Firewall penetration
Goto page 1, 2  Next
rvtach
PostPosted: Mon Jan 28, 2008 3:42 pm    Post subject: Firewall penetration Reply with quote
Hi-
Working on making firewall penetrations and making them fireproof. I'm using steel eyeballs for engine control cables and a stainless heater valve. I'm expecting to have a single penetration for electrical wiring and for engine sensors etc near the battery box.
I like Bob's modified grab handle method for a fireproof penetration but it's larger and bulkier than I need. And it's probably not a good use of my $time$ to try to come up with a less expensive alternative to the SafeAir 1 stainless fire wall pass through system; it's only $50. But it's $50! I came across a plumbing fitting in the "swamp cooler" section of my local plumbing supply today and it just might be a $3.50 alternative. I have posted some photos at http://picasaweb.google.com/rvtach/FirewallPassthrough that show the hardware.
It comes threaded internally for 1/2" NPT. I removed the threads by running a 7/8" drill through it. The whole thing fits snugly through a 1" hole and is secured by a threaded nut which would need to be secured with some thread locker. I would use firesleeve and hose clamps like Bob's grab handle or the SafeAir 1 product. There's just over 1/2" to clamp the sleeve to which is a little short but should be adequate.
So, can any of you guys think of any problems with this method? Maybe I shouldn't use brass hardware against the s/s firewall? Brass melts to easily? Anything? Appreciate any help at all here.
Jim McChesney
Tucson, AZ
RV-7A Flying
RV10 4JF
PostPosted: Mon Jan 28, 2008 4:54 pm    Post subject: Re: Firewall penetration Reply with quote
Hello,
Tony Bingelis wrote an article on making pass-thru fittings. They are similar to those used on Cessnas except that they are one piece where as the Cessna fittings are two piece. They are oval in shape, SS with fire retardant material surrounding your pass-thru item. You make them out of stainless steel using sockets or pipe as the forming die. They are attached to the firewall with 2 screws. You drill a hole to fit your pass-thru item. You can make them as large or small as you like. You just have to find the right die.
I will see if I can find the article and maybe I can post some pictures or a poorly drawn facsimile.
BTW, in case of an engine fire, you want these fittings to provide some protection so you really need something good.
JF
Dale Ensing
PostPosted: Mon Jan 28, 2008 5:34 pm    Post subject: Firewall penetration Reply with quote
Be aware of possible impact on engine sensor data if sensor leads are too
close to high current (fat) wires.
Dale Ensing
Dale Ensing
RV-6A
Aero Plantation
Weddington NC
ceengland(at)bellsouth.ne
PostPosted: Mon Jan 28, 2008 7:21 pm    Post subject: Firewall penetration Reply with quote
rvtach wrote:
Hi-
Jim McChesney
Tucson, AZ
RV-7A Finishing Kit
Is it a brass fitting? If so, it will melt at a lower temp than
stainless, but so will the aluminum rivets & angles (and the copper wire
going through it will, too). You might be able to find the same fitting
in stainless from a food supply grade plumbing supplier.
You just have to weigh risk/benefit/expense.
My personal opinion is that there's much more risk from the heater
penetration, even with stainless parts, than with any penetration
carrying solid wires or steel cables. If you look at the air gap around
the flapper valve on the heater penetration, the total area of the gap
is effectively a gaping hole, compared to a wire penetration filled with
wire & fire suppressing caulk.
echristley(at)nc.rr.com
PostPosted: Mon Jan 28, 2008 7:53 pm    Post subject: Firewall penetration Reply with quote
A big contributor to the elbow fitting's effectiveness is the elbow.
The fire would have to turn a corner. You loose that with a straight
through fitting.
It should be fairly easy to find a stainless elbow that would do the
same thing. You might have to got up to $10 to get one though 8*)
klehman(at)albedo.net
PostPosted: Tue Jan 29, 2008 4:45 am    Post subject: Firewall penetration Reply with quote
It is not difficult to make a stainless guillotine valve right on the
firewall. A pull cable pulls a plate over the firewall hole to block it
and control the heat. In case things distort in a fire, I have it set to
pull closed. It is on the cabin side of the FW. Perhaps not as good a
solution for those who have to dump excess manifold heat but excellant
for water heat and for fire blocking.
Ken
snip
RV10 4JF
PostPosted: Tue Jan 29, 2008 6:34 am    Post subject: Re: Firewall penetration Reply with quote
I found the article that I mentioned on the EAA builders site.
http://members.eaa.org/home/homebuilders/building/firewall/How%20to%20Make%20Firewall%20Grommet%20Shields.html#TopOfPage
Check this out and see if it will work for you.
JF
david.nelson(at)pobox.com
PostPosted: Tue Jan 29, 2008 8:14 am    Post subject: Firewall penetration Reply with quote
Hi Jim,
Clever idea. I presume it's brass so it's corrosion resistant even though
you drilled out the threads.
I saw a clever use of EMT tubing set screw connectors (ie steel electrical
conduit tubing). You can see a picture here (search for 'set-screw'):
http://www.alliedtube.com/electrical-raceways/conduit/emt-connectors-couplings.asp
The builder had notched out the set screw. Personally, I think I'd leave
the set screw hole (and toss the set screw) and make sure the inside of
coupling was free of any burrs, etc. The set screw hole is slightly
raised thus providing a little bit of a "barb" to keep any clamps and fire
sleeve from backing out.
The connectors are available in a variety of nominal sizes from 1/2",
3/4", 1", 1-1/4", 1-1/2", all the way up to 4". Any hardware store (at
least in the US) would have the smaller sizes.
I would also think about using some .032 sheet behind the locking nut
rather than have the nut gouge the firewall.
/\/elson
Austin, TX
RV-7A - Canopy frame
~~ Lately my memory seems to be like a steel trap .... without any spring. ~~
On Mon, 28 Jan 2008, rvtach wrote:
Hi-
Jim McChesney
Tucson, AZ
RV-7A Finishing Kit
http://forums.matronics.com/viewtopic.php?p=160931#160931
rvtach
PostPosted: Tue Jan 29, 2008 9:26 am    Post subject: Re: Firewall penetration Reply with quote
david.nelson(at)pobox.com wrote:
Hi Jim,
[/quote]
Yup. It is solid brass. Any opinions if brass is adequate fire protection in this application?
Dale Ensing
Hadn't thought of this. I had planned on running my main bus and e-bus feed lines through this pass through (along with all engine sensors). No really fat wires (like starter or B-lead) but would there be enough current here for me to need to make a separate penetration to keep these wires separate?
Really appreciate all the input so far. If I actually do need to make 2 more penetrations then maybe this is worthwhile ($7 vs $100).
Jim McChesney
Tucson, AZ
RV-7A Flying
ericparlow(at)hotmail.com
PostPosted: Wed Jan 30, 2008 7:05 am    Post subject: Firewall penetration Reply with quote
We used a similar fitting but it has a barbed extension to clamp flexible conduit over it.
$2.50 ea in Lowes Aviation dept.
See photos attached
We used 4 of theses on our RV-10 mounted in the firewall center recess.
The wires pass thru the bulkhead fitting with a connector on either side.
The wires are wrapped in fire sleeve similar to the SafeAir design.
After the pass-thrus are in the firewall the FWF side connectors are mounted on to the back side of a SS plate which covers the recess.
Eric Parlow
RV-10, 40014
N104EP
Date: Tue, 29 Jan 2008 10:10:07 -0600
Subject: Re: Firewall penetration
--> AeroElectric-List message posted by: 'David E. Nelson' <david.nelson(at)pobox.com>
Hi Jim,
raised thus providing a little bit of a 'barb' to keep any clamps and fire
The connectors are available in a variety of nominal sizes from 1/2',
3/4', 1', 1-1/4', 1-1/2', all the way up to 4'. Any hardware store (at
/\/elson
Austin, TX
> --> AeroElectric-List message posted by: 'rvtach' <rvtach(at)msn.com>
> Hi-
> I like Bob's modified grab handle method for a fireproof penetration but it's larger and bulkier than I need. And it's probably not a good use of my $time$ to try to come up with a less expensive alternative to the SafeAir 1 stainless fire wall pass through system; it's only $50. But it's $50! I came across a plumbing fitting in the 'swamp cooler' section of my local plumbing supply today and it just might be a $3.50 alternative. I have posted some photos at http://picasaweb.google.com/rvtach/FirewallPassthrough that show the hardware.
> It comes threaded internally for 1/2' NPT. I removed the threads by running a 7/8' drill through it. The whole thing fits snugly through a 1' hole and is secured by a threaded nut which would need to be secured with some thread locker. I would use firesleeve and hose clamps like Bob's grab handle or the SafeAir 1 product. There's just over 1/2' to clamp the sleeve to which is a little short but should be adequate.
> Jim McChesney
> Tucson, AZ
> RV-7A Finishing Kit
PostPosted: Thu Jan 31, 2008 9:25 am    Post subject: Firewall penetration Reply with quote
FWIW I ran everything including starter fat wire through the same
opening which is a hardware store steel towel rack/grab bar elbow. It
really doesn't matter if an engine sensor is misreading a bit during
cranking. At idle on the ground I can hear a bit of electronic ignition
noise from one ignition. No alternator noise at all so I'd do it again.
I don't have mags.
Ken
> Dale Ensing
Jim McChesney
Tucson, AZ
RV-7A Finishing Kit
Bill Schlatterer
PostPosted: Thu Jan 31, 2008 5:42 pm    Post subject: Firewall penetration Reply with quote
Just FWIW, I posted a similar firewall penetration a couple years ago using
the cheap pot metal electrical connectors shown in the attachment. I was
cautioned to AVOID any of the fittings that were made of cast steel
compounds (gray looking pot metal material) because they would actually burn
very well under modest flame. Was told to ONLY use the steel tube/forged
fittings which were much more expensive but would not burn.
I did not put a torch on them to find out but thought I might mention it.
Pictures of the rejected fittings attached.
Just what I was told on this list back then.
Bill S
7a
 Filesize:  97.64 KB
 Viewed:  907 Time(s)
Joemotis(at)aol.com
PostPosted: Thu Jan 31, 2008 6:07 pm    Post subject: Firewall penetration Reply with quote
Those connectors are made from ZAMAC and have a melting point of around 750 degrees. You can melt them in a saucepan on a gas cooktop.
Joe Motis
Start the year off right. Easy ways to stay in shape in the new year.
longg(at)pjm.com
PostPosted: Fri Feb 01, 2008 1:37 pm    Post subject: Firewall penetration Reply with quote
I understand the experimental mentality and all, but this crap is so
cheap-o. Are we left to salvaging conduit fittings from electrical
contractors? I have tons of these things in coffee cans in my basement
if anyone really wants to use them.
These clamps are right at home running conduit to my air-conditioner,
but if you do a risk analysis of using them on the firewall with your
family sitting behind them, what value would you place on buying
something actually made for the firewall for a few dollars more?
mkimball(at)gci.net
PostPosted: Fri Feb 01, 2008 2:35 pm    Post subject: Firewall penetration Reply with quote
Anybody have a web link to the proper penetration fittings?
stevea(at)svpal.org
PostPosted: Fri Feb 01, 2008 3:34 pm    Post subject: Firewall penetration Reply with quote
These are what I installed. Buy direct from EPM or get them through
Aircraft Spruce.
http://www.epm-avcorp.com/tubeseal.html
The idea here is to buy time to shut off the fuel and get the airplane
on the ground in the event of an in flight engine fire. Aluminum,
plastic, brass, and zinc/aluminum (conduit fittings) will fail
catastrophically well below the temperature at which gasoline burns.
Steel (stainless or non-stainless) will withstand that temperature much
longer, allowing for a better chance at surviving the situation.
It is called a "firewall" for a reason.
Steve A
RV-6A
Bret Smith
PostPosted: Fri Feb 01, 2008 3:38 pm    Post subject: Firewall penetration Reply with quote
Mike,
Here is one example. Hopefully this discussion will shake out some other
"less expensive" options.
Bret Smith
RV-9A N16BL
Blue Ridge, Ga
www.FlightInnovations.com
Bret Smith
RV-9A (Emp)
Terry Watson
PostPosted: Fri Feb 01, 2008 4:06 pm    Post subject: Firewall penetration Reply with quote
This is what I used and I like them. I bought the middle size, hoping that
two of them would be big enough and that it would be cheaper than the bigger
ones. Hindsight says that the biggest ones would have been better for me.
Terry
RV-8A
Wiring
Mark Phillips in TN
PostPosted: Fri Feb 01, 2008 6:34 pm    Post subject: Firewall penetration Reply with quote
In a message dated 02/01/2008 3:40:03 PM Central Standard Time, longg(at)pjm.com writes:
contractors?
OK folks- I've been watching this pass-thru stuff for quite a while now (years, in fact) and while building my plane, solved the issue to my satisfaction with the following:
http://websites.expercraft.com/n51pw/index.php?q=log_entry&log_id=5006
http://websites.expercraft.com/n51pw/index.php?q=log_entry&log_id=5007
http://websites.expercraft.com/n51pw/index.php?q=log_entry&log_id=5517
For use by a fellow builder, I've had additional copies of this made in the size shown and slightly larger to accomodate fatter/more wires, and the extra parts I had cut have been hanging on the wall of my shop for some time, looking for a home. I had no intention of "marketing" this, but if there is any interest, I'd gladly send what I have to those interested, provided my costs were covered. I have theorized some improvements and might even consider going into production if y'all think it would be useful. I could provide fotos of the newer installation to those interested.
It ain't rocket science, it just works...
From The PossumWorks in TN,
Mark Phillips, RV-6A N51PW "Mojo" (she's a good girl!)
Who's never won? Biggest Grammy Award surprises of all time on AOL Music.
From The PossumWorks...
Allen Fulmer
PostPosted: Fri Feb 01, 2008 7:58 pm    Post subject: Firewall penetration Reply with quote
For some reason this link hasn't worked for the last few days from
Vansairforce.net but I have just recently bought one of their stainless
firewall penetrations. They only have 1/4", 1/2" and 3/4" i.d. versions.
Kind of pricey but will certainly do the job.
Also just ordered a similar 0.90 i.d. firewall penetration from SafeAir1 at
http://www.safeair1.com/index.htm.
Allen Fulmer
RV7 Wiring and plumbing
[quote]>>--
RV7 QB Fuselage
Eggenfellner H6 on orde
N808AF reserved
Alexander City, AL
Goto page 1, 2  Next
Page 1 of 2
