Vinyl graphics
wadegreaves
PostPosted: Fri Jan 11, 2008 12:36 am    Post subject: Vinyl graphics Reply with quote
How do vinyl graphics do on polytone?
My recent battle with mysterious polybrush behavior is behind me and most of the 1st coat of silver is on there. Was warned by many to not be upset by the appearance of things after the first coat is put on. To be honest, it looks great and have not pulled out the sandpaper yet! This is a kick the the pants to get the spray coats going!
Looking to do my S7 up in O-1 Bird Dog markings after being inspired by the Sorensen Bearhawk on the cover of the recent 'Sport Aviation'. Will substitute their black band on fuselage and black rudder with a light color.
Anyone have good experiences with any particular online vinyl lettering company?
Attached is concept....you can also see my modified fairing around the landing gear. Tubes bonded to wood 'box' surrounding landing gear.
 Filesize:  1.02 MB
 Viewed:  657 Time(s)
Tom Jones
PostPosted: Fri Jan 11, 2008 6:07 am    Post subject: Re: Vinyl graphics Reply with quote
I have some vinyl graphics on polytone . Put them on when the polytone had been on for one year. They have been on for seven years now. Six years as a hangar queen and nine months flying now. They still look like new.
My wife made the designs on her computer and put them on a CD. I took the disk to a sign shop and they printed them up. I had them print the N numbers too.
 Filesize:  235.46 KB
 Viewed:  634 Time(s)
Tom Jones
Classic IV
Ellensburg, WA
kcflys
PostPosted: Fri Jan 11, 2008 8:07 am    Post subject: Re: Vinyl graphics Reply with quote
Wade,
My 2 cents but have you considered the consequences of that color scheme if they have to search for you?
Something I heard weather real or not was the response from FAA that sure you can paint your plane "camo" but if you go down don't expect us to come looking for you
Keith C.
kitfox wannabe
C-150
Rancho Cordova CA
akflyer
PostPosted: Fri Jan 11, 2008 9:17 am    Post subject: Re: Vinyl graphics Reply with quote
the plane does not look "camo" it looks like standard olive drab.
I have the local cutter make paint masks for mine. they go on like the vinyl graphics, but are paint masks. put em on, paint, peel em off and you have the perfect details. They cost about the same as the vinyl, but the paint will last forever and not start lifting on ya.
DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
Float Flyr
PostPosted: Fri Jan 11, 2008 10:12 am    Post subject: Vinyl graphics Reply with quote
I e-mailed my design for my tail graphic and the size I wanted to a sign shop a distance away... the next time I was in the town I went in a picked up my graphics.
They even cut the letters out and placed then on separation paper so it was easy to place.
Hope this comes through.
Noel
Mod III-A
 Filesize:  43.61 KB
 Viewed:  604 Time(s)
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Float Flyr
PostPosted: Fri Jan 11, 2008 10:13 am    Post subject: Vinyl graphics Reply with quote
Be sure if you crash, to crash upside down so the light blue will be
visible... Nah... file a flight plan, it's easier
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Float Flyr
PostPosted: Fri Jan 11, 2008 10:33 am    Post subject: Vinyl graphics Reply with quote
I think a graphics supply shop will call the material "Frisket". I used to
use it when air bushing photos. Digital is much faster and easier to
replace if the skins have to come off. Mine are on a float plane with no
lifting problems. Unless the pattern is complex use thin masking tape.
Noel
Newfoundland
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Michel
PostPosted: Fri Jan 11, 2008 11:24 am    Post subject: Vinyl graphics Reply with quote
used to
He he! Been there - done that too, Noel! Put the frisket on the
artwork, then cut it with a swivel knife with enough pressure to cut
the frisket but not too much, not to cut the art board. At the time, I
was painting sailboat illustrations with airbrush. There was little
margin for error and - as you may guess - when digital tools with the
magic button "UNDO" came, I was delighted and the airbrush went on the
shelf ... where it still is.
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200
Float Flyr
PostPosted: Fri Jan 11, 2008 11:49 am    Post subject: Vinyl graphics Reply with quote
I found my first airbrush the other day in an old tool box with pipe
fittings. Electronic is faster cleaner and you can really exercise the
"undo" button. Working on photographs is an education with the knife
though. It can give you direction in exactly what it is you will want to
do.
Noel Loveys
AME Intern, RPP
Kitfox III-A, 582,B box
Ivo IFA, Aerocet 1100 floats
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
akflyer
PostPosted: Sat Jan 12, 2008 10:02 am    Post subject: Re: Vinyl graphics Reply with quote
I guess I should clarify, I had the masks cut for my N numbers, the fuse striping was just masked off in normal fashion with tape/paper.
I just figured, if you were going to have decals made, for about the same price you can have masks made and paint it on. The end result would be a better looking product IMO.
DO NOT ARCHIVE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
