martin(at)buzzardaviation Guest
Posted: Sun Feb 03, 2008 3:06 am Post subject: Oil pressure problem + |
Hi all,
Just heard my partner flew the 18T last week and found the oil pressure gguage jumping between 3 and zero. I intend to go and check this next week but any ideas gratefully taken on board. I suspect it's a lead to the guage but certainly don't want to fly it until we have it sorted.
On another note, we have an issue with our altimeter. When trying to enter the pressure settings the subscale will sometimes lock at 990/1000/1010 Mb etc and requires a lot of jiggling to turn it through. Is there an easy fix?
TIA
[img]cid:part1.07060304.05020809(at)buzzardaviation.flyer.co.uk[/img]
8.72 KB |
6360 Time(s) |
JOE HOWSE
Joined: 10 Jan 2006 Posts: 140 Location: DUNCAN BC CANADA
Posted: Sun Feb 03, 2008 6:47 am Post subject: Oil pressure problem + |
Check the oil pressure regulator for foreign material.
Joe
8.72 KB |
6358 Time(s) |
_________________ J.C. HOWSE |
KingCJ6(at)aol.com Guest
Posted: Sun Feb 03, 2008 8:27 am Post subject: Oil pressure problem + |
In a message dated 2/3/2008 3:07:03 AM Pacific Standard Time, martin(at)buzzardaviation.flyer.co.uk writes:
| Quote: | Hi all,
Just heard my partner flew the 18T last week and found the oil pressure gguage jumping between 3 and zero. I intend to go and check this next week but any ideas gratefully taken on board. I suspect it's a lead to the guage but certainly don't want to fly it until we have it sorted. |
Had the same issue with the oil temp gauge in our CJ. Was a loose fitting cannon plug at the sending unit. Tight on the ground, but would vibrate in flight and caused the needle to swing. A tie strap fixed it until the annual.
Who's never won? Biggest Grammy Award surprises of all time on AOL Music.
napeone
Joined: 10 Jan 2006 Posts: 36 Location: Birmingham, Al.
Posted: Sun Feb 03, 2008 10:05 am Post subject: Re: Oil pressure problem + |
What was outside air temperature?
David H.
Posted: Mon Feb 04, 2008 2:12 am Post subject: Oil pressure problem + |
David H.
About 4C if I recall. Guy flew for over an hour but had the intermittent oil pressure for most of the flight!!
Ciao
Posted: Mon Feb 04, 2008 5:55 am Post subject: Oil pressure problem + |
Most likely it is the cannon plug connection. Doubt it is the transducer on
the firewall. In my experience when one of those quits, it quits.
Ask your friend if he likes the look at stalled props while in flight and
dead sticking? Last time I looked at the EP's for the loss of oil pressure,
they read land as soon as possible assuming his flight was over land.
Doc
