msm_9949(at)yahoo.com Guest
Posted: Sun Jan 13, 2008 10:41 am Post subject: Engine Choices |
Ok guys. I've started the spreadsheet. Add to and improve it as you can.
Marco Menezes
Model 2 582 N99KX
 Download |
| Filename: |
Engine_choices.xls |
21.5 KB |
| Downloaded: |
556 Time(s) |
pwmac(at)sisna.com Guest
Posted: Sun Jan 13, 2008 11:47 am Post subject: Engine Choices |
Hi Marco,
Keep digging. Here are my comments:
A word of caution about the weights. I have been on this list since
day 1 and I still doubt the weights quoted. For example is the
coolant included and what about the oil? Then there is the radiator
and oil cooler. No idea if these things are ever included in engine
weight. Then every guy has minor differences and may use an aluminum
vs copper radiator or not even use the recommended oil cooler. Do the
j guys always use the tiny oil cooler or the hard to install air box?
Do the guys quoting weight include the engine mount, if so is it the
heavy or light R912 one?
Probably no a solution to this weight delemia.
Anyway maybe you can add the prop rpm for the two different gear
boxes for the R912 engines, since one of the advantages of the R912
is the lower prop speed, thus more efficiency and less noise. Just
something to keep in mind. I cannot quantify this.
Cruise Hp & fuel burn are the long term things to make you happy.
Lower initial cost is great for getting started. Reserve power like
the J3300 has is worthwhile, but the higher fuel burn is the downside
(not IMO).
Great customer support from multiple service centers and factory is
unequalled with Rotax. Certainly a real bonus. A personal decision.
LOL, Paul W
At 10:41 AM 1/13/2008, you wrote:
| Quote: | Ok guys. I've started the spreadsheet. Add to and improve it as you can.
Marco Menezes
Model 2 582 N99KX
jdmcbean(at)kitfoxaircraf Guest
Posted: Sun Jan 13, 2008 12:01 pm Post subject: Engine Choices |
Marco,
TBO on Jabiru is 2000 bottom and 1000 top…
TBO on the Rotax is 1500
<![if !supportEmptyParas]> <![endif]>
AUTOTEXTLIST \s "E-mail Signature" <![endif]-->Fly Safe !!
John & Debra McBean
208.337.5111
www.kitfoxaircraft.com
"It's not how Fast... It's how Fun!"
<![endif]--><![if !supportEmptyParas]> <![endif]>
-----Original Message-----
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Marco Menezes
Sent: Sunday, January 13, 2008 11:41 AM
To: Matronics.com
Subject: Engine Choices
Marco Menezes
Model 2 582 N99KX
av8rps
Joined: 05 Jan 2008 Posts: 33 Location: Central Wisconsin
Posted: Sun Jan 13, 2008 2:20 pm Post subject: Re: Engine Choices |
(Marco says "Ok guys. I've started the spreadsheet. Add to and improve it as you can...")
Marco,
One thing that I would suggest changing is the column heading words for column E. The current "Pwr & Wght" should be changed to "Hp per LB". Just words I know, but I think it better exemplifies which engine is producing the most power per lb, the thing that is probably the single most important thing to consider when comparing engines, (aside from actual prop thrust - which as of right now we don't have a good way to know).
The fuel burn for the 912 I know is not right. I'll pull my manuals next time I'm at the airport so we can fix that. It also would be nice to add the 914 Rotax, as that is hands down Rotaxes real power house.
Nice Job! Very nice spreadsheet for those deciding on an engine.
Paul Seehafer
_________________ Model IV-1200 912ul Amphib
Avid Flyer Sn#1 and Sn#26
Highlander 912s taildragger
Lake Amphibian
Central Wisconsin
paul676@tds.net |
av8rps
Posted: Sun Jan 13, 2008 2:34 pm Post subject: Re: Engine Choices |
(Paul W says "A word of caution about the weights. I have been on this list since day 1 and I still doubt the weights quoted. For example is the
coolant included and what about the...")
Paul,
I too don't agree with how the weights come out for all the engines as the mfrs have stated them. In another topic area I just asked Lynn Matteson to compare his Jabiru 2200 powered Model IV against my 912ul powered Model IV for empty weights and options, as I seem to recall our airplanes are similar weights. And if that's true, considering all the options I have on my airplane (its far from a light one), the Jabiru is really no lighter by the time it is installed.
The same seems to be true of the aircraft engines as well, with the mfrs stating weights that are a bit deceiving.
So the true test is for a bunch of us to post our empty weights for our various powered Kitfoxes, and then to give details as to what options and models they are so those making engine choices can make an educated decision based on facts. Or at least averages.
What do you think?
Hey Marco! Are you interested in setting up a spreadsheet for that?
Paul Seehafer
Lake Amphibian
Central Wisconsin
paul676@tds.net |
Posted: Sun Jan 13, 2008 3:20 pm Post subject: Engine Choices |
The best weight data will come from a guy that does a swap and then
weighs the plane before & after.
However the KFs seem to fly fine with all the choices, so maybe the
numbers are not as important as we all make them??? Perfection is
hard to achieve. But it would be nice to get close.
I remember in the old days when Murle W did a R912 swap to sube and
gave us real data.
Paul W
At 02:34 PM 1/13/2008, you wrote:
Paul,
What do you think?
Paul Seehafer
Avid Flyer
Lake Amphibian
Central Wisconsin
paul676(at)tds.net
http://forums.matronics.com/viewtopic.php?p=157866#157866
Lynn Matteson
Posted: Sun Jan 13, 2008 3:31 pm Post subject: Engine Choices |
At the risk of becoming annoying (I know, I've already passed that
milestone), forget the airplanes! Weigh the freakin' engines!
Lynn Matteson
flying w/460+ hrs
On Jan 13, 2008, at 6:19 PM, paul wilson wrote:
the numbers are not as important as we all make them??? Perfection
is hard to achieve. But it would be nice to get close.
gave us real data.
Paul W
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Lynn Matteson
Posted: Sun Jan 13, 2008 3:32 pm Post subject: Engine Choices |
I'l repeat here what I said on another post..paraphrased...you can't
compare one empty Kitfox with another and blame the difference on the
engine. If you're going to compare weights, compare weights, not
calculated weights based on equipment, paint jobs, etc. No jury would
buy that argument. We need to get that anal bunch from NASCAR to send
some of their boys over to settle this one, I'm afraid.
Lynn Matteson
flying w/460+ hrs
On Jan 13, 2008, at 5:34 PM, av8rps wrote:
example is the
Paul,
installed.
What do you think?
that?
Paul Seehafer
Avid Flyer
Lake Amphibian
Central Wisconsin
paul676(at)tds.net
N369LM |
Posted: Sun Jan 13, 2008 8:58 pm Post subject: Engine Choices |
The data I've included is derived from supplier and manufacturer websites. (Sources are included as "comments"). But if anybody wants to correct or supplement based on their experience, or add still more engine options, great! Please have at it.
Hey . . . my plan was just to get the ball rolling. I'm not gonna do all the work.
av8rps <paul676(at)tds.net> wrote:
[quote]--> Kitfox-List message posted by: "av8rps"
Marco,
One thing that I would suggest changing is the column heading words for column E. The current "Pwr & Wght" should be changed to "Hp per LB". Just words I know, but I think it better exemplifies which engine is producing Be a better friend, newshound, and [quote][b]
Posted: Sun Jan 13, 2008 9:00 pm Post subject: Engine Choices |
Like I said Paul, if you think that would be useful, please have at it! Just add a few columns and fill them in.
av8rps <paul676(at)tds.net> wrote: [quote]--> Kitfox-List message posted by: "av8rps"
Paul,
I too don't agree with how the weights come out for all the engines as the mfrs have stated them. In another topic area I just asked Lynn Matteson to compare his Jabiru 2200 powered Model IV against my 912ul powered Model IV for empty weights and options, as I seem to recall our airplanes are similar weights. And if that's true, considering all the options I have on my airplane (its far from a light one), the Jabiru is really [quote][b]
av8rps
Posted: Mon Jan 14, 2008 5:35 am Post subject: Re: Engine Choices |
(Lynn Matteson says "At the risk of becoming annoying (I know, I've already passed that milestone), forget the airplanes! Weigh the freakin' engines!")
Lynn,
Don't get me wrong. I agree that weighing the complete and flyable engine packages would be best. But that would be quite an undertaking, not probable to happen anytime soon. Plus, as you said earlier it would be difficult to make certain it was done without having someones thumb on the scale, so to speak.
So my idea of using averages for various engines and models with options and equipment was just to provide those in question with that, an average they could expect if they built or bought one similar to the ones owners listed.
As an example; With as many 912 powered Kitfoxes out there, and all the information that has been shared here on the list, it has become pretty easy to come up with an average for a 912 model IV. Plain and simple, a 912 model IV as an average will run between 625 and 675 lbs. Light ones will be in the low 600's, and heavy ones in the 700 lb range. It's really as simple as that. I don't know about you, but if I was building and considering using a 912 that would be helpful information for me.
And if I were torn between the Jab and the 912, and I also knew the average for a Jabiru powered Model IV was in the same empty weight range, I'd probably start asking owners for performance numbers, once again trying to come up with an average of what I could expect.
Now if a builder really wanted to get scientific beyond this list of averages, having exact engine flying weights would be great. From that they could determine horsepower per pound numbers, which is really all that is important (unless the weight is just more than his airframe was designed for). But better yet, prop thrust per pound is the number I'd be looking for. And I'd make sure the prop used in the thrust test was appropriate to the airframe I was going to install the engine on (E.g.; prop that works good on a Sonex probably isn't the best prop for a Kitfox). So once again, I agree with your idea that it would be best to have accurate engine info in front of anyone trying to make a decision about engine choice. Unfortunately, all that information isn't available unless some great writer we know (big smile) takes on that arduous task.
But we do have Kitfoxes that are flying with a variety of engines, and options right now. So we have the ability to come up with good averages for empty weights, as well as performance. So the guy that just wants to keep building so he can get in the air as soon as possible can do so. He doesn't have to spend hours pouring over information, hoping what he thought was correct information works out like he planned. We already have gained the experience with our Kitfoxes, and have proven results. That can save builders a lot of time, and money most likely, while also providing them with an engine decision they will be happy with.
And for what it's worth, this is good banter for this list. While we might be boring some readers to death, or appear to be arguing the Jab vs the 912, I'm certain what has been discussed here has already been helping some to better make an engine decision.
Paul Seehafer
Lake Amphibian
Central Wisconsin
paul676@tds.net |
propellerdesign(at)tele2. Guest
Lynn Matteson
Posted: Mon Jan 14, 2008 6:47 am Post subject: Engine Choices |
Ok, Paul, I see your point. I just saw the task of comparing the
various components that we install, paint on, or otherwise stuff into
our planes as a pretty daunting job, and thought that weighing the
engine would be the simple way to do it.
I gotta admit, though, that when I started to think about building a
plane, cost was a pretty big factor. I had just retired, and knew how
much money I was going to have to play with, and figured I could buy
the plane outright, bring it home, and start (continue) to build it,
and as the monthly pension checks came in, start to decide how many
bean dinners could be substituted for steaks, and then decide on an
engine. Performance figures didn't enter my mind. During this time, I
found a 3-part Kitplanes magazine article that told of one builder's
story, and that's what helped me make a decision.
I'm pretty much a shade-tree mechanic, so this decision process was
in keeping with my level of thinking, and my way of life. Others will
take a different path to the decision-making process, I'm sure, armed
with the information from this list.
Keep up the good work.
Lynn Matteson
flying w/460+ hrs
On Jan 14, 2008, at 8:35 AM, av8rps wrote:
freakin' engines!")
Lynn,
could expect.
Paul Seehafer
Avid Flyer
Lake Amphibian
Central Wisconsin
paul676(at)tds.net
http://forums.matronics.com/viewtopic.php?p=157951#157951
N369LM |
Guy Buchanan
Posted: Mon Jan 14, 2008 8:50 am Post subject: Engine Choices |
At 05:35 AM 1/14/2008, you wrote:
| Quote: | We already have gained the experience with our Kitfoxes, and have
proven results.
Actually I believe you already have the results. Because of
the relatively large numbers there is a sort of "natural selection"
process at work in the Kitfox community. If you were to simply add
the numbers of engines of each type in each airframe you would see
the relative "value" of each engine, including all factors. Though it
would seem that new engines would be under-represented, that
under-representation reflects their relatively "unproven" status. As
engines become "proven" they take over the market, as the 912 did
from the 582, and as the Jabiru is presently doing to the Subaru and
VW. (No offense intended. Remember I fly a 582.)
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
Lynn Matteson
Posted: Mon Jan 14, 2008 9:41 am Post subject: Engine Choices |
Just a reminder of one example of the "natural selection" process at
work:
Recall that Beta came out with a superior tape recording process,
quality-wise, but wasn't able to pack enough tape into the cassette
so that bored housewives could go on vacation for three weeks and
record their favorite soaps each day. VHS won the battle by offering
such a tape at a much lower resolution, thus giving the public what
they wanted. These people were satisfied with mundane quality if it
meant getting their soaps recorded. VHS finally put Beta out of
business, because of sheer numbers, not quality.
(There was a sign that hung in my old workplace that said: "Give the
customer quality, whether they want it or not")
This is by no means a reflection (so far anyway) on the homebuilt
industry, just something to keep in mind when looking at the
"numbers"....remember, if you torture numbers enough, they will tell
you anything. : )
Lynn Matteson
flying w/460+ hrs
On Jan 14, 2008, at 11:36 AM, Guy Buchanan wrote:
> proven results.
it would seem that new engines would be under-represented, that
As engines become "proven" they take over the market, as the 912
did from the 582, and as the Jabiru is presently doing to the
Subaru and VW. (No offense intended. Remember I fly a 582.)
Guy Buchanan
San Diego, CA
N369LM |
Michel
Posted: Mon Jan 14, 2008 11:52 am Post subject: Engine Choices |
Since we are comparing engines, here is from my annual weight and
balances:
Kitfox 3, pretty much 'vanilla taste' with original tube gear, etc. and
Rotax 582: Empty weight: 236 kg. (520 lbs)
The same but with Jabiru 2200: 241 kg. (531 lbs)
That is only 11 lbs more. But the Jabiru, with 4 cylinders, has a own
CoG that is more forward that the 582. Still, moving the battery from
firewall to behind the seat was all it took to keep the same CoG for
the plane.
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200 ... (hum, why do I have a deja-vu?
