Converting Russian hose to U.S.
kregg(at)balancemyprop.co
PostPosted: Thu Jan 17, 2008 10:14 am    Post subject: Converting Russian hose to U.S. Reply with quote
Recently I added fuel flow to a Yak 50 and a 52. Converting or upgrading the Russian hose to a US hose, 306 aeroquip or 111 stratoflex from the banjo fitting can be a pain. So, I had a machine shop make some fittings to adapt the banjo fitting to a -8 hose fitting that simply remove the hose and screw on the adapter to make the change to a -8 hose.
Check this out
Kregg Victory
 Filesize:  197.04 KB
 Viewed:  420 Time(s)
