orchidman
Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
Posted: Thu Jan 31, 2008 1:08 pm Post subject: Alternator Circuit Breaker |
Examining other builders wiring diagrams, I am finding both fuses and circuit breakers for the alternator output protection.
I am leaning to a CB but would like some input as to where to place the 60A CB.
Possible options would be forward of the firewall, or under the dash to keep the wires as short as possible, or normally positioned on the instrument panel.
_________________ Gary Blankenbiller
RV10 - # 40674
(N2GB Flying) |
Tim Olson
Posted: Thu Jan 31, 2008 1:50 pm Post subject: Alternator Circuit Breaker |
I decided on mine to forego the Circuit Breaker and do the fuse thing.
The reason is a few fold...
First, I did indeed buy a breaker at one point, but it's a pretty
fat wire you put on a 60-70A breaker, and that fat wire was stiff, and
I heard something plastic internal to the breaker crack. This did
not leave me feeling very good. I decided that unless you're
going to have a solid way to mount a breaker, and hold the wire
totally imobile and prevent cracking, it would not be a good idea to
use that breaker. Also, it isn't that easy to find a good breaker
of that size, and at a good cost.
Then, you also have the big fat wire coming up to your panel or
subpanel, further into the cabin that it needs to be. On mine,
I did mount it inside the firewall, but on the firewall, but
there is no reason that I needed to put it there. It could have
just as easily gone in the engine compartment. I like where it
is, and it's worked out well though.
Also, on my plane, I draw in the low 40's for amps at full draw
with everything lit up and turned on, including pitot heat. If my
60A breaker blows, I really don't think it would be a good idea for
me to re-set it in flight. So, you may as well use a fuse, at that
point. I work on lots of electronic things, and I don't mind
tinkering, but in the air is probably not the place. I do carry
a spare fuse though, in my kit.
If you're really leaning towards a CB, then you may as well skip
the idea of putting it under the cowl. If you're willing to
go under the cowl to deal with it, you shouldn't have any
objection to staying simple and cheap and going with a fuse.
As far as design goes, I was happy with my ANL fuse, because not
only was it simple to mount and hook up, but it included a nice
clear plastic case and cover. So it's easy to see if it blows.
Of course, I haven't had the opportunity to see it blown yet.
Now, one other reason I don't care about re-setting a breaker
is because with a good backup battery system, I'd rather treat
the real unusual case of a blow B-lead breaker to be somewhat
of an emergency....and use the hour or more of battery that I
have left to get on the ground. If that thing blows, I've got
some problems somewhere, and being on the ground is a good
plan anyway until I can figure out what caused it.
orchidman wrote:
circuit breakers for the alternator output protection. I am leaning
instrument panel.
-------- Gary Blankenbiller RV10 - # 40674 Fuselage SB (N410GB
reserved)
http://forums.matronics.com/viewtopic.php?p=161652#161652
dlm46007(at)cox.net Guest
Posted: Thu Jan 31, 2008 2:45 pm Post subject: Alternator Circuit Breaker |
two 30 or 35s in parallel with a short copper bus bar between them. Easy
attach of the fat wire.
695.38 KB |
664 Time(s) |
Posted: Thu Jan 31, 2008 2:46 pm Post subject: Alternator Circuit Breaker |
I always put in a circuit breaker and I put it in a location that it
can be seen if it pops, which would mean on the panel or nearby.
Since you will likely have 8AWG wire going to and from it, it is
important to think about routing as you plan where to put it. That
size wire doesn't bent too easily, so there needs to be a little
clearance from other items in the direction that the wire leaves the
breaker. I as I have heard others argue in the past, when a cb pops,
it is often unlikely that just pushing it back in will solve the
problem, which is an argument for using fuses, but it is also nice to
have that visual alert that something has happened rather than just
see your voltage drop or your alternator failure light come on.
Just my $.02, which is probably worth less than 50% of that.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
On Jan 31, 2008, at 4:08 PM, orchidman wrote:
the 60A CB.
Gary Blankenbiller
RV10 - # 40674
Fuselage SB
(N410GB reserved)
carl.froehlich(at)cox.net Guest
Posted: Thu Jan 31, 2008 3:39 pm Post subject: Alternator Circuit Breaker |
Use a 70 amp breaker with a 60 amp alternator to avoid spurious trips. If
the breaker does trip it means there is a serious problem, something you
might not want to troubleshoot in flight by resetting the breaker. In my
RV-8A I mounted the breaker on the engine side of the firewall. This kept
all the heavy wiring on the engine side of the firewall except for one
penetration to the starter solenoid. I have a dual battery install with
separate right/left busses that support continued IFR flight without the
alternator.
Carl Froehlich
RV-8A (375 hrs)
RV-10 (wings)
wcurtis(at)nerv10.com Guest
Posted: Thu Jan 31, 2008 3:45 pm Post subject: Alternator Circuit Breaker |
Aircraft Spruce sells a 60-70 alternator circuit breaker (non pull-able) relatively inexpensively and is the standard of certified OEM manufacturers. They are also less expensive than an ANL and holder.
http://www.aircraftspruce.com/catalog/elpages/6070amp.php
http://www.aircraftspruce.com/catalog/graphics/6070circuitbreak.jpg
For 60-70 AMPs the wire from the alternator only needs to be #8 AWG (or #6). An #8AWG Tefzel wire is only 3/16" thick and easy to manage behind the panel attached to the circuit breaker. Alternator to breaker, breaker to buss.
William
http://wcurtis.nerv10.com/
"Be who you are and say what you feel because those who mind don't matter and those who matter don't mind."
-- Dr. Suess
orchidman
Posted: Thu Jan 31, 2008 4:01 pm Post subject: Re: Alternator Circuit Breaker |
| Tim Olson wrote: |
totally mobile and prevent cracking, it would not be a good idea to
of that size, and at a good cost. |
I have found a source for 60 & 70 amp CBs and yes they are very pricey but no fuseses that big was one of the primary reasons I have been thinking of going the CB route.
| Quote: | Then, you also have the big fat wire coming up to your panel or
is, and it's worked out well though. |
Passing 'big' wires through the firewall bothers me and the fewer possible makes me feel better. That is why I am considering possibly in front of the firewall.
| Quote: | Also, on my plane, I draw in the low 40's for amps at full draw
Of course, I haven't had the opportunity to see it blown yet. |
Do you have a good source for that big an ANL fuse? I have checked all my normal sources.
RV10 - # 40674
(N2GB Flying) |
Posted: Thu Jan 31, 2008 4:38 pm Post subject: Alternator Circuit Breaker |
If all the "heavy" wiring is on the engine side, how do you get the 60 amps from the alternator to the buss? That's rhetorical.
I think I know what you are saying because I see a lot of builders connect the output lead of the alternator to the battery side of the starter contactor thinking they are keeping the "heavy" wires out of the cockpit. You still need to run a "heavy" wire from the battery cable to the main buss. So unless you buss is also forward of the firewall, you still have "heavy" wires coming into the cabin.
Having a cable from the alternator to the bus (via breaker or fuse) and then a separate cable from the battery to the buss is normal practice for certified aircraft. Also, attaching the alternator lead to the battery side of the starter contactor MANDATES putting the alternator fuse or circuit breaker firewall forward.
William
-- Dr. Suess
seipel(at)seznam.cz Guest
Posted: Thu Jan 31, 2008 4:47 pm Post subject: Alternator Circuit Breaker |
Make sure you take a look at the data sheet for your breaker before you
decide to upsize the number of amps too much. For example, the 30 amp
Tyco breaker I'm using for my backup SD-20 alternator is rated such that
it may take up to 1 hour at 145% or 43 amps before it trips. At 200%,
i.e. 60 amps, it may still take up to 30 seconds to trip. If that
breaker trips, then my alternator is definitely overloaded and I'd sure
want to take a look at the problem before continuing on.
PJ Seipel
RV-10 #40032
alternator.
Carl Froehlich
RV-8A (375 hrs)
RV-10 (wings)
apilot2(at)gmail.com Guest
Posted: Thu Jan 31, 2008 4:52 pm Post subject: Alternator Circuit Breaker |
How many REALLY need 60 amps for their panel?? Just rhetorical question. I don't see any problem using a 50-55amp
CB on a 60 amp alternator. Alternators are normally sized so that they aren't called upon to produce more than 85 percent of their nominal rating. So using a 50 amp CB would ensure you don't exceed 85% by very much.
On Jan 31, 2008 5:40 PM, William Curtis <wcurtis(at)nerv10.com (wcurtis(at)nerv10.com)> wrote:
[quote] --> RV10-List message posted by: "William Curtis" <wcurtis(at)nerv10.com (wcurtis(at)nerv10.com)>
William
-- Dr. Suess
Posted: Thu Jan 31, 2008 5:33 pm Post subject: Alternator Circuit Breaker |
| Quote: | Passing 'big' wires through the firewall bothers me and the fewer possible makes me feel better. That is why I am considering possibly in front of the firewall.
In the RV-10 with a rear mounted battery, you have to pass at least ONE "big" wire through the firewall. Well ---correction, I don't have ANY "big" wires going throught my firewall. I only have an 8AWG wire from the alternator going through my firewall. Not even the main battery to starter contactor cable. I use a thru bulkhead connector show on the attached picture. On the firewall side is attached the starter contactor as shown. On the cabin side is attached the main battery cable and the (smaller) battery cable to the buss.
William
-- Dr. Suess
149.62 KB |
603 Time(s) |
Posted: Thu Jan 31, 2008 5:53 pm Post subject: Alternator Circuit Breaker |
You have a point if you assume a traditional power distribution scheme.
With dual electronic ignitions and an all electric panel, I opted for a more
reliable approach than that used in certified aircraft.
The issue of big wires through the firewall is really secondary.
Carl
orchidman
Posted: Thu Jan 31, 2008 6:17 pm Post subject: Re: Alternator Circuit Breaker |
[quote="wcurtis(at)nerv10.com"] | Quote: | | I use a thru bulkhead connector show on the attached picture. |
William,
Where did you source your connector?
RV10 - # 40674
(N2GB Flying) |
Tim Olson
Posted: Thu Jan 31, 2008 6:38 pm Post subject: Alternator Circuit Breaker |
That's exactly my reasoning on using a 60A fuse (despite my 70A
alternator). The fact is, if I find myself drawing 60A off
my alternator, something is not right at all. None of my
avionics or equipment can draw that much, so my battery or
wires are shorted or something. You don't size your fuse by
the alternator, you size it to the max load you care to see
before you blow. A 60A ANL fuse won't blow until well over
60A anyway, so if that baby blows, I sure as heck don't
want to push a reset button in flight and figure it out.
That fuse/breaker is a very big problem indicator.
PJ Seipel
RV-10 #40032
> <carl.froehlich(at)cox.net>
> trips. If
> kept
> alternator.
> Carl Froehlich
> RV-8A (375 hrs)
> RV-10 (wings)
Tim Olson
Posted: Thu Jan 31, 2008 6:43 pm Post subject: Alternator Circuit Breaker |
Just search for ANL online...they're all over in the card audio
type places. Nice ones, too, with gold plating and good
housings.
Yes, but the biggest, nastiest wire in your plane is the one
going from your battery forward. That battery can source hundreds
of amps, and it doesn't stop when the engine stops. People forget
that of the "big wires" they're worried about, some of those
are the biggest worry. Sooner or later you need to put that
power to the panel busses.....doesn't matter where it comes
in from.
All over online. Even Ebay.
| Quote: | -------- Gary Blankenbiller RV10 - # 40674 Fuselage SB (N410GB
reserved)
Posted: Thu Jan 31, 2008 7:21 pm Post subject: Alternator Circuit Breaker |
Don't forget that if you have to crank more than normal, or if
something has drawn your battery down a little, your alternator will
be charging your battery as well as powering everything in the plane,
which will take you over the current that you use continuously.
However, I agree that a 60A fuse on a 70A alternator is probably no
problem at all, and that if it blows in flight you probably won't want
to reset it, but (just thinking out loud) is it possible that the fuse
could blow and you not realize it, maybe thinking the alternator
itself is bad or the field circuit has failed? With a CB in sight
there is no question where the failure is.
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
> you decide to upsize the number of amps too much. For example, the
> 30 amp Tyco breaker I'm using for my backup SD-20 alternator is
> rated such that it may take up to 1 hour at 145% or 43 amps before
> it trips. At 200%, i.e. 60 amps, it may still take up to 30
> seconds to trip. If that breaker trips, then my alternator is
> definitely overloaded and I'd sure want to take a look at the
> PJ Seipel
> RV-10 #40032
>> trips. If
>> something you
>> breaker. In my
>> This kept
>> one
>> install with
>> without the
>> alternator.
>> Carl Froehlich
>> RV-8A (375 hrs)
>> RV-10 (wings)
Posted: Thu Jan 31, 2008 7:57 pm Post subject: Alternator Circuit Breaker |
OK, that answer prompts another question that is not rhetorical.
| Quote: | I have a dual battery install with separate right/left busses that support continued IFR flight without the alternator.
Continued IFR without an alternator-- How is that possible? OK, maybe possible, but prudent?
I used the term traditional because there are many ways to put all the wires together to achieve the same ends. The certified aircraft to which I am referring is the all electric dual battery, dual main, dual avionics buss Cirrus SR series. They used to have their POH on line that anyone could download which detailed the electrical system. I can't find it on their site anymore but I have the SR22 POH in pdf if anyone is interested.
By all accounts, the Cirrus system is very good and reliable but I don't think even Cirrus will say you can continue IFR flight without the alternator. And the Cirrus engine is not dependant on the electrical system as your electronic ignition is. If you have a design that is more robust than the Cirrus, I (and I'm sure other builders) would be very interested in seeing it.
I apologize in advanced for the pointed questions, however as builders, I think we sometimes design pens that work in zero-g rather than just using a pencil.
William
-- Dr. Suess
Tim Olson
Posted: Thu Jan 31, 2008 8:19 pm Post subject: Alternator Circuit Breaker |
Even with this non-time-delay ANL, here's an info sheet
that shows some details:
http://www.aeroelectric.com/Mfgr_Data/Fuses_and_Current_Limiters/Bussman/ANL_Specs.pdf
This is on a 50A ANL:
Notice you can pull over 200A, for 1 second, and can pull 100A+ for
basically at least 100 seconds, or possibly nearly an unlimited
amount of time. If you interpolate the graph, even the lowly 50A
ANL is likely going to stay running with no problem unless you
have some sort of hard fault. A dead battery will draw more power
from the alternator, but you really should be running your alternator
near 100% of capacity for much time. That's why I went with a 70A
alternator....slower turning, cooler running, and a larger margin
over the operating load.
I'm not too worried about losing the fuse and not knowing. It would
first be immediately noticeable on the voltmeter, as you won't
have a voltage anywhere NEAR 14v if you put a load on it and
don't have a working alternator, and I also have visual and
audio alerts for voltage, and can set them in the EIS for Amperage
too, since I have the hall-effect current sensor installed.
But again, with a load on a battery, your voltage will immediately
be in the 12's.....so setting a voltage alert for 13V or
even higher would give you an alert if you lost an alternator.
Jesse Saint wrote:
Don't forget that if you have to crank more than normal, or if something
has drawn your battery down a little, your alternator will be charging
your battery as well as powering everything in the plane, which will
could blow and you not realize it, maybe thinking the alternator itself
is bad or the field circuit has failed? With a CB in sight there is no
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
> Tim
>> 30 amp Tyco breaker I'm using for my backup SD-20 alternator is rated
>> such that it may take up to 1 hour at 145% or 43 amps before it
>> trips. At 200%, i.e. 60 amps, it may still take up to 30 seconds to
>> trip. If that breaker trips, then my alternator is definitely
>> overloaded and I'd sure want to take a look at the problem before
>> continuing on.
>> PJ Seipel
>> RV-10 #40032
>>> trips. If
>>> you
>>> In my
>>> This kept
>>> with
>>> the
>>> alternator.
>>> Carl Froehlich
>>> RV-8A (375 hrs)
>>> RV-10 (wings)
patrick.pulis(at)seagas.c Guest
Posted: Thu Jan 31, 2008 8:50 pm Post subject: Alternator Circuit Breaker |
William, the attachment supports your comments.
I have just completed an endorsement on the Cirrus SR-20 (need to fly
something similar until the ten is completed!) and I experienced an ALT2
failure last Sunday whilst VFR, so these things do happen and from what
I have been told are common.
Patrick
#40299 VH-XPP
Adelaide, South Australia
 Download |
| Filename: |
Cirrus_SR20_Minimum_Equipment_Requirements.doc |
121.5 KB |
| Downloaded: |
460 Time(s) |
Posted: Fri Feb 01, 2008 6:35 am Post subject: Alternator Circuit Breaker |
Tim Olson wrote:
before you blow.
Not really true. The size of the breaker is there to protect the wire,
which could cause a fire if it gets a large escess of current. The size
of the wire is dictated by the load. True of small wires and big ones too.
Linn
| Quote: | A 60A ANL fuse won't blow until well over
