dfischer(at)iserv.net Guest
Posted: Wed Jan 09, 2008 7:23 am Post subject: Falcon Pitot Tube |
I have a chromed Falcon heated pitot tube without the static air line.
For the airspeed connection, it has a tapered fitting (like an AN
fitting). Does anyone know what the fitting surface angle is on this
pitot? I have a 37-deg Flaring tool and I want to run aluminum line for
10-12 inches for heat dissipation. Is the taper 37-deg? Will the Falcon
fitting work with a 37-deg. flare? Thanks in advance for any help!
Doug Fischer
RV-9A wings
khorton01(at)rogers.com Guest
Posted: Wed Jan 09, 2008 10:50 am Post subject: Falcon Pitot Tube |
On Wed, 9 Jan 2008 10:17:02 -0500 (EST)
dfischer(at)iserv.net wrote:
You should be able to get a pretty good idea by holding the pitot tube fitting next to an aviation fitting and comparing the angles with the Mark I eyeball. It is quite likely a 37 deg aviation flared fitting.
Kevin Horton
