David.Miller(at)cmworks.c Guest
Posted: Tue Jan 15, 2008 6:39 am Post subject: Cold Air Induction |
Is anyone familiar with cold air induction on a 540? What is it, what are the advantages and disadvantages, what's the cost, where can get the equipment, how difficult is it to installation and what modifications are required, and most importantly; is it worth it ?
David Miller
Lexington, TN
HRII under construction
| | - The Matronics Rocket-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Rhonda(at)bpaengines.com Guest
Posted: Tue Jan 15, 2008 7:24 am Post subject: Cold Air Induction |
[i]David:[/i]
[i]We have a cold air induction system for the parallel head and angle head 540 and 580. Our system is a lightweight magnesium sump and plenum. The system has seamless stainless intake pipes, and the system is shipped complete with everything you need to install the system on your engine. [/i]
[i]The engine becomes forward facing induction resulting in greater inlet air pressure (ram air recovery effect), and if you get a larger throttle body, the increase in air flow is substantial. The system also removes the inlet air from the oil sump, rerouting it through the separate plenum. We see a 15-20 hp increase with the cold air system on stock compression engines. These numbers are verifiable on our dynomometer. This is the cold air sump used in virtually all experimental competitive aerobatic/race parallel 540 engines in use today. [/i]
[i]The biggest disadvantage is that with more air and colder air, you are going to burn more fuel. You may also have to make cowling modifications for the system on your airplane. Hope you find this information helpful.[/i]
[i]Rhonda Barrett-Bewley[/i]
[i]Barrett Precision Engines, Inc.[/i]
[i]Tulsa[/i][i], OK 74115[/i][i][/i]
[i](918) 835-1089 phone[/i]
[i](918) 835-1754 fax[/i]
[i]www.barrettprecisionengines.com [/i]
From: owner-rocket-list-server(at)matronics.com [mailto:owner-rocket-list-server(at)matronics.com] On Behalf Of David Miller
Sent: Tuesday, January 15, 2008 8:38 AM
To: rocket-list(at)matronics.com
Subject: Cold Air Induction
David Miller
Lexington, TN
| Quote: | | http://www.matronics.com/Navigator?Rocket-List | 0123456789
mdatp(at)bellsouth.net Guest
Posted: Tue Jan 15, 2008 6:19 pm Post subject: Cold Air Induction |
David, Not sure if it’s worth it or not. I raced a fellow that had 10:1pistons, Barrett cold air induction, no air filter and a Sky Dynamics fancy exhaust. I’m running a Barrett engine with 9:1 pistons, filtered air and nothing else but attention to aerodynamic detail and I smoked him in a flat out race. If you’re going for speed, fair the plane well and make it straight.
Jim Frank
Atlanta
F1with 110hrs
on 1/15/08 9:38 AM, David Miller at David.Miller(at)cmworks.com wrote:
| Quote: | Is anyone familiar with cold air induction on a 540? What is it, what are the advantages and disadvantages, what's the cost, where can get the equipment, how difficult is it to installation and what modifications are required, and most importantly; is it worth it ?
David Miller
Lexington, TN
Email Forum -
ist">http://www.matronics.com/Navigator?Rocket-List
; - MATRONICS WEB FORUMS -
matronics.com
;- List Contribution Web Site -
; -Matt Dralle, List Admin.
://www.matronics.com/contribution
Lee Logan
Posted: Tue Jan 15, 2008 6:49 pm Post subject: Cold Air Induction |
James: Sounds like you have your mojo working!! Bring that speedster down here one of these days!!
Best wishes!
Lee...
f1rocket(at)telus.net Guest
Posted: Fri Jan 18, 2008 1:28 am Post subject: Cold Air Induction |
David,
The other main disadvantage is that you will have to get a custom exhaust made.
Then build a new cowling to house it all.
Jeff
Quoting Rhonda Bewley <Rhonda(at)bpaengines.com>:
| Quote: | David:
engine.
Tulsa, OK 74115
(918) 835-1754 fax
<http://www.barrettprecisionengines.com/>
Miller
David Miller
Lexington, TN
