 Motorglider
Do Not Archive |
Dana
Posted: Tue Feb 05, 2008 4:13 am Post subject: Ultrastar Update |
At 07:25 PM 2/4/2008, jb92563 wrote:
| Quote: | Are those numbers the Max from Cuyuna manual, or from your own engine?
plugs?
Ray, the numbers I gave are from the Cuyuna manual. I don't know how much
running time is necessary to read the plugs, but it can't hurt to have a
look. Also check what main jet is in your carb, and where the needle is;
you might need to go bigger and/or move the needle clip down.
-Dana
"Very funny, Scotty. Now beam down my clothes."
jb92563
Posted: Tue Feb 05, 2008 7:37 am Post subject: Re: Ultrastar Update |
Sounds like I am running to lean if those numbers are right.
Not sure how to tune it for richer, would the needle clip go in the next lower notch to make it more rich?
Or do I change needles to make it richer.....lower needle number is richer?
I'll take a look and see what needle number I am running tonight.
Dana, what needle number are you running?
Are you using a filter on your carb?
Moni MotorGlider
Do Not Archive |
Posted: Tue Feb 05, 2008 8:04 am Post subject: Ultrastar Update |
Ray:
Are you running the correct prop pitch?
Two stroke tuning in an airplane is based on correct prop loading as the
number one item. If it is incorrect, everything on down the line, jets,
needles, and plugs, with also be incorrect.
I find the best way to get an unknown engine back in line is put everything
in the carb back where it belongs, and insure jetting and needles are
correct size.
Also insure the spark plug is the correct heat range.
Insure the correct prop and pitch is installed. For a Cuyuna ULII02, I
believe that would have been a Jim Culver 50X30. That was a perfect prop
for the US with ULII02.
Hope you all are operating those engines with air filters.
_________________ John Hauck
Titus, Alabama |
herbgh(at)nctc.com Guest
Posted: Tue Feb 05, 2008 2:39 pm Post subject: Ultrastar Update |
I seem to recall that the Ul202 engine was succeptible to case
leaks..Needed re torqueing once in a while.. A very old engine model
at any rate..15 years old or older? Herb
At 09:37 AM 2/5/2008, you wrote:
Ray
Moni MotorGlider
Riverside County, CA
http://forums.matronics.com/viewtopic.php?p=162522#162522
Posted: Tue Feb 05, 2008 2:53 pm Post subject: Ultrastar Update |
| Quote: | leaks..Needed re torqueing once in a while.. A very old engine model at
Herb:
The ULII02 was a good engine. Had CDI ign, which was much easier to
maintain than the point ign Rotax's.
If one did not retorque the cylinders every 100 hours or more, they were
prone to leak at the cylinder base gasket. This was probably caused by the
small amount of metal that remained after the engine cases were lightened
from the 430 to the ULII02. In an US the engine had to be dropped from the
engine mount to get at the bolts to torque them. Because of the extra work
involved, most of us would fly them until they started leaking, then end up
replacing cyl base gaskets and head gaskets.
Never had any big problems with the ULII02, but was plagued with little ones
that were annoying and would occasionally put one on the ground. It was all
a big learning curve, getting out of turbine powered helicopters that had
lots of folks and lots of money available for parts and repairs, into a
little two stroke that had to be maintained by a guy anxious to fly more
than anxious to spend all time on the ground fixing stuff.
Titus, Alabama |
Posted: Tue Feb 05, 2008 3:32 pm Post subject: Ultrastar Update |
Yeah! I am old and good also...
I had a UL202 on the US that I had... Very surprised at the ease
of starting.. Nearly fell backward, expecting to have to pull and
pull and pull .. Started just about the time I pulled the rope a foot
or so.. Ran strong. Herb
At 04:50 PM 2/5/2008, you wrote:
>model at any rate..15 years old or older? Herb
Herb:
were prone to leak at the cylinder base gasket. This was probably
caused by the small amount of metal that remained after the engine
cases were lightened from the 430 to the ULII02. In an US the
engine had to be dropped from the engine mount to get at the bolts
to torque them. Because of the extra work involved, most of us
would fly them until they started leaking, then end up replacing cyl
little ones that were annoying and would occasionally put one on the
ground. It was all a big learning curve, getting out of turbine
powered helicopters that had lots of folks and lots of money
available for parts and repairs, into a little two stroke that had
to be maintained by a guy anxious to fly more than anxious to spend
Dana
Posted: Tue Feb 05, 2008 3:51 pm Post subject: Ultrastar Update |
At 10:37 AM 2/5/2008, jb92563 wrote:
| Quote: | Sounds like I am running to lean if those numbers are right.
Are you using a filter on your carb? |
Ray, yes, it sounds like it's lean. Moving the needle clip down makes the needle go up, which makes it richer... but only in the midrange. I don't know what needle number I have; I don't think many people change them. Full throttle mixture is controlled by the main jet, which _does_ need to be changed according to the seasons or altitude:
ULII-02, Cuyuna exhaust, Mikuni VM32 carburetor
Altitude
8000 250 240 230 220 210
6000 270 260 250 240 230
4000 290 280 270 260 250
2000 310 300 290 280 270
Sea Level 330 320 310 300 290
Temp. °F 0-20° 20-40° 40-60° 60-80° 80-100°
Mine had a 300 main jet, which I changed to a 310 for winter flying (below 40° and it's too cold to fly!). On a couple of hot days last summer, I stuck with the 300 jet (all I had at the time) but I had the needle clip in the top notch.
-Dana
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government. - Thomas Jefferson [quote][b]
jb92563
Posted: Tue Feb 05, 2008 10:05 pm Post subject: Re: Ultrastar Update |
Good info folk I appreciate all the great feedback.
I'm going to save all that info and check it all out.
I also love the easy starting of the UL-202....a short pull is all it takes once its primed.
In the meantime, here are some pics.
1.24 MB |
578 Time(s) |
1.27 MB |
552 Time(s) |
1.28 MB |
565 Time(s) |
Moni MotorGlider
Do Not Archive |
Posted: Wed Feb 06, 2008 6:08 am Post subject: Ultrastar Update |
At 10:05 PM 2/5/08 -0800, you wrote:
Ray,
Looks like your Ultrastar has negative dihedral.
Should make it a fun aircraft to fly.
Jack B. Hart FF004
Winchester, IN
jb92563
Posted: Wed Feb 06, 2008 7:25 am Post subject: Re: Ultrastar Update |
I'll double check the dihedral with my laser level once I get the proper bolts, but if there is any, its probably because I used undersized temporary non AN bolts to assemble so I could take an inventory of what I needed to buy.
Thats what resulted in a slight negative dihedral.
Same thing on the elevator hookup as they were noticeably mis-aligned with my temporary undersized bolts.
Actually, having a slight bit of negative dihedral is not a bad thing, just makes the aircraft more neutrally stable in the roll axis......makes turning more effortless as it will resist rolling out better....no big deal really, and it helps considerably in crosswinds to resist weather-vaning.
Funny thing is that every aircraft I have owned have some V in them as I have a owned 4 V-tails so far, perhaps the Ultrastar is feeling left out and trying to conform as well
Moni MotorGlider
Do Not Archive |
GeoR38
Joined: 25 Jan 2006 Posts: 60 Location: The Villages, fl
