dhall(at)donka.net Guest
Posted: Wed Jan 09, 2008 2:43 am Post subject: good warning label |
Sorry for the slow reply back on this.
I ordered steel braided "performance" brake lines online from Advance Auto Parts. You cannot buy them in the brick and mortar stores (common around Atlanta at least), but the local store did say I could use them for return if I had an issue. The stores do have paper versions of the catalogs for all the parts that are sold online. The brake lines are listed under the "performance" parts on their website. Russell Performance was their supplier. I contacted them directly to make sure I was getting 37 deg flare.
I ordered some 20" straight an4-an4 braided steel braided lines at $37 each. I was pleasantly surprised that the steel lines had a clear protective coating which will keep the lines from chafing my rudder assembly. They had unique part numbers for various length lines, so make sure you're specifiying a part number that matches the length you want.
You can also do build-to-order hoses from Aircraft Spruce. Build-to-order hoses should be expected to cost a little more. I'm a big fan of Aircraft Spruce. The speed that they ship out orders amazes me, and has saved me a nice chunk of time over the course of my project.
Don Hall
N517DG (registered)
rv7 finishing
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Jim Fogarty at Lakes & Leisure Realty
Sent: Thursday, December 20, 2007 11:34 AM
To: rv-list(at)matronics.com
Subject: Re: good warning label
Don,
How about the fittings are they standard AN4 fittings that would be compatible to our fittings? You have the hoses in your shop, do they fit okay on the brake fittings? Do you think it would be a good place to order our brake hoses through and how was their service and turn around time?
Do you have a link to the shop you are working with?
Jim
RV9 Builder
