ron.mcgann(at)baesystems. Guest
Posted: Sun Feb 03, 2008 3:14 pm Post subject: Slick Mags |
Anybody have any technical data for the Slick mags included with 540 supplied by Vans? I am installing a Slick Start and the lack of data on the mags is a PITA.
TIA
Ron
187 [quote]"Warning:
The information contained in this email and any attached files is
confidential to BAE Systems Australia. If you are not the intended
recipient, any use, disclosure or copying of this email or any
attachments is expressly prohibited. If you have received this email
in error, please notify us immediately. VIRUS: Every care has been
taken to ensure this email and its attachments are virus free,
however, any loss or damage incurred in using this email is not the
sender's responsibility. It is your responsibility to ensure virus
checks are completed before installing any data sent in this email to
your computer."
AV8ORJWC
Posted: Sun Feb 03, 2008 9:43 pm Post subject: Slick Mags |
Which model do you want information on?
John Cox
600
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of McGANN, Ron
Sent: Sunday, February 03, 2008 3:10 PM
Subject: Slick Mags
TIA
Ron
187 [quote]"Warning:The information contained in this email and any attached files isconfidential to BAE Systems Australia. If you are not the intendedrecipient, any use, disclosure or copying of this email or anyattachments is expressly prohibited. If you have received this emailin error, please notify us immediately. VIRUS: Every care has beentaken to ensure this email and its attachments are virus free,however, any loss or damage incurred in using this email is not thesender's responsibility. It is your responsibility to ensure viruschecks are completed before installing any data sent in this email toyour computer." [b]
taildragon(at)msn.com Guest
Posted: Mon Feb 04, 2008 9:17 am Post subject: Slick Mags |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Hi Ron,
I’ve been working this subject, also, and have gathered and crunched data from a number of sources to find what we need. The best data came from OC Baker on the AeroElectric-List. The Slick Service Letter SL2-96 that comes with the SlickStart mostly addresses replacement of existing ignition vibrators, not a fresh new installation. One of the concerns not clearly addressed in SL2-96 is how to ground out the right mag out while cranking the engine to ensure that the right mag does not fire at twenty some degrees before top dead center (TDC) and create a kick back. Apparently, the grounding out can be accomplished either by the way the starting switch wiring is connected or by the way the SkickStart is connected to accomplish the needed grounding.
Lets set the stage: I am using the keyed start switch, IO-540D4A5, SlickStart (SS1001), electrical and FWF kits, all from Van’s. The IO-540 came with a retard breaker Slick mag on the left and a non retard breaker Slick mag on the right. The retard terminal is labeled on the left mag. No impulse coupler is on either mag.
Per SL2-96, SlickStart Pin VIN is the electrical supply into the unit and is connected to the output side of the starter solenoid through a 5 amp fuse to this pin. Then whenever you are feeding electricity to the starter you are also feeding the SlickStart. SlickStart Pin GND is connected to the grounding screw on the left mag (retard breaker magneto). SlickStart Pin 1 is connected to the P-lead terminal of the left mag. Pin 3 is connected to the left mag retard breaker terminal. According to OC Baker, the function of Pin 3 is to tell Pin 1 to fire only when the retard breaker points are open which will be near top dead center. This provides the retarded spark which is desired while the engine is cranking. So far, so good.
Now is where SL2-96 and Page OP37-13 of Van’s RV-10 Wiring Harness Manual become a little unclear. One of the configurations in SL2-96 says
SlickStart Pin 2 gets connected to the P-lead of the right mag (non-retard breaker magneto). OC Baker says that the purpose of Pin 2 is to ground out the right magneto so that it can not fire an advanced (twenty some degrees before TDC) spark while the engine is cranking. The diagram on Van’s Page OP37-13 implies there should be a jumper between the R terminal and GND terminal of the keyed start switch. And that this jumper causes the right mag to be grounded only while the keyed start switch is in the “start” position This seems to be redundant with SlickStart Pin 2 but it also seems that doing both would not be harmful. I need some help here
Well, that is what I have so far. I kick this out to the List for helpful review/critique/inputs/help/feedback. Please, no flames!
Roger Standley
N291RV (Reserved)
billderou(at)yahoo.com Guest
Posted: Mon Feb 04, 2008 11:23 am Post subject: Slick Mags |
Ron-
You have done your homework. This is exactly the setup I am using with both the Slickstart and the switch grounding the right mag. Only reason for the double grounding is a backfire can be very expensive and the cost is zero to add protection for a broken wire.
N939SB
Roger Standley <taildragon(at)msn.com> wrote:
[quote] <?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Hi Ron,
I’ve been working this subject, also, and have gathered and crunched data from a number of sources to find what we need. The best data came from OC Baker on the AeroElectric-List. The Slick Service Letter SL2-96 that comes with the SlickStart mostly addresses replacement of existing ignition vibrators, not a fresh new installation. One of the concerns not clearly addressed in SL2-96 is how to ground out the right mag out while cranking the engine to ensure that the right mag does not fire at twenty some degrees before top dead center (TDC) and create a kick back. Apparently, the grounding out can be accomplished either by the way the starting switch wiring is connected or by the way the SkickStart is connected to accomplish the needed grounding. <?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Roger Standley
N291RV (Reserved)
Posted: Mon Feb 04, 2008 11:43 am Post subject: Slick Mags |
Additional info re SlickStart:
I had noticed a lot of ringing on the Left magneto P-Lead and am blaming this on the SlickStart. My engine monitor picks up RPM from the P-Lead. When connected to the Left mag, once in a while I got strange RPM values. This was immediately fixed when I moved the pickup to the right mag.
This is not a reason to be cautious of the SlickStart as I believe the SlickStart and breaker retard mag is a great combination at a good price.
Roger Standley <taildragon(at)msn.com> wrote: [quote] <?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Hi Ron,
Roger Standley
N291RV (Reserved)
Posted: Mon Feb 04, 2008 1:36 pm Post subject: Slick Mags |
Thanks Roger, this is excellent input!
I have a Push button start and have wired the start circuitry such that the start button will only energise the starter/Slick start when the Right Mag is grounded. I also have a retard breaker on the left mag only. No impulse couplers on either mag. Funny, I thought an impulse coupler on the left mag was standard.
Seems my install will be quite straightforward.
thanks again
Ron
187
[quote] From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Roger Standley
Sent: Tuesday, 5 February 2008 3:43 AM
Subject: Re: Slick Mags
Roger Standley
N291RV (Reserved)
Hi John,
LHS Model 6393 (with retard breaker)
RHS Model 6350
cheers
Ron
| Quote: | From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John W. Cox
Sent: Monday, 4 February 2008 4:08 PM
Subject: RE: Slick Mags
John Cox
600
Subject: Slick Mags
TIA
Ron
187 | Quote: | | "Warning:The information contained in this email and any attached files isconfidential to BAE Systems Australia. If you are not the intendedrecipient, any use, disclosure or copying of this email or anyattachments is expressly prohibited. If you have received this emailin error, please notify us immediately. VIRUS: Every care has beentaken to ensure this email and its attachments are virus free,however, any loss or damage incurred in using this email is not thesender's responsibility. It is your responsibility to ensure viruschecks are completed before installing any data sent in this email toThe information contained in this email and any attached files is | 0 | Quote: | | The information contained in this email and any attached files is | 1 | Quote: | | The information contained in this email and any attached files is | 2 | Quote: | | The information contained in this email and any attached files is | 3 | Quote: | | The information contained in this email and any attached files is | 4 | Quote: | | The information contained in this email and any attached files is | 5 | Quote: | | The information contained in this email and any attached files is | 6 | Quote: | | The information contained in this email and any attached files is | 7 | Quote: | | The information contained in this email and any attached files is | 8 | Quote: | | The information contained in this email and any attached files is | 9 | Quote: | | confidential to BAE Systems Australia. If you are not the intended | 0 | Quote: | | confidential to BAE Systems Australia. If you are not the intended | 1 | Quote: | | confidential to BAE Systems Australia. If you are not the intended | 2 | Quote: | | confidential to BAE Systems Australia. If you are not the intended | 3 | Quote: | | confidential to BAE Systems Australia. If you are not the intended | 4 | Quote: | | confidential to BAE Systems Australia. If you are not the intended | 5 | Quote: | | confidential to BAE Systems Australia. If you are not the intended | 6 | Quote: | | confidential to BAE Systems Australia. If you are not the intended | 7 | Quote: | | confidential to BAE Systems Australia. If you are not the intended | 8 | Quote: | | confidential to BAE Systems Australia. If you are not the intended | 9 | Quote: | | recipient, any use, disclosure or copying of this email or any | 0 | Quote: | | recipient, any use, disclosure or copying of this email or any | 1
| Quote: | | recipient, any use, disclosure or copying of this email or any | 2 |
| Quote: | | recipient, any use, disclosure or copying of this email or any | 3 [quote][b]
Posted: Mon Feb 04, 2008 2:04 pm Post subject: Slick Mags |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Yes, Ron, I expected an impulse coupler on the left mag, too. When I discovered no impulse coupler, I ordered the SlickStart. I still don't know if having redundant right mag grounds is OK. I am leaning toward just using the jumper on the ignition switch and leaving SlickStart Pin 2 disconnected. Maybe someone else will chime in here and set us straight.
Roger
Posted: Mon Feb 04, 2008 3:53 pm Post subject: Slick Mags |
I have the same setup in N939SB and ran the grounding wire from the SlickStart to the right Mag P-lead and also grounded the right Mag P-lead during start switch activation. Since a backfire could be very expensive and the cost of running both wires is zero, I believed this was cheap insurance against a broken wire. No issues at 160 hours.
[quote] <?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Yes, Ron, I expected an impulse coupler on the left mag, too. When I discovered no impulse coupler, I ordered the SlickStart. I still don't know if having redundant right mag grounds is OK. I am leaning toward just using the jumper on the ignition switch and leaving SlickStart Pin 2 disconnected. Maybe someone else will chime in here and set us straight.
Roger
mckervey(at)edge.net Guest
Posted: Mon Feb 04, 2008 7:13 pm Post subject: Slick Mags |
Bill,
The new Slick-Start doesn't have a pin 2.
Joe
Posted: Mon Feb 04, 2008 9:26 pm Post subject: Slick Mags |
Joe-
I can't think of a design reason to drop pin 2 functionality except to limit their liability in lawsuits. I suppose that every kick-back lawsuit will automatically name Unison as a defendant and they can create uncertainity by blaming the right mag.
I looked for information on the new version with no joy.
Does anyone have a description of the changes between new/old?
Is the new version now being shipped?
Can anyone send a new wiring diagram?
mckervey <mckervey(at)edge.net> wrote:
[quote] Bill,
Joe
Posted: Tue Feb 05, 2008 8:55 am Post subject: Slick Mags |
[img]cid:002f01c86817$0d4596a0$27ae9804(at)josepheg3rzhs5[/img]
124.12 KB |
568 Time(s) |
