patreilly43(at)hotmail.co Guest
Posted: Sun Jan 20, 2008 12:15 pm Post subject: Aluminum Belly Pan |
Lynn, I like the idea of tabs to secure the belly pan. I also like epoxy attachment. I could also weld the tabs on. The front cross tube on my Mod 3 had the lower firewall screwed or riveted directly into that tube. It was not attached when I got the plane. It just has the holes in the firewall and tube. What brand of epoxy do you recommend for the clips. The paint would need to be removed in the area where it was epoxied and repainted. At least I think most epoxies require clean metal for attachment. I didn't plan on fabric covering that portion of the belly the pan covers. I will see if I can find the metal cable clips you mention. Again Thank You for your advice. It is invaluable to have the experience available through this Kitfox Thread. Pat Reilly Mod 3 Rebuild Rockford, IL
| Quote: | From: lynnmatt(at)jps.net
Subject: Re: Aluminum Belly Pan
Date: Sun, 20 Jan 2008 13:26:19 -0500
--> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net>
Thanks, Pat.
I get nervous about screwing right into the structural fuselage
tubing. I'd rather epoxy some brackets to the tubing, so that the
"structural integrity" [don't know what that means, but it sounds
important : ) ] isn't compromised/weakened. You could epoxy a pre-
drilled bracket(s) to the tubing, then put a hole right through the
fabric, and this would mount the belly pan.
I would make a question-mark shaped bracket, and drill some holes
into the rounded part of the bracket. When you epoxy the bracket in
place, the epoxy oozes through the holes, and helps hold the bracket
to the tubing. Maybe single-screw brackets, or some wide brackets, so
that a couple of screws could be used in each bracket, cutting down
on the number of brackets needed to be epoxied on.
Hey, I just thought of something...Gardner-Bender of Milwaukee, WI,
makes EZ-Cable Clips in various sizes. I found then at a hardware
store in the electrical department.I have some made from aluminum,
and they'd be almost perfect, if bent to shape. I would use anchor
nuts riveted onto the clips, (before gluing the clips in place) and
then use machine screws to secure the belly pan.
Lynn Matteson
Grass Lake, Michigan
flying w/460+ hrs
On Jan 20, 2008, at 11:38 AM, patrick reilly wrote:
> Lynn, Thanks for reply. I am definitly installing an aluminum belly
> pan. What about pop riveting or screwing the pan to the fusalage
> tubing, similar to the screws at the front, at the rear. I am going
> to mount the front as you mentioned, slide it under the bottom of
> the firewall. I saw your picture on the Kitfox factory website,
> nice looking plane. Pat Reilly Mod 3 rebuild Rockford, IL
> > Date: Sun, 20 Jan 2008 10:31:56 -0500
> > To: kitfox-list(at)matronics.com
> > I have a Grove gear, and it seems like there must be a bit of
> drag on
> > that, where the air passes between the belly of the plane and the
> > gear. I have thought of putting a belly pan in that area, using the
> > screws that hold the bottom portion of the firewall...the horizontal
> > "flap"...to hold the front of the belly pan. My notion was to remove
> > the screws, slide the front of the belly pan under the firewall
> flap,
> > and screw it back down. then slope the belly pan down under the
> Grove
> > gear, and then back up to the fuse. I'd make the whole thing about 2
> > feet long, and this would streamline, to some extent, the Grove
> gear.
> > I haven't worked it all out in my mind yet, but the sides could be
> > formed up, I'm thinking, to cover the gear attaching brackets, and
> > fair those in as well. The biggest problem as I see it would be
> > attaching the rear of the pan to the fuse. Maybe some brackets
> > epoxied inside the fuse to the crosstubes would work. A belly pan in
> > this area would ease cleanup in this area as well.
> > A fellow lister has a Model V, and the builder of that plane
> actually
> > did some structural work in that area...Grove gear...to fair in the
> > belly of the plane, and enclose the gear at that point. Danny, Deke,
> > or Duane might want to shed some light on this, Danny especially.
> > Lynn Matteson
> > Kitfox IV Speedster w/Jabiru 2200
> > flying w/460+ hrs
> > On Jan 19, 2008, at 11:44 PM, john oakley wrote:
> > > Pat,
> > > If I had to do it over again, I would put an aluminum pan under
> the
> > > cabin.
> > > John Oakley
> > > 912 speedster cap
> > > From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-
> > > list-server(at)matronics.com] On Behalf Of Pat Reilly
> > > Sent: Saturday, January 19, 2008 2:30 PM
> > > Subject: Kitfox-List: Aluminum Belly Pan
> > > Kitfoxers, has anybody put an aluminum belly pan under the cabin?
> > > Would .025 thick add too much weight?
> > > Pat Reilly
> > > Mod 3 Rebuild
> > > Rockford, IL
> > > http://www.matronics.com/Navigator?Kitfox-Listhttp://
> > > forums.matronics.comhttp://www.matronics.com/contribution
> > > http://www.matronics.com/Navigator?Kitfox-List_-
> > > ========== _-
> > > forums.matronics.com_-
> > > =================================== _-
> > > contribution_-
> ========== _-
> contribution_-
Float Flyr
avidfox
Posted: Sun Jan 20, 2008 1:46 pm Post subject: Aluminum Belly Pan |
Vintage Pipers, J-3's, 4's, PA-15's,17's, 20's, 22's, etc. have small, drilled tabs welded to the tubing with clip-on tinnermans to attach a aluminum belly pan. It works perfect and has for 70 years
A 2007 $125,000.00 CubCrafter has small holes drilled right into the tubing and the pan is attached with a zillion #4 PK screws. I don't care to think about what the holes will look like in a few years after the pan has been removed for each inspection and general maintenance, No doubt all augured out and oversized with an assortment of #4's, #6's, and in time #8, I'm concerned also about what was mentioned about future internal corrosion because of the holes compromising the tubing interior
No doubt CubCrafters does this for labor cost savings and simplicity, but it sucks.
Steve Benesh
A&P, IA
Jimz
Posted: Sun Jan 20, 2008 1:48 pm Post subject: Aluminum Belly Pan |
A friend is building a series 5 and so am I. His kit came with an aluminum extrusion to use to cut out clips to attach the aluminum pan under the rudder pedals. He had me cut them for him and here is a picture of the extra one. This is the second plane that I have seen use them. They get epoxied to the tubes, then either a rivet or screw holds the aluminum pan.
Jim Z
Series 5 0-200
Covering.
22.98 KB |
660 Time(s) |
jdmcbean(at)kitfoxaircraf Guest
Posted: Sun Jan 20, 2008 2:22 pm Post subject: Aluminum Belly Pan |
Has anyone thought about maybe using heavy fabric on the bottom instead of the aluminum ?? Just a thought.
<![if !supportEmptyParas]> <![endif]>
AUTOTEXTLIST \s "E-mail Signature" <![endif]-->Fly Safe !!
John & Debra McBean
208.337.5111
www.kitfoxaircraft.com
"It's not how Fast... It's how Fun!"
<![endif]--><![if !supportEmptyParas]> <![endif]>
-----Original Message-----
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of patrick reilly
Sent: Sunday, January 20, 2008 9:56 AM
Subject: RE: Aluminum Belly Pan
John, Thanks for your response. I will fabricate an aluminum belly pan. I will use .020 or.016 clad aluminum. Pat Reilly Mod 3 Rebuild Rockford, IL
Date: Sat, 19 Jan 2008 21:44:19 -0700
Pat,
If I had to do it over again, I would put an aluminum pan under the cabin.
John Oakley
912 speedster cap
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Pat Reilly
Subject: Aluminum Belly Pan
Kitfoxers, has anybody put an aluminum belly pan under the cabin? Would .025 thick add too much weight?
Pat Reilly
Mod 3 Rebuild
Rockford, IL [quote] http://www.matronics.com/contribution <![if !supportEmptyParas]> <![endif]><![if !supportEmptyParas]> <![endif]>arget=_blank>http://www.matronics.com/Navigator?Kitfox-Listp://forums.matronics.comblank>http://www.matronics.com/contribution<![if !supportEmptyParas]> <![endif]><![if !supportEmptyParas]> <![endif]><![if !supportEmptyParas]> <![endif]> - The Kitfox-List Email Forum - --> http://www.matronics.com/Navigator?Kitfox-List - MATRONICS WEB FORUMS - --> http://forums.matronics.com - List Contribution Web Site - Thank you for your generous support! -Matt Dralle, List Admin. --> http://www.matronics.com/contribution<![if !supportEmptyParas]> <![endif]>[b]
Float Flyr
Posted: Sun Jan 20, 2008 2:54 pm Post subject: Aluminum Belly Pan |
Lynn:
The only time I ever heard of any one intentionally putting a hole in a tube
frame is when they are inhibiting the interior of the tube. Other than that
tabs would always be welded to the exterior before the frame was inhibited.
The inhibiting process includes drilling two small holes in the upper and
lower corners of the frame. Inserting about a quart (depending on the size
of the frame) of double-boiled linseed oil into one of the holes ( a hypo
works well) and then sealing the holes with PK self tapping screws. For the
next few days hang the frame and turn it in every direction and let it sit
for a couple of hours to ensure the oil flowed to every part of the interior
of the frame. Then after about a week of this turning you would turn it so
one of the holes was at the low point, remove both screws and drain out the
excess linseed oil. This can take overnight. Re-seal the holes with the
screws. For obvious reasons never drill the holes into joints (welds) and
always drill into the inside of the frame not the outside where the cloth
lies. This form of interior rust control has been protecting tube frame
aircraft for almost a century. Only down side to this process is if you mop
the linseed oil up with a rag you have to be very careful the rag won't
spontaneously combust. Rags wet with linseed oil should be immediately
stored in a fireproof container or used to start the fireplace. I've seen a
wet rag combust in as little as fifteen minutes and fill a hangar with
white, cough, cough, smoke.
Noel Loveys
AME Intern, RPP
Kitfox III-A, 582,B box
Ivo IFA, Aerocet 1100 floats
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
jcorner(at)shaw.ca Guest
Posted: Sun Jan 20, 2008 3:37 pm Post subject: Aluminum Belly Pan |
Posted: Sun Jan 20, 2008 3:41 pm Post subject: Aluminum Belly Pan |
John, Thought about heavy fabric on belly, but doesn't give accessability. Pat Reilly Mod 3 Rebuild Rockford, IL
[quote] From: jdmcbean(at)kitfoxaircraft.com
Date: Sun, 20 Jan 2008 15:19:22 -0700
.ExternalClass .EC_shape {;} .ExternalClass EC_p.MsoNormal, .ExternalClass EC_li.MsoNormal, .ExternalClass EC_div.MsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman';} .ExternalClass a:link, .ExternalClass EC_span.MsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited, .ExternalClass EC_span.MsoHyperlinkFollowed {color:blue;text-decoration:underline;} .ExternalClass EC_span.EmailStyle18 {font-family:Arial;color:navy;} .ExternalClass EC_div.Section1 {page:Section1;} .ExternalClass EC_p.MsoNormal, .ExternalClass EC_li.MsoNormal, .ExternalClass EC_div.MsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman';} .ExternalClass a:link, .ExternalClass EC_span.MsoHyperlink {color:blue;text-decoration:underline;text-underline:single;} .ExternalClass a:visited, .ExternalClass EC_span.MsoHyperlinkFollowed {color:blue;text-decoration:underline;text-underline:single;} .ExternalClass EC_p.MsoAutoSig, .ExternalClass EC_li.MsoAutoSig, .ExternalClass EC_div.MsoAutoSig {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman';} .ExternalClass p {margin-right:0in;margin-left:0in;font-size:12.0pt;font-family:'Times New Roman';} .ExternalClass pre {margin-bottom:.0001pt;tab-stops:45.8pt 91.6pt 137.4pt 183.2pt 229.0pt 274.8pt 320.6pt 366.4pt 412.2pt 458.0pt 503.8pt 549.6pt 595.4pt 641.2pt 687.0pt 732.8pt;font-size:10.0pt;font-family:'Courier New';} .ExternalClass EC_p.NormalWeb1, .ExternalClass EC_li.NormalWeb1, .ExternalClass EC_div.NormalWeb1 {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman';} .ExternalClass EC_p.NormalWeb2, .ExternalClass EC_li.NormalWeb2, .ExternalClass EC_div.NormalWeb2 {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman';} .ExternalClass EC_p.HTMLPreformatted1, .ExternalClass EC_li.HTMLPreformatted1, .ExternalClass EC_div.HTMLPreformatted1 {margin-bottom:.0001pt;tab-stops:45.8pt 91.6pt 137.4pt 183.2pt 229.0pt 274.8pt 320.6pt 366.4pt 412.2pt 458.0pt 503.8pt 549.6pt 595.4pt 641.2pt 687.0pt 732.8pt;font-size:10.0pt;font-family:'Courier New';} .ExternalClass EC_p.NormalWeb3, .ExternalClass EC_li.NormalWeb3, .ExternalClass EC_div.NormalWeb3 {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman';} .ExternalClass EC_p.HTMLPreformatted2, .ExternalClass EC_li.HTMLPreformatted2, .ExternalClass EC_div.HTMLPreformatted2 {margin-bottom:.0001pt;tab-stops:45.8pt 91.6pt 137.4pt 183.2pt 229.0pt 274.8pt 320.6pt 366.4pt 412.2pt 458.0pt 503.8pt 549.6pt 595.4pt 641.2pt 687.0pt 732.8pt;font-size:10.0pt;font-family:'Courier New';} .ExternalClass EC_p.ecmsonormal, .ExternalClass EC_li.ecmsonormal, .ExternalClass EC_div.ecmsonormal {margin-right:0in;margin-left:0in;font-size:12.0pt;font-family:'Times New Roman';} .ExternalClass EC_span.EmailStyle25 {color:navy;} (at)page Section1 {size:8.5in 11.0in;} .ExternalClass EC_div.Section1 {page:Section1;}
Fly Safe !!
John & Debra McBean
208.337.5111
Posted: Sun Jan 20, 2008 3:45 pm Post subject: Aluminum Belly Pan |
Jim, Thanks for the picture. I will fabricate some of those clips. What brand epoxy do you recommend? Pat Reilly Mod 3 Rebuild Rockford, iL
[quote] From: jezim(at)pro-ns.net
Subject: Re: Kitfox-List: Re: Aluminum Belly Pan
Date: Sun, 20 Jan 2008 14:34:14 -0600
Jim Z
Series 5 0-200
Covering.
Posted: Sun Jan 20, 2008 3:58 pm Post subject: Aluminum Belly Pan |
Darin, Yes I don't think putting an aluminum belly pan on would be difficult. Looks easier than fabric covering. Thanks for the reference to Hysol epoxy. I didn't know what brand to use. I think a 2 piece belly pan would be easiest. Front one from firewall 1/2 way back, then another slipped under the front one to cover the last 2 feet. Removed, it would facilitate easier bungee access also. .020 Alcad aluminum would weigh 3 1/2 pounds and cost $50. It seems like a no brainer to me.
| Quote: | Subject: Kitfox-List: Re: Aluminum Belly Pan
Date: Sun, 20 Jan 2008 11:50:40 -0800
--> Kitfox-List message posted by: "darinh" <gerns25(at)netscape.net>
Pat,
John hit one reason on the head and that is introducing moisture into the chromoly tubing. Once this steel gets wet, it will rust pretty fast and this will be corrosion you will never see until it is too late. Another reason is strength. I am a structural/Civil engineer and anytime you put a hole in something, you introduce concentrated stress points around the holes. Granted round holes are better than sharp edges but not hole is better. The tubing along the bottom of the fuse will see some pretty good loads especially while landing so I would go for a different attachment method. I would be easy enough to fab brackets that are glued with Hysol to the structure and then rivet or rivnut (that way it is removable) to those. The more I talk about this, the easier is seems like it would be and maybe I will undertake the mod as I am at that point now.
Dave,
I have seen sticks, rocks and other debris go through fabric many times. The desert environment of Southern Utah is especially notorious for this. Wheels often kick up rocks and alot of them are sharp shale and sandstone chips that are razor sharp.
I think adding the skin is a great idea!
Darin Hawkes
Series 7 (under Construction)
914 Turbo
Kaysville, Utah
http://forums.matronics.com/viewtopic.php?p=159416#159416
&g========================>
dave
Posted: Sun Jan 20, 2008 4:09 pm Post subject: Re: Aluminum Belly Pan |
| Quote: | I think that I would be more concerned about the radiator on the Rotax installs catching debris than the fabric. And if you want a "skid plate " just use somthing thin like 016 and ADEL clamps.
when you get done armouring your aircraft get some film of why you need it , that would be the best part to see what you are doing to warrant this
John and Darin covered the most important points with regard to the 4130 tubing.
Whats about the radiator ?
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
darinh
Posted: Sun Jan 20, 2008 5:41 pm Post subject: Re: Aluminum Belly Pan |
Pat,
The Hysol you want is 9460 and is available from John. Like you said, it is best to adhere to bare metal that has been cleaned and prepped for adhesive.
Dave,
I don't have to worry about the radiator as on the 7 it is inside the cowl...on my Model 3 it was under the cabin and I had it in the radiator fairing. I had a bunch of chips out of the fiberglass fairing but luckily never had anything get inside and puncture it.
_________________ Darin Hawkes
Series 7
914 Turbo
Kaysville, Utah |
JohnA
Posted: Sun Jan 20, 2008 5:51 pm Post subject: Aluminum Belly Pan |
I've been following this thread with interest. I see any number of uses for tabs like that from belly pans to mounts for an autopilot. Where can such aluminum extrusion be found?
John Alexander
Woodland, CA
On Sun, 20 Jan 2008 14:34:14 -0600, Zimmermans wrote > A friend is building a series 5 and so am I. His kit came with an aluminum extrusion to use to cut out clips to attach the aluminum pan under the rudder pedals. He had me cut them for him and here is a picture of the extra one. This is the second plane that I have seen use them. They get epoxied to the tubes, then either a rivet or screw holds the aluminum pan. > Jim Z > Series 5 0-200 > Covering. [quote][b]
_________________ John Alexander
Woodland, CA |
Posted: Sun Jan 20, 2008 6:05 pm Post subject: aluminum Belly Pan |
On 20-Jan-08, at 8:31 AM, Lynn Matteson wrote:
I have a Grove gear, and it seems like there must be a bit of drag on
the screws, slide the front of the belly pan under the firewall flap,
and screw it back down. then slope the belly pan down under the Grove
feet long, and this would streamline, to some extent, the Grove gear.
A fellow lister has a Model V, and the builder of that plane actually
Lynn
Just happens that I had the same thought as you that the Grove gear
area would create an area of extra drag between the gear and the
belly. I just finished fabricating a small belly pan which will be
attached at the front under the firewall flap using screws into a 1/2
x 3/4 wood cross brace which is in turn held to the fuse by screws
through the floorboards. (i.e. no holes in tubing.)
At the rear I have drilled and tapped a couple of holes into the
round aluminum gear retainers and then attached an aluminum angle
across the width of the fuselage. The bottom of the angle is flush
with the bottom of the Grove gear.
A couple of small photos attached.
Jim Corner
Model 2, 582,. Ivo med !FA, 1100 hrs
Model 5 under construction
Calgary, AB
<pre><b><font size=3D2 color="#000000" face=3D"courier new,courier">
31.5 KB |
661 Time(s) |
38.74 KB |
663 Time(s) |
11.84 KB |
587 Time(s) |
Jimz
Posted: Sun Jan 20, 2008 6:19 pm Post subject: Aluminum Belly Pan |
Hysol 9460 John Mcbean has it.
rjdaugh
Posted: Sun Jan 20, 2008 7:53 pm Post subject: aluminum Belly Pan |
Hey guys,
Don't for get that the grove gear moves below the center of the cockpit.
The center moves down as the wheels flex up. Just be sure to design for
it if you are fairing it in. I like the access that a removable pan would
allow. I have had no problems (yet!) with holes from sticks or stones.
Randy
_________________ Randy
Kitfox 5/7 912S
Black Hills, South Dakota |
avidfox
Posted: Sun Jan 20, 2008 8:12 pm Post subject: aluminum Belly Pan |
On Jan 20, 2008 10:52 PM, Randy Daughenbaugh <rjdaugh(at)rapidnet.com (rjdaugh(at)rapidnet.com)> wrote:
| Quote: | --> Kitfox-List message posted by: "Randy Daughenbaugh" < rjdaugh(at)rapidnet.com (rjdaugh(at)rapidnet.com)>
Hey guys,
Randy |
Go here for a video demo of what Randy is speaking of....
http://www.groveaircraft.com/drptst.html
Here is Grove's site a w\picture of flex.
[quote]http://www.groveaircraft.com/droptest.html #
Lynn Matteson
Posted: Mon Jan 21, 2008 5:31 am Post subject: Aluminum Belly Pan |
The brand that was prevalent when I built in '04-06 was Hysol. It
looks a LOT like J-B Weld, and some have suggested that it is, but
I'm not sure. I'd rather see the name that I trust on the can than
wish later that I had. I'm sure John McBean supplies Hysol, or
locally you can probably get it at an industrial supplier.
Lynn Matteson
flying w/460+ hrs
On Jan 20, 2008, at 2:57 PM, patrick reilly wrote:
| Quote: | Lynn, I like the idea of tabs to secure the belly pan. I also like
Rockford, IL
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Michael Logan
Posted: Mon Jan 21, 2008 6:48 am Post subject: aluminum Belly Pan |
I faired my Grove gear in using plywood ribs epoxied to the tubing. In
front of the gear, I covered the ribs with aluminum, which provides the
ground plane for the transponder. Aft of the gear I used fabric like the
rest of the plane. The fabric is just as tough, if not tougher than the
aluminum and does not dent. The gear under the fuselage is not covered so
that it can flex.
Mike Logan
Series 5
_________________ Mike Logan
Fredericksburg, VA |
Lynn Matteson
Posted: Mon Jan 21, 2008 7:05 am Post subject: aluminum Belly Pan |
Jim-
Does your pan extend beyond the Grove gear to the rear? If not, it
would seem like you'd get some turbulence behind the gear if the pan
just quit at the gear. I thought I'd slope my pan from the firewall
flap area down to below the gear, then slope it back up to where it
would again contact the fuse's fabric, and be held in place there by
the aforementioned machine screws and Hysol'ed clips inside the fuse.
Lynn Matteson
flying w/460+ hrs
On Jan 20, 2008, at 9:02 PM, Jim Corner wrote:
on that, where the air passes between the belly of the plane and
the gear. I have thought of putting a belly pan in that area, using
the screws that hold the bottom portion of the firewall...the
horizontal "flap"...to hold the front of the belly pan.
Lynn
be attached at the front under the firewall flap using screws into
a 1/2 x 3/4 wood cross brace which is in turn held to the fuse by
screws through the floorboards. (i.e. no holes in tubing.)
Jim Corner
Calgary, AB
N369LM |
