wgill10(at)comcast.net Guest
Posted: Tue Jan 15, 2008 7:42 pm Post subject: IFR GPS requirements |
Hello All,
I have a Bendix-King KLN 94 GPS (IFR certified unit) in an RV-7. During discussions with an FAA inspector, I was told that I was not allowed to use this unit for IFR use until I completed a 337 form with a field approval, and completed the required test flight. I was not aware that the experimental ships had to jump through the same hoops as the Type Certificated aircraft. Can this possibly be true? I welcome all input on this subject.
RV-7
Lee’s Summit, MO
nuckolls.bob(at)cox.net Guest
Posted: Tue Jan 15, 2008 8:17 pm Post subject: IFR GPS requirements |
At 09:39 PM 1/15/2008 -0600, you wrote:
| Quote: | Hello All,
this subject.
It would be interesting to see who he recommends for
an IA to sign this off! Assuming you can get it submitted,
it would be interesting to watch what happens to the document
once it hit the appropriate offices for approval and filing.
337's are the equivalent of a one-time STC against a particular
certificated airframe.
The guys here tell me to install it, go fly it, satisfy yourself
that it is functioning as advertised and be done with it. Be
cautious about getting into any serious discussions with
a bureaucrat.
BobsV35B(at)aol.com Guest
Posted: Wed Jan 16, 2008 1:18 am Post subject: IFR GPS requirements |
Good Morning Bill,
I agree with 'Lectric Bob's comment, but may I add a bit more?
What it basically amounts to is that you are the certifying agent. As long as the equipment operates in the manner required to meet the IFR requirements, you are good to go. However, that does seem to mean that you should do the checks that would be required for the flight testing to assure yourself that the set is working properly. Just follow the directions given in the installation manual for the test flight and so certify in the ship's papers.
I don't have the regulations memorized, but EAA has issued a paper on the subject of IFR certification of experimental aircraft. It may have been authored by Earl Lawrence, but I am not sure. Hopefully, someone more knowledgeable than I will pipe up with a better reference.
In any case, don't get in an argument with a local FSDO inspector.
Remember, even though most of them are great guys who want to do a good job, they are still at the very bottom of the food chain.
Just listen and then do what you want! You are the responsible party. No arguments needed.
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
628 West 86th Street
Downers Grove, IL 60516
630 985-8502
Stearman N3977A
Brookeridge Air Park LL22
In a message dated 1/15/2008 9:44:48 P.M. Central Standard Time, wgill10(at)comcast.net writes:
Hello All,
RV-7
Lee’s Summit, MO
Start the year off right. Easy ways to stay in shape in the new year.
Posted: Wed Jan 16, 2008 3:17 am Post subject: IFR GPS requirements |
This inspector said he has done over 50 field inspections via 337 in
experimental aircraft in the Kansas City area. He did not say who the
submitting agency was, but I believe it was a repair station that he has
oversight responsibility. Strange. I will take everyone's advice and
quietly stay back away from the FAA and proceed. I have done a flight
test in visual conditions performing GPS approaches (as well as LOC/ILS
approaches) and all went great. Thanks for your input.
Peter Laurence
Posted: Wed Jan 16, 2008 5:33 am Post subject: IFR GPS requirements |
I did a bit of research on this subject last year. The FAA inspector is WRONG!
Peter Laurence
bakerocb
Posted: Wed Jan 16, 2008 6:10 am Post subject: IFR GPS requirements |
1/16/2008
Hello Bill, Avoid that poor soul -- he has not been around long enough or
cared enough to learn that type certificated aircraft and amateur built
experimental aircraft are treated very differently in the FAA's paperwork
system.
What he has described in the way of paperwork approval just simply does not
apply to your airplane.
Here is a quote from the signature section of the FAA Form 337:
"I certify that the repair and/or alteration made to the unit(s) identified
in item 5 above and described on the reverse or attachments hereto have been
made in accordance with the requirements of Part 43 of the U.S. Federal
Aviation Regulations and that the information furnished herein is true and
correct to the best of my knowledge."
And here is a quote from FAR Part 43.1:
"(b) This part does not apply to any aircraft for which the FAA has issued
an experimental certificate, unless the FAA has previously issued a
different kind of airworthiness certificate for that aircraft."
Since part 43 does not apply to amateur built aircraft issued a Special
Airworthiness Certificate in the Experimental Category for the purpose of
operating amateur-built aircraft (FAR 21.191 (g)) how can one properly
comply with the signature certification requirement on the FAA Form 337?
Several years ago a poster described his mistaken attempt to comply with all
FAA type certificated regulatory and advisory circular requirements for the
IFR GPS installation in his amateur built experimental airplane. He even
flew a test flight with a terrified FAA inspector who spent the entire
flight frantically looking out the window in fear of a mid air collision.
The entire effort was wasted because no FAA agency or procedure for the
approval existed -- just initial erroneous assumptions by uninformed FAA
employees.
'OC' Says: "The best investment we can make is the effort to gather and
understand knowledge."
From: "William Gill" <wgill10(at)comcast.net>Subject: IFR GPS requirements
Date: Jan 15, 2008
Hello All,
this subject.
RV-7
Lee's Summit, MO
jindoguy(at)gmail.com Guest
Posted: Wed Jan 16, 2008 6:50 am Post subject: IFR GPS requirements |
Peter, et al, It depends on what the inspector wrote into you ops limits. If he referenced 91.205 as a requirement for IFR flight, then you must get the system tested by an FAA certified shop. If not you can proceed as you wish.
In the Ops Limits I received yesterday, Item 11:
"After completion of phase 1 testing, unless appropriately equipped for night and/or instrument flight in accordance with 91.205, this aircraft is to be operated VFR day only."
Rick Girard
On Jan 16, 2008 7:27 AM, Peter Laurence <Dr.Laurence(at)mbdi.org (Dr.Laurence(at)mbdi.org)> wrote:
[quote] Bill
Peter Laurence
Posted: Wed Jan 16, 2008 7:07 am Post subject: IFR GPS requirements |
Good Morning Rick,
That is exactly the way it should read!
The next step is to equip it in accordance with the specifications of 14 CFR Part 91, section 91.205 for the type of flight you wish to conduct and make an entry into the ship's papers stating that you have done so.
No need to change anything on your ops spec and no need to contact any Fed.
Just install the equipment and test it in accordance with the manufacturers directions. As long as you have the proper equipment, just hop in the machine and go fly IFR and/or night
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
630 985-8502
Stearman N3977A
In a message dated 1/16/2008 8:53:03 A.M. Central Standard Time, jindoguy(at)gmail.com writes:
| Quote: | In the Ops Limits I received yesterday, Item 11:
Rick Girard
Posted: Wed Jan 16, 2008 7:34 am Post subject: IFR GPS requirements |
At 05:13 AM 1/16/2008 -0600, you wrote:
What he "has done" compared to what he is supposed
"to do" may have some serious disconnect here. But
then KC is the home of the Small Aircraft Directorate.
As Thomas Paine noted many moons ago: When subject to
dictatorships, monarchy, or oligarchy, at least we
KNOW the source from which our irritations emanate.
With democracies, we can only just begin to perceive
the major players in a mass of individuals who's
power needs to be metered through constitutional
boundaries. It would not surprise me that what
was recited to you by this individual was a portent
of things to come. After all, the FAA is only here
to help! With the numbers of TC light aircraft
dwindling, he's only looking for more things to
do.
The prohibition against night and/or IFR flight
speaks only to having the necessary equipment under
part 91 rules to safely conduct such operations.
It does not speak to whether it's silver plated,
platinum plated, or holy-watered by individuals
knighted by the oligarchy.
A wise mentor of many years ago once advised me
never to ask a question of anyone with power unless
I already knew what that answer would be. Seems
like a silly notion but as I grew older, it made
a lot of sense. Folks with much power over my life
leave a trail of activities that can be researched
for predictors of their answers. If you don't like
what the answer is going to be, then don't ask it.
It many cases, the expenditure of $time$ to receive
permission far exceeds the $time$ expended to
beg forgiveness.
So sifting through the pile of wreckage after
bagging your remains they discover that your
GPS was not holy-watered . . . what are they
going to do, fine you?
aerobubba(at)earthlink.ne Guest
Posted: Thu Jan 17, 2008 6:03 am Post subject: IFR GPS requirements |
Hi Bill et al-
Re: >Hello Bill, Avoid that poor soul -- he has not been around long
enough or
| Quote: | cared enough to learn that type certificated aircraft and amateur built
system.
While I greatly appreciate and highly regard and respect the source of that
comment, I couldn't disagree more. If this inspector has run 50
unnecessary 337's through the system, he has cost a lot of people a lot of
money, spread misinformation across the system, and will no doubt cause
other improperly educated or motivated inspectors to take the
'conservative' (ignorant) route at our collective expense. In other words,
there has been a gross misuse of governmental power. These kinds of topics
have gone to DC and back via OSH, and we have the tools to correct the
problem you are facing.
My personal experience with an amateur built rule hose-up was to be very
(politely) clear with the person involved about the nature and basis for
our disconnect, and then call OSH with the details. Within 24 hours they
had achieved understanding with the head of the directorate involved, and
within another 24 the fed involved had been re-educated. That ended the
problem for me, and, presumably, everyone who came along after.
Also, the feds now have a program to handle customer service issues in
house. As I understand it, it's the equivalent of 'let me speak to your
supervisor', although I don't recall the precise terminology. Mike, can
you fill us in?
While I don't advocate getting into hostile conflicts with The Man, I
strongly urge you (and anyone else having bogus reg interpretation issues)
to fight the good fight with the resources we have developed and paid for
through our EAA dues and those gate fees at OSH we are all unhappy about.
Heck, Brian got a law in Jacksonville repealed with a little help from his
friends. What's one confused inspector?
glen matejcek
aerobubba(at)earthlink.net
bakerocb
Posted: Thu Jan 17, 2008 11:04 am Post subject: IFR GPS requirements |
1/17/2008
Hello Rick, Thanks for your input and interest in this subject. You wrote:
1) "It depends on what the inspector wrote into you ops limits."
The FAA Inspector or DAR is directed by FAA Order 8130.2_ (edition F, with
change 3 incorporated is the current version) what to write into the
Operating Limitations when issuing the Special Airworthiness Certificate for
an amateur built experimental aircraft. His prerogative to ad lib in this
specific area (IFR GPS requirements) is extremely limited to non existent.
2) "If he referenced 91.205 as a requirement for IFR flight, then you must
get the
system tested by an FAA certified shop." and "If not you can proceed as you
wish."
These two statements are misleading / incorrect.
2A) First off, There is no "if" about it. He most certainly will reference
91.205 as a requirement for IFR flight. He will do this by incorporating
this statement into the Operating Limitations: "After completion of phase 1
accordance with 91.205, this aircraft is to be operated VFR day only." See
paragraph 1 above.
2B) Second, Other than the normal regulatory requirements for periodic
inspections of the altitude encoder, the altimeter, and the transponder
(these inspection requirements also apply to type certificated aircraft)
there is no requirement to "get the system tested by an FAA certified shop."
2C) Third, It is not clear what you mean when you write the word "system".
I have prepared a table that serves as a quick reference on this subject:
MINIMUM INSTRUMENT AND EQUIPMENT REQUIREMENTS FOR POWERED AMATEUR BUILT
EXPERIMENTAL AIRCRAFT.
I will email a copy of this table to any reader requesting it.
Time: 06:50:54 AM PST US
Subject: Re: AeroElectric-List: IFR GPS requirements
Rick Girard
rv9jim(at)juno.com Guest
Posted: Thu Jan 17, 2008 1:40 pm Post subject: IFR GPS requirements |
Hi Bob,
Could you send me a copy of the list? I am setting up for lite
IFR but having the right stuff is important also.
Jim Nelson
N15JN
RV9-A
bhcishere(at)ca.rr.com Guest
Posted: Thu Jan 17, 2008 2:05 pm Post subject: IFR GPS requirements |
I could sure use a copy of your table.
Thank You,
Bryan
Posted: Thu Jan 17, 2008 3:14 pm Post subject: IFR GPS requirements |
Good Afternoon OC,
I would appreciate a copy of your listing!
BobsV35B(at)aol.com (BobsV35B(at)aol.com)
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
630 985-8502
Stearman N3977A
In a message dated 1/17/2008 1:07:41 P.M. Central Standard Time, bakerocb(at)cox.net writes:
| Quote: | MINIMUM INSTRUMENT AND EQUIPMENT REQUIREMENTS FOR POWERED AMATEUR BUILT
hammer408(at)comcast.net Guest
bakerocb
Posted: Fri Jan 18, 2008 6:27 am Post subject: IFR GPS requirements |
1/18/2008
Hello Glen, You are absolutely correct and I apologize for that moment of
weakness when I wrote to just avoid the ignorant bureaucrat.
If we don't (politely) confront these people who are misusing their
position, either out of ignorance or ego, we will suffer further abuses down
the line.
Subject: AeroElectric-List: RE: IFR GPS requirements
Hi Bill et al-
enough or
system.
you fill us in?
glen matejcek
