		russ(at)wernerworld.com Guest
				 Posted: Fri Jan 04, 2008 11:02 am    Post subject: Fuel vents |
				I seem to be one of the very few on the RV or Rocket list that  get fuel fumes during turbulence or acro with tanks over half full.  I have  the vent lines run up and back down per vans plans and exiting from the floor in  the footwell box area.  I'm considering the Andair check valves with  bleeds.  Anyone tried this?
  I also plan to try some plastic tubing to temporarily relocate  the outlets to see what's up.  I get lots of air in the flap actuator link  holes so I assume that is where the fuel slopped overboard is getting into the  cockpit.  Possibly moving these way aft would help, but you never really  know which way the air is really going in any given spot.
  Anyone have any other ideas?
  Russ
  HRII
  |  | - The Matronics Rocket-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		bluebird266(at)dslextreme Guest
				 Posted: Fri Jan 04, 2008 11:13 am    Post subject: Fuel vents |
				DONT FLY IN TURBULENCE OR DO ACRO
 CHUCKLE
 Wernerworld
  	  | Quote: | 	 		   I seem to be one of the very few on the RV or Rocket list that get fuel
  Russ
  HRII
		T.gummo(at)verizon.net Guest
				 Posted: Fri Jan 04, 2008 12:44 pm    Post subject: Fuel vents |
				N561FS - Harmon Rocket II,  does like to put fuel  fumes in the cockpit during acro or upside down flight.
  Tom Gummo
 Apple Valley, CA
 Harmon  Rocket-II
  http://mysite.verizon.net/t.gummo/index.html
  [quote]   ---
		f1rocket(at)telus.net Guest
				 Posted: Fri Jan 04, 2008 8:45 pm    Post subject: Fuel vents |
				Mine does as well, but only when the tanks are quite full.
 Jeff
 Quoting Tom Gummo <T.gummo(at)verizon.net>:
 [quote] N561FS - Harmon Rocket II,  does like to put fuel fumes in the cockpit during
  Tom Gummo
  Apple Valley, CA
  Harmon Rocket-II
