M3X update
icrashrc
PostPosted: Mon Jan 28, 2008 11:37 am    Post subject: M3X update Reply with quote
Life has gotten in the way of both building and updating the website on the M3X so I thought I would post a few pics. I'm starting with the overhead console we made. Those of you at the homecoming may have seen this.
 Filesize:  106.43 KB
 Viewed:  392 Time(s)
 Filesize:  90.59 KB
 Viewed:  430 Time(s)
Overhead Console
 Filesize:  88.89 KB
 Viewed:  412 Time(s)
Scott
www.ill-EagleAviation.com
icrashrc
PostPosted: Mon Jan 28, 2008 11:41 am    Post subject: Re: M3X update Reply with quote
Here's a pic of the Kevlar panel we laid up to mount all the under seat components on.
 Filesize:  79.6 KB
 Viewed:  409 Time(s)
Scott
icrashrc
PostPosted: Mon Jan 28, 2008 11:47 am    Post subject: Re: M3X update Reply with quote
Here's the foam and glass center console. Note the built in GPS. This is the main reason we made the overhead console. Once we built in the GPS there was nowhere for the accessory and ignition switches.
 Filesize:  106.31 KB
 Viewed:  427 Time(s)
 Filesize:  60.9 KB
 Viewed:  399 Time(s)
Scott
icrashrc
PostPosted: Mon Jan 28, 2008 11:51 am    Post subject: Re: M3X update Reply with quote
Here's the instrument pod. We laid up a Carbon/blue Kevlar panel to use instead of the horrid but functional aluminum panel provided.
 Filesize:  56.31 KB
 Viewed:  387 Time(s)
 Filesize:  63.49 KB
 Viewed:  365 Time(s)
Scott
icrashrc
PostPosted: Mon Jan 28, 2008 11:54 am    Post subject: Re: M3X update Reply with quote
M3X out sunbathing
 Filesize:  111.76 KB
 Viewed:  389 Time(s)
Scott
slyck(at)frontiernet.net
PostPosted: Mon Jan 28, 2008 12:04 pm    Post subject: M3X update Reply with quote
looks great. Can almost hear you making brrrm-brrrrm noises.
BB
Scott
http://forums.matronics.com/viewtopic.php?p=160879#160879
http://forums.matronics.com//files/dsc00748_159.jpg
http://forums.matronics.com//files/dsc00746_444.jpg
http://forums.matronics.com//files/dsc00740_184.jpg
NeilsenRM(at)comcast.net
PostPosted: Mon Jan 28, 2008 12:51 pm    Post subject: M3X update Reply with quote
Scott
Looks super.
I see in one of your photos you put what looks like a 2X4 over the torque
tube. You probably just put this in to protect the torque tube while you
were working on things but try this. I got a aluminum tube that I cut length
wise and then bent into a U shape. Then with spacers I mounted this U shaped
aluminum piece over the torque tube. It fits close enough to be covered by
the Kolb upholstery, strong enough that I can support my weight without
collapsing on the torque tube and is very light weight. I got the idea for
this every time I got in the factory plane they would said "don't lean on
that tube".
Rick Neilsen
Redrive VW powered MKIIIC
icrashrc
PostPosted: Mon Jan 28, 2008 2:28 pm    Post subject: Re: M3X update Reply with quote
Rick,
That's actually a vacuum bagged Kevlar piece. It attaches to both the center console and another composite piece that covers the A-frame section of the cage between the seats.
Scott
PostPosted: Mon Jan 28, 2008 3:28 pm    Post subject: M3X update Reply with quote
BB
Scott and Gang:
I echo Beanie Weanie's sentiments also. Looks good. Got to get a look at
some of their stuff last year at London.
BTW: What are those big things on the little wheels? Wink
mkIII - Lover of big soft tires and interesting short, soft fields.
Steve Boetto
PostPosted: Mon Jan 28, 2008 6:48 pm    Post subject: M3X update Reply with quote
John, is it just me or did your statement have a certain hidden Freudian meaning?
Steve B
Firefly 007/Floats
In a message dated 1/28/2008 6:29:15 P.M. Eastern Standard Time, jhauck(at)elmore.rr.com writes:
Start the year off right. Easy ways to stay in shape in the new year.
PostPosted: Mon Jan 28, 2008 6:55 pm    Post subject: M3X update Reply with quote
Oh shit.
Leave it to Beaver.
Oops, there I go again. Wink
[quote] john h
PostPosted: Mon Jan 28, 2008 7:17 pm    Post subject: M3X update Reply with quote
Gang:
My reply was not intended to go back to the Kolb List, but it did.
As we would say in Vietnam: "20,000 xin loi" which means I am sorry 20 thousand times.
Now.........what were we talking about?
Oh shit.
Leave it to Beaver.
icrashrc
PostPosted: Mon Jan 28, 2008 7:36 pm    Post subject: Re: M3X update Reply with quote
[/quote]
Scott and Gang:
mkIII - Lover of big soft tires and interesting short, soft fields.[/quote]
John,
The big things hiding the little wheels are there at Pauls request. I figure it's the least i could do considering all the work he's done. I'll be sure to leave them at home if you and i go hunting for short, soft fields to land in.
Smile
Scott
icrashrc
PostPosted: Thu Jan 31, 2008 11:16 pm    Post subject: Re: M3X update Reply with quote
Due to many back channel emails I've added a page to the site with some info on the composite layups Paul and I have been doing.
http://www.ill-eagleaviation.com/composites.htm
Scott
ElleryWeld(at)aol.com
PostPosted: Fri Feb 01, 2008 5:15 am    Post subject: M3X update Reply with quote
Any new info is always great I can do about anything else but composits is a area that I could use any info to learn more about it. But How to make a mold is the next chapter I hope Thanks Scott
Ellery
In a message dated 2/1/2008 2:20:08 A.M. Eastern Standard Time, icrashrc(at)aol.com writes:
--> Kolb-List message posted by: "icrashrc" <icrashrc(at)aol.com>
Scott
http://forums.matronics.com/viewtopic.php?p=161779#161779
