Oil-canning
reinkings(at)comcast.net
PostPosted: Fri Jan 04, 2008 5:12 pm    Post subject: Oil-canning Reply with quote
Okay, I'm a newbie but what is oil-canning? Is it the flexing of the
skin between the skeleton components? The skins on my rudder all have
some flex (give?) in them. Is this a problem? I'd really appreciate
your input on this. I always thought that the skins would have less
flex (tightness). I'm confused about this issue.
amyvega2005(at)earthlink.
PostPosted: Fri Jan 04, 2008 5:22 pm    Post subject: Oil-canning Reply with quote
oil canning is not a problem, it is when the metal at certain speeds pops in and out betweeen the support areas. NO BIG DEAL. WE are not building 747s.
Joemotis(at)aol.com
PostPosted: Fri Jan 04, 2008 6:50 pm    Post subject: Oil-canning Reply with quote
Oil used to be sold in cans. Think a cardboard tube with punched sheet metal ends crimped on. When the can had been punctured and drained, you could take your finger and push on the can end and it would collapse in and make a sound "dink".
Then when you released pressure, it would pop back and make the sound 'donk'
Zenith (and many other) aircraft are prone to the same thing with wing skins etc.
Yes I am old
Had a Chevy truck with a can opener tied on under the hood.
Joe Motis
Start the year off right. Easy ways to stay in shape in the new year.
ter_turn(at)yahoo.com
PostPosted: Fri Jan 04, 2008 7:17 pm    Post subject: Oil-canning Reply with quote
We used to get a free can opener with every six pack of beer too! Oh, the good old days.
do not archive!
Hope this useless info doesn't drive Larry over the brink!
Joemotis(at)aol.com wrote:[quote] Oil used to be sold in cans. Think a cardboard tube with punched sheet metal ends crimped on. When the can had been punctured and drained, you could take your finger and push on the can end and it would collapse in and make a sound "dink".
Zenith (and many other) aircraft are prone to the same thing [quote][b]
grs-pms(at)comcast.net
PostPosted: Fri Jan 04, 2008 7:19 pm    Post subject: Oil-canning Reply with quote
Also, around the shop or house, light oil used to be dispensed from a hemispheric-shaped can with a long spout and a slightly convex bottom. When you upended the can and pushed on the bottom it would make that characteristic "dink" sound and a few drops of oil would be forced out the spout.
I admit to being old, too.
George
n4546v(at)mindspring.com
PostPosted: Fri Jan 04, 2008 7:59 pm    Post subject: Oil-canning Reply with quote
To add to Joe's experience;
Oil cans containing lubricating oil used to be made as shown in the photo. They had no pump. Their bottoms were convex (bulged to the outside). To use, one tipped the spount to the area to be lubed, and with your thumb in the center of the convex bottom, you pushed that metal which flexed from convex to concave shape. This action forced oil out the spout. When you released pressure with your thumb, the metal bottom popped back to the convex shape, ready for another push. When the can bottom was pushed in and released in this manner, it made the "dink, donk" sound described by Joe. This motion of metal flexing, along with it's associated noise, is know as "oil-canning" as it sounds like the everyday use of a old time oil can.
In the movie "The Wizard of Oz", while traveling along the Yellow Brick Road, the charectors come upon the Tin Woodsman rusted in place. Through rusted jaws, he directs them to a such a oil can which they then used to lube and free him up, with plenty of "dink,donk" sound. Ask your Kids or Grandkids!
Time for another drink,
Randy, Las Vegas
 Filesize:  25.16 KB
 Viewed:  487 Time(s)
purplemoon99(at)bellsouth
PostPosted: Fri Jan 04, 2008 8:16 pm    Post subject: Oil-canning Reply with quote
I'am so old that I remember when you couldn't buy soda in a can .... Joe N101HD                     do not archive
skyridersbn(at)yahoo.com
PostPosted: Sat Jan 05, 2008 3:35 am    Post subject: Oil-canning Reply with quote
Dink-Donk....Dink-Donk........
Be a better friend, newshound, and [quote][b]
notsew_evets(at)frontiern
PostPosted: Sat Jan 05, 2008 7:42 am    Post subject: Oil-canning Reply with quote
I remember when they came out with a new fangled gadget that had a trigger looking thing that you would actually pull and the oil would squirt out like magic but I aint never learned about english and running sentences...
PostPosted: Sat Jan 05, 2008 11:41 am    Post subject: Oil-canning Reply with quote
Amen.
