Lynn Matteson
Posted: Sat Jan 05, 2008 7:31 am Post subject: Rule breakers Was: Re: This feud isn't pretty! |
KFM-
Sounds like you're living up to your motto: if you're not getting
razzed from pilots or the FAA then you're not flying enough : )
Lynn Matteson
flying w/450+ hrs
On Jan 5, 2008, at 10:13 AM, kitfoxmike wrote:
<customtrans(at)qwest.net>
John,
I can understand your concern. But now lets look at it another
way. I went into a small airport and nobody was around I mean
nobody, early in the morning. I decided to do touch and go's on
all the runways, shouldn't be a problem, I added in short
approaches to get in 5 touches on each runway, total of 4 with
opposite direction put in there. 5 days later I get a letter from
the airport manager stating that there were multiple complaints
about me doing erratic flying at their airport and if it continues
they will turn me into the FSDO. I did nothing wrong, but somebody
on the ground didn't like my flying and got with his friends and
they complained to the airport manager.
That brings up another thing, if a person is upset with you, that
person goes to his friends and congers up a rule that you broke and
the bunch of them turn you in, it can be from drinking before
flying to just about anything they can think of, does this happen,
yes it does.
I think we just need to keep away from the FAA and let them do
their job.
If you have a problem with a pilot, go talk to him. Best of all
stay out of his flying.
One last thing, most of those people that turn people in, their
hangers are right on the approach end of the runway. They
literally sit in a chair and watch people all day long.
kitfoxmike
model IV, 1200
speedster
912ul
building
RV7a
slowbuild wings, fuse, finish kit
"if you're not getting razzed from pilots or the FAA then
you're not flying enough"
http://forums.matronics.com/viewtopic.php?p=156129#156129
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
MichaelGibbs(at)cox.net Guest
Posted: Sat Jan 05, 2008 9:13 am Post subject: Rule breakers Was: Re: This feud isn't pretty! |
kitfoxmike sez:
| Quote: | 5 days later I get a letter from the airport manager stating that
there were multiple complaints about me doing erratic flying at
their airport and if it continues they will turn me into the FSDO.
I did nothing wrong...
"Perception is everything," as they say. Unfortunately, as aviation
enthusiasts we are involved in a constant PR struggle. The general
public perceives us as noisy, dangerous, and unnecessary. The
reality is that we are very tiny minority of the population and if we
ignore these concerns we will ultimately get regulated away due to
public pressure on government officials.
Mike G.
N728KF
Phoenix, AZ
akanka(at)kiamichiwb.org Guest
Posted: Sat Jan 05, 2008 12:34 pm Post subject: Rule breakers Was: Re: This feud isn't pretty! |
Mike,
My intent in responding to this is not to stir up controversy, nor to point
the finger at anyone. I'm only posting the following to let folks get a
look at some of the things that are overlooked, or forgotten from our
initial and recurrent training. My purpose here is simply to point out that
what many of us expect in a traffic pattern as pilots is not the way a lot
of folks fly.
You posted that you that you did nothing wrong in your response below. I
invite your attention to Section 4-3-3, and Section 4-3-4, in the
Aeronautical Information Manual, Airport Operations, the Official Guide to
Basic Flight Information and ATC Procedures for all pilots in the USA. What
you described below is not what other pilots that are familiar with
procedures would expect on an airport open to the public. You apparently
did not cause a concern for another aircraft in that instance, however, if
you look at those sections I mentioned, you will see that you did not follow
recommended procedures. The Aeronautical information Manual can be found at:
http://www.faa.gov/airports_airtraffic/air_traffic/publications/atpubs/aim/
I have seen the FAA issue a citation for simply making a long (10 mile or
so) straight-in approach to an uncontrolled airport, citing careless and
reckless operation as the offence in that he failed to follow recommended
procedures. They got a conviction for the offence by a Federal Magistrate.
The FAA inspectors were on the airport at the time the guy made that long
approach.
As I said, I'm not attempting to point fingers or otherwise find fault with
what happened, just to point out that we all forget things and that we need
to keep on our toes when we share the airspace with others.
John Hart
Model IV
Latimer County, OK
