JetPilot
Posted: Fri Jan 11, 2008 11:59 am Post subject: VG's effect on Runway Leingth |
A picture is worth a thousand words, so below are a couple pictures.
First picture is my Kolbs runway without VG's, Second is my Kolbs runway with VG's. Any questions
| Runway my Kolb needed Without VG's |
180.95 KB |
784 Time(s) |
| Runway For my Kolb with VG's |
193.64 KB |
741 Time(s) |
Kolb MK-III Xtra, 912-S |
Posted: Fri Jan 11, 2008 1:33 pm Post subject: VG's effect on Runway Leingth |
Steve B's are those long blue ones.
On 11, Jan 2008, at 2:59 PM, JetPilot wrote:
jindoguy(at)gmail.com Guest
Posted: Fri Jan 11, 2008 1:35 pm Post subject: VG's effect on Runway Leingth |
So if you put on VG's you can't get the Kolb lined up with the runway?
Rick
On Jan 11, 2008 1:59 PM, JetPilot <orcabonita(at)hotmail.com (orcabonita(at)hotmail.com)> wrote:
[quote]--> Kolb-List message posted by: "JetPilot" < orcabonita(at)hotmail.com (orcabonita(at)hotmail.com)>
First picture is my Kolbs runway without VG's, Second is my Kolbs runway with VG's. Any questions [Wink]
http://forums.matronics.com/viewtopic.php?p=157518#157518
http://forums.matronics.com//files/runwaywithoutvgs_905.jpg [quote][b]
Posted: Fri Jan 11, 2008 2:28 pm Post subject: VG's effect on Runway Leingth |
If you need that long of a runway for your kolb you need a whole lot more
than just VGs.
I sill would like to see a objective comparison between the same airplane
with VGs and without.
Rick Neilsen
Redrive VW powered MKIIIC
R. Hankins
Joined: 18 Jan 2006 Posts: 185 Location: Grants Pass, Oregon
Posted: Sat Jan 12, 2008 10:13 pm Post subject: Re: VG's effect on Runway Leingth |
Holy large runways Batman! Thanks for the chuckle.
Here is a picture taken just before launch from my brother's place. His house and trees are behind me, so it is one way in and out. Made aprox. 10 landings over two days visit last July. Field elevation is 4100'. I had to use my new brakes once on day two with a tailwind.
Oh. I almost forgot to mention that I don't have VG's
226 KB |
758 Time(s) |
_________________ Roger in Oregon
1992 KXP 503 - N1782C |
JetPilot
Posted: Mon Jan 14, 2008 8:31 am Post subject: Re: VG's effect on Runway Leingth |
I was hoping someone would see the humor in that When I saw how that picture turned out, I just had to post it. At 11,200 feet long, even the newbies I often let fly can hit it most of the time...
That does look short ! Do you go over, or turn away from the power lines ? The cows in the next field look like interesting targets Do they run or just ignore you as you fly over ?
Russ Kinne
Posted: Mon Jan 14, 2008 8:46 am Post subject: VG's effect on Runway Leingth |
Cows run. Where do you think whipped cream comes from??
On Jan 14, 2008, at 11:31 AM, JetPilot wrote:
[Wink] Do they run or just ignore you as you fly over ?
http://forums.matronics.com/viewtopic.php?p=158011#158011
