2-stroke Oil
Goto page 1, 2  Next
Guy Buchanan
PostPosted: Mon Jan 21, 2008 12:08 pm    Post subject: 2-stroke Oil Reply with quote
Good morning all,
I am having a heck of a time getting the Pennzoil 2-stroke
air cooled oil. The best price I've been able to get was $40/case of
24 pints + $10 shipping at oil-store.com. I was also told by a
Pennzoil distributor that the 16oz. has been discontinued and that
sooner or later I'll have to use 8oz. bottles, with the attendant
higher price and waste. Therefore, would anyone care to recommend a
non-Pennzoil oil for the 582?
Thank you,
Guy Buchanan
San Diego, CA
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
patreilly43(at)hotmail.co
PostPosted: Mon Jan 21, 2008 12:37 pm    Post subject: 2-stroke Oil Reply with quote
Guy, I recommend AMSOIL. They have a premix and an injector oil I have used it in everything from a Kohler 30 HP engine on an ultralite & various 2 stroke race motorcycles to a 1/6 HP weed whip at the 100 to 1 Ratio for over 20 years. It is the only 2 stroke oil I will use except for break-in of a brand new engine. I use what ever the mfg. recommends for break-in for obvious reasons.
Pat Reilly
Mod 3 Rebuild
Rockford,IL
Date: Mon, 21 Jan 2008 11:59:23 -0800
To: kitfox-list(at)matronics.com; rotaxengines-list(at)matronics.com
Subject: 2-stroke Oil
--> Kitfox-List message posted by: Guy Buchanan <bnn(at)nethere.com>
Good morning all,
Thank you,
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to ========================>
dave
PostPosted: Mon Jan 21, 2008 12:51 pm    Post subject: Re: 2-stroke Oil Reply with quote
Simple solution, Use Bombardier XPS mineral oil
it is API TC rated an sold at all Ski doo and Sea doo dealers.
You can buy it in containers or bring your own and buy bulk.
My Current 582 has 380 hours on it and never been apart.
Current spark plugs have 14 hours on them and I checked one yesterday.
Look like they got 10 hours on them.
I use what works and in this case I will continue to do it this way.
Pennzoil for air cooleds in my opinion is about the same . Just stay away from outboard oil that is TCw#3 rated and not API TC rated .
Synthetics use only if you use you r plane at least twice a week and live in a dry climate. If not I be happy to sell you a crank.
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube
JohnA
PostPosted: Mon Jan 21, 2008 2:04 pm    Post subject: 2-stroke Oil Reply with quote
Guy,
CPS has AV-2. It is really the cleanest burning stuff that I've run across.
CPS has it in 5 gallon buckets which is quite economical.
www.800-airwolf.com
John Alexander
Woodland, CA
On Mon, 21 Jan 2008 11:59:23 -0800, Guy Buchanan wrote
Good morning all,
Thank you,
Guy Buchanan
San Diego, CA
Beer is proof that god loves us and wants us to be happy. - Ben Franklin
John Alexander
Woodland, CA
Fox5flyer
PostPosted: Mon Jan 21, 2008 2:38 pm    Post subject: 2-stroke Oil Reply with quote
Guy, I always bought mine from Tractor Supply (TSC) in one gallon containers
and it was very economical compared to buying it in the 16 oz units. It's
been quite awhile though, so I don't know if they still carry it like that.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 355+ TT
"The aim of an argument or discussion should not be victory, but progress."
- Joseph Joubert
PostPosted: Mon Jan 21, 2008 3:54 pm    Post subject: 2-stroke Oil Reply with quote
Dave, My experience over 20 years with AMSOIL has been nothing but positive. You state that you don't like synthetics with your 582. What experience have you had with synthetic oil that prompts your advice? I value your advice. Maybe, I will have to switch to the oil you are recommending.
Pat Reilly
Mod 3 Rebuild
Rockford,IL
Subject: Re: 2-stroke Oil
Date: Mon, 21 Jan 2008 12:51:33 -0800
--> Kitfox-List message posted by: "dave" <dave(at)cfisher.com>
Pennzoil for air cooleds in my opinion is about the same . Just stay away from outboard oil that is TCw# rated and not API TC rated .
Rotax Dealer, Ontario Canada
Flying Videos and Kitfox Info
http://www.cfisher.com/
http://forums.matronics.com/viewtopic.php?p=159630#159630>
shinco(at)bright.net
PostPosted: Mon Jan 21, 2008 4:09 pm    Post subject: 2-stroke Oil Reply with quote
Guy Buchanan wrote:
Good morning all,
I am having a heck of a time getting the Pennzoil 2-stroke air
cooled oil. The best price I've been able to get was $40/case of 24
pints + $10 shipping at oil-store.com. I was also told by a Pennzoil
distributor that the 16oz. has been discontinued and that sooner or
later I'll have to use 8oz. bottles, with the attendant higher price
and waste. Therefore, would anyone care to recommend a non-Pennzoil
oil for the 582?
Thank you,
Guy Buchanan
San Diego, CA
Go To Walmart,,they have Pennzoil 2 stroke oil.I use Rotax 2 stroke
oil in my KF2..Steve Shinabery N554KF kf 2
dave
PostPosted: Mon Jan 21, 2008 5:08 pm    Post subject: Re: 2-stroke Oil Reply with quote
Pat Reilly
Mod 3 Rebuild
Rockford,IL
Pat I have over 35 year with 2 strokes and have used synthetic in some applications ie exhaust valv racing etc. There is no question that some synthetics do a great job providing lubrication.
But they do not provide the corrosion protection you get with mineral oil.
If you use you engine several time s a week and/or live in the desert or a very dry climate you might do better than others.
What is the advantage of Amsoil or any synthetic ? We use mostly Bombardier XPS here for injected engines and rotax pre mix for pre mix.
just make sure it is API tc rated and if you insist on synthetics then when not in use you better buy some fogging oil or someone will be selling you a crank .
Thousands of Rotax cranks are sold annually , why ?
Alot of bearing failures stem from corrosion. Imagine any roller or Ball bearing with a bit of rust on it not to mention the races of the bearing then spin them at 6000 rpm and see how long that galled bearing endures the not so smooth ride. Yes failure imminent.
JohnA
PostPosted: Mon Jan 21, 2008 5:23 pm    Post subject: 2-stroke Oil Reply with quote
All,
Two major things to be aware of if you change your 2-stroke oil in a 582.
- Use the same oil for both your oil injection (or pre-mix) and for the RV
shaft fluid. If you change oils, your oil injection / fuel lines and the RV
shaft lube system should get a very good flush - or preferably, do a full
engine teardown. It is not that expensive and should be done about every 150
hours anyway.
- Beware of switching from synthetic to non-synthetic oils. In some cases,
they are not compatable and mixing the two will result in a gummy sludge.
This could really bite you if you have oil injection. The ports in the oil
pump are small.
If your oil works for you, doesn't rapidly foul the plugs and stick the rings
and build up overly on the piston dome/cylinder head, stick with it.
John Alexander
Woodland, CA
John Alexander
Woodland, CA
Guy Buchanan
PostPosted: Mon Jan 21, 2008 9:56 pm    Post subject: 2-stroke Oil Reply with quote
containers and it was very economical compared to buying it in the
16 oz units. It's been quite awhile though, so I don't know if
Thanks Deke. It looks like they don't carry it anymore.
Guy Buchanan
San Diego, CA
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
Guy Buchanan
Wow. Wouldn't that be great. I'll check it out. I wonder if I have to
flush the system to go from the blue air cooled engine oil to the red
Premium Outboard.
Guy Buchanan
San Diego, CA
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
dave
PostPosted: Tue Jan 22, 2008 2:00 am    Post subject: Re: 2-stroke Oil Reply with quote
Premium Outboard.
Guy Buchanan
Why would you use outboard oil? If it meets API TC - sure.
If it TCw3 oil -stay away from it.
Go to a Sea doo or a Ski doo dealer and likely theyr will have XPS in containers or Bulk.
Others I know are decent along with Pennzoil, Shell advance and Castrol Super 2 stroke. Once again make sure they meet the rating of API TC.
PostPosted: Tue Jan 22, 2008 2:13 am    Post subject: 2-stroke Oil Reply with quote
Premium Outboard.
Guy Buchanan
San Diego, CA
I think that they sell the Pennzoil 2 stroke oil in gal gugs all so..But
I buy my rotax 2 stroke oil at ,a rotax snowmobile dealer.why chance a
good thing.ROTAX engine,ROTAX 2 stroke oil.all so I heard a thing I do
not know if it is trure.But they told me to stay away from Pennzoil
because it does not break down in gasoline as the Rotax oil does.that is
why I never switched to the Pennzoil 2 stroke oil,I was but after I
heard that.I stayed with the Rotax oil..I thought what Rotax knows about
there engines they sould know about there oil all so.but that is your
choice. Steve Shinabery N554KF KF2 582 C box
PostPosted: Tue Jan 22, 2008 2:15 am    Post subject: 2-stroke Oil Reply with quote
Premium Outboard.
Guy Buchanan
San Diego, CA
Gary when you switch from 1 oil to another it is best to flush your
system,and then put in all new oil. Steve Shinabery N554KF KF2 582
dave
PostPosted: Tue Jan 22, 2008 2:30 am    Post subject: Re: 2-stroke Oil Reply with quote
Hey Steve, it certainly is funny how the Rotax book is followed to a "T" for alot of info, cooling temps, coolant, EGTs temps, Mufflers etc but when it comes to oil it seems to go unnoticed?
You know what I use and you know it works.... 250 to 350 2 stroke flying hours a year with no troubles speaks for itself.
I will tell you that some owners decisions on how to run their engine and what oil to use does in fact bring Rotax shops business. Smile
In all fairness I would rather see a safe and longer running engine than just being the supplier of parts to replace ones that had their life shortened from improper operations.
Guy Buchanan
PostPosted: Tue Jan 22, 2008 9:19 am    Post subject: 2-stroke Oil Reply with quote
Only because of the ultralightnews.com test. They tested these two
Pennzoils and though they found the air-cooled to be the best, they
found the red Premium outboard, which is API-TC rated to be almost as
good. Unfortunately they didn't test the XPS or Amsoil. On your
suggestion I will be looking around San Diego for the XPS, as I'm
sure there's a Sea-Doo dealer here somewhere.
Guy Buchanan
San Diego, CA
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
Guy Buchanan
so..But I buy my rotax 2 stroke oil at ,a rotax snowmobile
dealer.why chance a good thing.ROTAX engine,ROTAX 2 stroke oil
Steve,
Are you talking about the Bombardier XPS oil? Or is there
something with a Rotax brand on it?
Guy Buchanan
San Diego, CA
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
Float Flyr
PostPosted: Tue Jan 22, 2008 10:35 am    Post subject: 2-stroke Oil Reply with quote
Just a thought... Johnson (the outboard manufacturer not the... J ) and Evinrude are now built by Bombardier. They should have a supply of XPS mineral oil.
Noel Loveys
Campbellton, NL, Canada
CDN AME intern, PP-Rec
C-FINB, Kitfox III-A
582 B box, Ivo IFA, Aerocet 1100 floats
[url=noelloveys(at)yahoo.ca]noelloveys(at)yahoo.ca[/url]
Noel
 Filesize:  7.29 KB
 Viewed:  15301 Time(s)
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
nativealaskan1956(at)gmai
PostPosted: Tue Jan 22, 2008 11:40 am    Post subject: 2-stroke Oil Reply with quote
Why are you using that crap anyway. Use Golden Spectro.
On 1/21/08, Guy Buchanan <bnn(at)nethere.com (bnn(at)nethere.com)> wrote: [quote]--> Kitfox-List message posted by: Guy Buchanan <bnn(at)nethere.com (bnn(at)nethere.com) >
Good morning all,
higher price and waste. Therefore, would anyone care to recommend a [quote][b]
PostPosted: Tue Jan 22, 2008 2:09 pm    Post subject: 2-stroke Oil Reply with quote
> so..But I buy my rotax 2 stroke oil at ,a rotax snowmobile dealer.why
Steve,
Guy Buchanan
San Diego, CA
Guy,,It is the Bombardier XPS 2 stroke oil.but I will check to make
sure this weekend.since I will not get out to the airport untill
then.I belive that you will beable to get it from Ski Doo or a Sea Doo
dealer. I think I payed $24.00 gal for it. if the Sea Doo Dealer does
not have it.he could order it for you..Steve Shinabery N554KF KF2
with the little but mighty 582
Goto page 1, 2  Next
Page 1 of 2
