dwilde(at)clearwire.net Guest
Posted: Sat Jan 12, 2008 12:57 pm Post subject: Inspection Checklist |
All: Yesterday I went to get my Repairman Inspection Authorization from
the local FSDO. This took over an hour for some reason. Anyway while I
was there, he asked if I had a construction checklist for my airplane
(701). He said Zenith should have provided or made available one.
Apparently this checklist is something you sign or check off each time
you complete an assembly. I can find no such thing. Does anyone have a
clue what he was talking about?
Also he pointed out some errors my DAR made when he issued my Special
Airworthiness Certificate. Hopefully that will not come back to bite me
somehow.
I did receive my Inspection Authorization but it appears the FAA could
use some better organization to speed up the process. It is totally
asinine the amount of nitpicking they do or at least are required to do.
Dan Wilde
rroberts
Joined: 04 Sep 2006 Posts: 50 Location: Birmingham, AL USA
Posted: Sat Jan 12, 2008 1:26 pm Post subject: Re: Inspection Checklist |
Dan,
Looks like every FSDO might be different. Did mine via the US mail. The guy called me and wanted me to send in a copy of my builders log. About two weeks later, along came my certificate.
Painless.
Mine was the Atlanta FSDO.
_________________ Low & Slow
Rick
www.n701rr.com
www.ricksplace.info |
naumuk(at)alltel.net Guest
Posted: Sat Jan 12, 2008 1:54 pm Post subject: Inspection Checklist |
Dan-
There's a checklist at the start of each section of my 601HDS manual.
Wonder if that's what he's talking about? Definitely chickenshit, because
you could check things off before you ever completed them!
kmccune
Joined: 22 Sep 2007 Posts: 577 Location: Wisconsin, USA
Posted: Sat Jan 12, 2008 2:41 pm Post subject: Re: Inspection Checklist |
Why would you check off things that are not done/completed? Its your neck the check list is protecting.
_________________ “Always do what you are afraid to do.”
R.W. Emerson (1803-1882)
Dorothy McCune |
bryanmmartin
Posted: Sat Jan 12, 2008 3:46 pm Post subject: Inspection Checklist |
At the Detroit FSDO all he wanted to see is the construction logbook
with photos and the aircraft registration. You need to show evidence
that you were actually the person that built the airplane.
On Jan 12, 2008, at 2:02 PM, Dan wrote:
from the local FSDO. This took over an hour for some reason.
Anyway while I was there, he asked if I had a construction checklist
for my airplane (701). He said Zenith should have provided or made
available one. Apparently this checklist is something you sign or
check off each time you complete an assembly. I can find no such
thing. Does anyone have a clue what he was talking about?
Dan Wilde
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
n801bh(at)netzero.com Guest
For what it's worth my 801 kit had a complete assembly manual. At the end of each section there was a checklist and a place to sign off the sub assembly. Of course neither the FAA or the DAR even asked to look at it.
Ben Haas
N801BH
www.haaspowerair.com
-- Dan <dwilde(at)clearwire.net> wrote:
--> Zenith-List message posted by: Dan <dwilde(at)clearwire.net>
somehow.
Dan Wilde
================================================bsp; - ========================; - List Contribution Websp; &nb=====================================================
_____________________________________________________________
Financial Career Training - Click Here.
Posted: Sat Jan 12, 2008 3:48 pm Post subject: Inspection Checklist |
Not in the least. I just mentioned it to point out how ridiculous the system
is.
Over and out. Do not archive.
klr12(at)psu.edu Guest
Posted: Sat Jan 12, 2008 5:10 pm Post subject: Inspection Checklist |
Dan,
I know it's only semantics, but you did not get a "Repairman Inspection Authorization". Technically, there is no such privilege. You may perform a "Condition Inspection" on a specific aircraft built by you, the certificate holder as per FAR 65.104. Inspection Authorizations are only available to A&P mechanics who have been active for a minimum of 3 years.
Kevin Rupert
davgray(at)sbcglobal.net Guest
Posted: Sat Jan 12, 2008 6:36 pm Post subject: Inspection Checklist |
"Repairman Experimental Aircraft Builder" is the wording on the card indicating your authorization as a repairman.
On the back of the card it will list the specific aircraft that the card applies to.
My FAA rep emphasized the specific wording that needs to be entered into the aircraft log book on the annual condition inspections and the need to keep accurate records of deficiencies found and the work performed to remedy the situation.
Gary Ray
[quote] [b]
cj.tremblay(at)videotron. Guest
Posted: Sat Jan 12, 2008 7:26 pm Post subject: Inspection Checklist |
Hi Dan,
I got IPLs (Inspection Part List) sheets for my own plane CH640. It's a current process in the aeronautical and other industries for insure good process assembly. I find mine on Zenith Web Site. Look for yours. I attach one file example of mine to this email to show you what's it's look like.
Christian Tremblay
A guy who build a CH640 aircraft from plan
http://www.zodiac640.com/
-----Message d'origine-----
De : owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] De la part de Dan
Envoy : Saturday, January 12, 2008 2:03 PM
: Zenith List
Objet : Inspection Checklist
somehow.
Dan Wilde
 Download |
| Filename: |
CH640_-_AILERON_L-R.pdf |
9.4 KB |
| Downloaded: |
592 Time(s) |
ggower_99(at)yahoo.com Guest
Posted: Sun Jan 13, 2008 12:01 am Post subject: Inspection Checklist |
What we do, is that in each page of the contruction manual (the printed photo one) we hand print the date we finished each step in that page, in the upper corner.
Same did when we built the 701.
At the beguining of the 701 project, we used to put the time involved (hour or fraction) in each step-page, but was very dificult sometimes to remember to see the watch...
We finaly decided to record in a personal page, the time we spended (individualy) each day (efective work, no visits or day dreaming , that gives us a close estimate of the time and hours invested.
We make teams of two (in fact now two teams: Larry & Carlos and Me & Gary Jr), masters and helpers Also I am elected the "Project Manager", this is to read the manual and plans a few steps in advance to have everything ready and explain to "the Teams". All parts to use in the day, are located and get ready in the first minutes of each working day.
Each one of us decides one day at a time, what music we are going to hear while building. Soft drinks and snacks costs are devided in four, sometimes the visitors bring them, so we save some cash Fun and Team work is responsability of all of us
Saludos
Gary Gower
Flying from Chapala, Mexico.
701 912S
Now building the 601 XL, Jabiru 3300 .
Bill Naumuk <naumuk(at)alltel.net> wrote:
[quote]--> Zenith-List message posted by: "Bill Naumuk"
Dan-
Posted: Sun Jan 13, 2008 5:06 am Post subject: Inspection Checklist |
Hi Dan;
Perhaps he is referring to the FAA Form 8000-38 Fabrication/Assembly Operation Checklist. I attached a copy of the form.
Dan <dwilde(at)clearwire.net> wrote:[quote] --> Zenith-List message posted by: Dan
Also he Be a better friend, newshound, and
 Download |
| Filename: |
Faa_Form_8000-38_assy_checklist.doc |
204 KB |
| Downloaded: |
2013 Time(s) |
Posted: Sun Jan 13, 2008 9:28 am Post subject: Inspection Checklist |
To Christian and others. Thank you for the information. The inspector
was the first time I had heard of this checklist and it sounds like a
good idea, just a little late in my case.
I used the assembly manuals as a check and simply put them in a 3 ring
binder when I had completed each section. Hopefully this information
may help others earlier in the building process.
Dan Wilde
Christian Tremblay wrote:
*Hi Dan,*
*I got IPLs (Inspection Part List) sheets for my own plane CH640.
what's it's look like.*
*Christian Tremblay*
*A guy who build a CH640 aircraft from plan*
*http://www.zodiac640.com/*
mfrench601(at)yahoo.com Guest
Posted: Sun Jan 13, 2008 7:05 pm Post subject: Inspection Checklist |
You will find the construction checklist provided in the Zenith Buiders Manual with a list of assembly steps for each phase. There are also places for your signature and the inspectors.
Michael French
David Downey <planecrazydld(at)yahoo.com> wrote:
Hi Dan;
Dan <dwilde(at)clearwire.net> wrote: | Quote: | --> Zenith-List message posted by: Dan
Also he Be a better friend, newshound, and |
Be a better friend, newshound, and [quote][b]
