lgold(at)quantum-associat Guest
Posted: Sun Dec 23, 2007 10:02 pm Post subject: Low voltage problem in a new plane |
Robert,
The low-voltage buss indicator light stays on in my new plane and I would really appreciate help to understand what to do about it.
I just finished building a Zenith 701 with a new 100-HP Rotax 912 using your Aeroelectric’s Z16 schematic. B&C did not have the exact Alternator OV detection system shown in the schematic and sold me their BC207-1 over and low voltage control module that has a warning light which stays on for under and flashes for over-voltage. The B&C web site says that the low voltage light goes on if the Buss voltage is under 12.5V. I wired this module exactly as shown in Z16.
I flew the plane for the first time yesterday starting with a fully charged battery and all seemed well. On the second flight that day I noticed that the Alternator under voltage (UV) light came on with the engine idling when the electric fuel pump was on. Since I don’t need the pump (fuel is gravity fed and the engine has a mechanical pump) I just turned it off and may have advanced the throttle beyond its high 2000-RPM idle. The UV light went out as I did this. I was happy and did my first solo flight in the plane for a half hour without incident. Today, assuming the battery was fully charged (I did not check it), I made some adjustments to the Dynon instrument for about 30 minutes (drawing about 1 to 2-amps), and started the engine for a few more go-arounds in the pattern. The engine stared immediately so I guess the battery was charged . However, the low-voltage light came on as soon as I started-up and would not go off, even after a 10-minutes warm-up, much of it above idle RPM, with almost nothing electric turned on. When I taxied back to the hanger and shut down (with the UV light still on) my battery voltage read 12.3V (this is a new battery).
There are probably a lot of things I need to check to isolate the problem and need advice as to how to go about doing this. What is the most likely cause? What should I check first and second, third… and how do I check them. Here are some of my (probably dumb) more specific questions: - Is this a definite problem or will the this under voltage light come on as described above when there are no problems?
- There are two fuselinks attached to the Alternator OV/UV module. If one of these blew or got disconnected would it cause this problem? Since this is easy to check, I plan to look into this first.
- Is it possible that the problem is in the voltage regulator? How do you check this out and determine if the regulator and not the alternator is the cause?
- I’m not certain how to check the alternator or AC voltage. First, is this a likely source of the problem? Second, if so how do I check the alternator output? If the alternator is bad I probably will have to remove the engine and find a “real” repairman to fix it, so I hope the problem lies elsewhere.
Any help would really be appreciated.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Best regards and happy holiday,
Les
nuckolls.bob(at)cox.net Guest
Posted: Mon Dec 24, 2007 10:56 am Post subject: Low voltage problem in a new plane |
At 10:00 PM 12/23/2007 -0800, you wrote:
Robert,
do about it.
as shown in Z16.
I presume that you tied the OV/LV warning
light into the main bus as shown in Z16 but
wired the module in accordance with instructions
provided with the device.
The Rotax alternators don't give you much output at
idle or taxi speeds. It's possible if not probable that
the bus voltage was indeed too low to turn out the
LV warning light.
without incident.
Okay. This is pretty much what I would expect.
Get a voltmeter and put it on the bus while you're
observing the Under-Voltage warning light. So far, the
observations you've reported seem pretty common. PM
alternators on the Rotax engines are, first of all,
small. The BIG guy on the 912 is an 18A machine and
then ONLY at cruise RPM. If you ran accessories on your
battery for a time, then it's going to take some time
to replace that energy . . . and it's not going to happen
fast except AFTER engine RPMs are raised to flight ops
levels.
For the moment, I don't see that your system is
performing in an unexpected manner. It's designed
in limitations for alternator output at low engine
RPM would account for what you've observed.
on as described above when there are no problems? There are two
Let us begin with the reasonable assumption that you
don't have a problem. Put a smart battery charger
on the battery and get it topped off. Then go fly
the airplane. Doesn't your Dynon have a voltage display
on it?
I would expect the Low Volts warning to stay lit
until some time after takeoff. You can tell if the
alternator is working by watching the voltmeter.
At ramp idle and with electro-whizzies turned ON,
bus voltage will be decidedly less than 13.0 volts.
As soon as you power up for takeoff, the bus voltage
should rise . . . not high enough perhaps to turn
out the light, but if the alternator is working at
all, bus voltage should come up with engine RPM.
I'm betting the light will go out after a time sufficient
for the alternator to top off the battery.
Posted: Mon Dec 24, 2007 12:37 pm Post subject: Low voltage problem in a new plane |
Thanks Bob,
You don't know how much this helped. I read your book and came to one of
your weekend sessions but am still a total novice when it comes to
understanding these systems.
Have a great Christmas,
Les
[quote] --
Joemotis(at)aol.com Guest
Posted: Mon Dec 24, 2007 1:00 pm Post subject: Low voltage problem in a new plane |
In a message dated 12/23/2007 10:05:49 P.M. Pacific Standard Time, lgold(at)quantum-associates.com writes:
| Quote: | | When I taxied back to the hanger and shut down (with the UV light still on) my battery voltage read 12.3V (this is a new battery). |
So, have you checked voltage on the buss with the engine running? Maybe the device is accurate and you really are in a UV situation.
Joe Motis
Do not archive.
See AOL's top rated recipes and easy ways to stay in shape for winter.
Posted: Mon Dec 24, 2007 4:24 pm Post subject: Low voltage problem in a new plane |
Joe,
I will not be able to get to the plane for a week, but you can be certain i will check the voltage as soon as i can. (I think my Dynon shows voltage and current). I guess anything higher than 12.5V is Ok but am not certain of this.
Les
[quote] From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Joemotis(at)aol.com
Sent: Monday, December 24, 2007 12:58 PM
Subject: Re: Low voltage problem in a new plane
Joe Motis
Do not archive.
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List
| [b]
glastar(at)gmx.net Guest
Posted: Tue Dec 25, 2007 1:34 am Post subject: Low voltage problem in a new plane |
Les,
2 things coming to my mind if you have the Dynon D10A (or the
D1007DEK180) do NOT connect the keep alive wire (pin 2 on the D10A) if
you have an internal battery, as it might drain your battery by
recharging the internal one. Upgrade your Dynon to the 3.x or 4.x software.
Ad I would advise you get into the setup menu of the D10A/100/180 enable
the info for the voltage on the right or left side. BTW even if you do
not have enabled this, when you shutdown one with internal battery and
have software 4.0 loaded the internal battery will show up during the
grace periode before total shutdown. Good thing to check the internal
battery voltage.
br Werner
Les Goldner wrote:
Thanks Bob,
Les
Posted: Tue Dec 25, 2007 11:29 am Post subject: Low voltage problem in a new plane |
Werner
I have the Dynon 180. Thanks for the advice, which I will follow before the
next engine startup.
Les
[quote] --
Posted: Tue Jan 01, 2008 8:42 pm Post subject: Low voltage problem in a new plane |
Bob,
I really think there may be a low voltage problem with my aircraft.
I followed your instructions and put a smart charger on the battery for a
full day before a two-hour flight today. With only minimal current draw from
the Dynon, my ICOM portable VHF, the battery contactor relay, and the
strobes, the low voltage light would not turn off. When the strobes were
turned off, the light did extinguish. I put a voltmeter across the battery
before start-up. It read 12.8V. Is this normal for a new fully charged
battery?. After landing it read 12.3V. Doesn't this indicate that I have a
problem and I could loose battery power on a longer flight or when running
other electrical components?
I checked all my wires and connections. They appear OK. Unfortunately I
don't trust the Dynon 180 voltage so I have to find another meter if I want
in-flight readings. Would you suggest any further testing before
changing-out the voltage regulator?
Thanks again for your help.
Les
[quote] --
Posted: Tue Jan 01, 2008 10:36 pm Post subject: Low voltage problem in a new plane |
At 08:41 PM 1/1/2008 -0800, you wrote:
<lgold(at)quantum-associates.com>
Bob,
Les
Absolutely. If you don't already own a good
multimeter, this is an excellent opportunity to
acquire one . . . I just realized that all
of our discussions to date did not include independent
voltage data from another instrument.
Suggest you check out one of these products:
http://tinyurl.com/2xkmnq
http://tinyurl.com/yume4t
Both are an excellent value and offer a next
order of voltage measurement accuracy for
resolving any differences between Dynon
readings and the behavior of the LV warning
light.
Your bus voltage in cruising flight with
light loads should be on the order of 14.2
to 14.5 volts.
Posted: Sat Jan 05, 2008 4:11 pm Post subject: Low voltage problem in a new plane |
Bob,
battery?.
Yes . . .
| Quote: | After landing it read 12.3V. Doesn't this indicate that I have a
Check the voltage in flight with a known-good instrument.
Your alternator should boost the battery to 13.8 to 14.6 volts in cruise.
