Shock cords -- FWIW (triv)
Goto page 1, 2  Next
Fox5flyer
PostPosted: Mon Dec 31, 2007 12:11 pm    Post subject: Shock cords -- FWIW (triv) Reply with quote
My model II/582 had bungee gear and I never understood what all the fuss was about. It landed straight and I changed out two sets of shock cords over 4 years (3 counting orig), spending perhaps a couple hours on each set (I made my own). I put just under 400 hours on it and I was always amazed at how resilient the system was. Never had a problem. I now have a S5 and with nearly 400 hours on spring gear which is also nice, but it came with the package so I was kinda stuck with it. I do remember that during building I weighed the entire spring gear assembly with wheels and tires and it came to about 75 lbs. I don't know how that compares with the bungee gear, but it sure seemed heavy. Then again, it has held up quite well on my farm strip.
For all you bungee gear users, here's what Dan Denny had to say about shock cords.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 355+ TT
"Nothing will ever be attempted, if all possible objections must first be overcome".- Samuel Johnson
"SUBJECT: Shock Cords
TO: KitfoxT Model III & IV Builders
Dear KitfoxT Builders,
Over the course of the past several months, good quality shock cord has been
increasingly difficult to obtain. The shock cords (LSC-19) included in your
landing gear kit may be fabricated of one of three different types of bungee
material.
Some of this material is of smaller diameter than the original stock. You
may have to take more wraps than indicated by the instructions, Step (22)
and Figure LGH-6.
The original material is .41" diameter and color coded with two rows of
black threads and one of red. Install it according to the manual (six
wraps).
The smaller cord is about .33" diameter and marked with 3 rows of green
threads. You will have to take about eight wraps. It seems to be good
quality bungee material and should work just as well as the original.
For a time we sent bungee material that has proven to be of inferior
quality. It is about 7/16" (.41") diameter and marked by paired bands of red
and green. These shock cords do not last at all. Return them to the factory
and we will be happy to replace them with the better - quality cords as soon
as possible.
Happy building
Dan Denney
[url=]rexjan(at)bigpond.com[/url]
dave
PostPosted: Mon Dec 31, 2007 12:42 pm    Post subject: Re: Shock cords -- FWIW (triv) Reply with quote
Deke,
Attached is a pic of mine with well over 700 hours on them.
Look like RED RED Yellow ?
Next pic will show mine that are not tight to stops.
I agree-- whazzzzzzzzza all da fuss about ?
Use what works and is proven.
Daves Kitfox Bungees well over 700 hours !!!!!!
 Filesize:  634.64 KB
 Viewed:  780 Time(s)
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube
dave
PostPosted: Mon Dec 31, 2007 12:43 pm    Post subject: Re: Shock cords -- FWIW (triv) Reply with quote
Here is pic of Gear not touching stops .
Seems ok so far ,,,,,,,,,, Smile
Landing gear stops
 Filesize:  457.76 KB
 Viewed:  771 Time(s)
Fox5flyer
PostPosted: Mon Dec 31, 2007 1:51 pm    Post subject: Shock cords -- FWIW (triv) Reply with quote
I think if you want perfection they should be right to the stops, but a
little sag doesn't hurt anything, in my opinion. I notice you use the
safety cables. Many years ago there was a long thread on this subject.
There were reports of some members who made hard landings, hard enough so
that the safety cables maxed out and bent the lateral bulkhead that the
cables are wrapped around. There may still be pics on Sportflight.com
somewhere. If I recall correctly, Skystar published a bulletin recommending
that safety cables not be used for this reason. It's rare for a bungee to
break anyway.
Deke Morisse
Mikado Michigan
dave
PostPosted: Wed Jan 02, 2008 3:30 am    Post subject: Re: Shock cords -- FWIW (triv) Reply with quote
Deke, thanks. Yes I agree tighter might be optimum but like i said i have the last 2 seasons flying with one less wrap and not tight against the stops. Perhaps this has helped the bungees last longer as well? I do have on with the outer jacket frayed but strands seem intact so far.
Bending the tubes would not be nice but would be the lesser of evils then smacking prop and bending a gearbox or crank and/or more damage to wingtips,gear etc.
Man you would have to hit hard to bust a cable like that .
Fox5flyer
PostPosted: Wed Jan 02, 2008 5:03 am    Post subject: Shock cords -- FWIW (triv) Reply with quote
That's exactly the problem. The cables don't break so something has to
give.
Deke
wingtips,gear etc.
Rotax Dealer, Ontario Canada
Flying Videos and Kitfox Info
http://www.cfisher.com/
http://forums.matronics.com/viewtopic.php?p=155502#155502
dave
PostPosted: Wed Jan 02, 2008 6:09 am    Post subject: Re: Shock cords -- FWIW (triv) More cable talk Reply with quote
give.
Deke
So are you saying the cables should break? I would that in the event of bungee failure the cable would arrest the gear from total collapse and potentially saving a prop strike and possibly more.
I will add that I have 1/8" cable attached to engine in 2 places ,routed through the firewall, and looped around the fuselage aft of the firewall in the event of a prop failure where you could lose the engine and would lose control. In this case again the cable would save you again from more damage but at the cost of possibly denting,collapsing or destroying fuselage tubing.
lcfitt(at)sbcglobal.net
PostPosted: Wed Jan 02, 2008 9:36 am    Post subject: Shock cords -- FWIW (triv) Reply with quote
Dave,
I don't think you got Deke's point. There have in fact been guys that had
to trailer their Model IVs to the Skystar factory for replacement of the
bulkhead the bungees wrap around because of a hard landing caught by the
limit cables which essentially destroyed the bulkhead. Securing the
engine - smart move, but securing the landing gear - very questionable move,
in my opinion and Skyster corrected their design error.
I guess it is up to the individual what he would prefer replacing - the prop
and possibly the gear box (crank) on his engine or the bulkhead weldment
with all the fabric repair, paint, etc. Believe it or not, the damage
incidents are factual rather than the typical argued opinions so very common
on aviation forums.
I don't know if these reports still appear in the available archives, (When
I last checked, I couldn't find anything prior to the turn of the century)
but these reports were the real reason I went to the Hammerhead gear.
Consider Hammerhead and Grove, the same way we consider Kitfox and Avid,
however in this case it was Hammerhead that went south first.
Lowell
dave
PostPosted: Wed Jan 02, 2008 6:31 pm    Post subject: Re: Shock cords -- FWIW (triv) Reply with quote
Lowell,
I am still wondering why you are suggesting no safety cable on the bungee gear? There are there for a reason to arrest the gear in the event of a bungee failure. Without it alot of damage could occur. If there was a safety bulletin that I missed please post it.
If the reason to not use them is to not bend a cross member in the event of a hard landing then i would suggest some one better learn to land better. You are talking some serious G's here to do that kind of damage. Possibly close to what you experienced in your accident.
I would highly recommend that you talk to your Kitfox supplier to see if it is advisable to not use safety cables -- they are there for a reason.
Next point -- is it possible that the cable in the cases you mention where never properly installed and possibly too long or short of a loop that caused this damage?
The bungee suspension could be made stronger and eliminate the Bungees by using a compression spring type suspension , but you would end up like the Grove or Hammerhead gear with extra weight that was not necessary. Goes back to the Keep it simple theory. How does formula go? For every pound of weight you add to your plane you will lose 3 to 4 FPM of climb rate.
Speaking of bent tubing -- I would rather see Bent 4130 tubing then cracked or broken tubing that was too brittle.
MichaelGibbs(at)cox.net
PostPosted: Wed Jan 02, 2008 8:00 pm    Post subject: Shock cords -- FWIW (triv) Reply with quote
Dave sez:
If the reason to not use [safety cables on the gear] is to not bend
Actually, it doesn't take all that many gs. There have been several
cases of moderately hard landings stretching the bungees far enough
for the safety cables to put an excessive load on the truss and
collapsed it.
Rather than remove the cables I decided to use the Grove gear to
avoid the problem.
Mike G.
N728KF
Phoenix, AZ
PostPosted: Wed Jan 02, 2008 8:38 pm    Post subject: Shock cords -- FWIW (triv) Reply with quote
Dave,
Good question. What I am suggesting is that people consider the possible
outcomes of the various scenerios. As you recall, I chose the heavy spring
gear rather than a more cost effestive pair or dikes in my right hand.
When I build again I will likely use tube gear for weight issues, and due to
the destroyed bulkhead will not install the limit cables - my choice. But
then none of my friends flying with bungee gear have limit cables. And then
again, that is a personal preference. But their choice was based on the
possible structural damage with a hard landing.
Now a question for you. With properly maintained bungees, what is the
greater likelyhood, a broken bungee, or a messed up landing. Realizing that
there are different levels of proficiency, one has to consider all sides of
the issue, which is only what I propose. But consider the poor goofballs
like Mark or Wray who might ding their airplanes at any moment with a hard
landing. Mark has nearly 2000 hours in three models of Kitfoxes and Wray
has 3000 hours in DC-3s and 1000 in his Fox, not to mention the Storches and
Learjets - just kidding. Neither have limit cables for the mentioned reason
and we have talked about it many times. They just change out the bungees in
a timely manner. Did I mention off airport landings - tons and lots of
first timers too.
I just thought of another question. Has anyone ever heard of bungees
breaking and the gear hanging on the limit cables or damaging a prop? The
Mil Spec for 3/8" bungees is a minimum breaking force of 300 lbs. Multiply
that by 7 wraps and that's some serious Gs as well for gear legs that
supports between 275 and 400 lbs each.
I searched the Service Bulletins and there is nothing, as you found. There
is, interestingly, nothing on the recommended frequency of bungee
replacemtent either - whatever that means.
Again, I have to say. I have no personal interest in what people do with
their airplanes. For some reason, I find it difficult to sit on my hands
when I know of experiences that others have had that might shed a bit of
light on an issue.
Question the Kitfox supplier - good idea. Best to make a decision after all
the info is in.
Improper installation. Who knows, but the one that most easily comes to
mind - a good friend, we used to room together at the Skystar Fly-ins and I
remember all the details. He was showing off at a local fly-in event at a
private one way strip. He was nicknamed Dr. Downhill after that. He was an
engineer by profession. Who was that man Smile
Lowell
l.morris(at)tx.rr.com
PostPosted: Thu Jan 03, 2008 8:21 am    Post subject: Shock cords -- FWIW (triv) Reply with quote
Lowell, Are you trying to say that my bungee chords stored in a box in my attic since 1994 are no good?(LOL). Really, are there other bungee geared aiplanes out there that use limit cables?----- Leon Morris/Classic 4(94)/60%/like Jab/Flower Mound,TX
---- Lowell Fitt <lcfitt(at)sbcglobal.net> wrote:
Dave,
first timers too.
light on an issue.
the info is in.
Lowell
dave
PostPosted: Thu Jan 03, 2008 10:38 am    Post subject: Re: Shock cords -- FWIW (triv) Reply with quote
Lowell same link i found on google say replace annually.
http://kitfox.lazair.com/Service_Letters/sl48.htm
. The condition of the bungee should also be checked, and it should be replaced annually.
I would really doubt that many Kitfoxes are not using safety cables .
How about a poll......... ?
Fox5flyer
PostPosted: Thu Jan 03, 2008 11:03 am    Post subject: Shock cords -- FWIW (triv) Reply with quote
Dave, I suspect the bulletins and service letters at KitfoxAircraft are not
complete which is not surprising considering all the commotion with the
bankruptcy and picking up the pieces. Somewhere are several photos of
Kitfoxes with the center bulkhead destroyed by these cables when all that
happened was a hard landing. Nobody is trying to sway you into taking yours
off.
Take a poll if you want, but it won't prove a thing and will just eat up
unnecessary space and time. If you like them there, then by all means keep
them. I was just pointing out that Skystar, after the damage, recommended
they be removed. However, those old manuals were probably never changed to
reflect that. I've been involved with Kitfoxes since about 1990 and I
recall zero incidents of bungies actually breaking. When I saw the photos I
couldn't get those cables cut off there quick enough. As for annually
replacing the bungies, nothing new there either. It's always been that way.
Deke Morisse
Mikado Michigan
> There
replaced annually.
http://forums.matronics.com/viewtopic.php?p=155761#155761
dave
PostPosted: Thu Jan 03, 2008 11:14 am    Post subject: Re: Shock cords -- FWIW (triv) Reply with quote
To destroy the center bulkhead you would need on hell of a hard landing.
To tear the cables through the bulkhead you have ot ask your self what "could have " happened had the cables not been there ?
I would not be in a hurry to remove mine or anyones.
I have been around flying not just kitfox but GA to ultralight and homebuilts since 1980.
I would like to see these pictures and referance to remove them.
How does one land thathard anyhow ? Stall and drop straight in from 50 feet ?
Michel
PostPosted: Thu Jan 03, 2008 11:42 am    Post subject: Shock cords -- FWIW (triv) Reply with quote
On Jan 3, 2008, at 8:01 PM, fox5flyer wrote:
As for annually replacing the bungies, nothing new there either.
Er ... maybe, Deke. And, BTW, thanks Dave for the link to the service
bulletin that I had never seen before.
I replaced my bungees last year after ... 13 years and about 950
landings. I thought it was time although the one I removed were still
in a splendid condition. Of course, I do inspect about everything on my
plane, as a pre-flight and at any other occasion I am in the hangar and
e.g. lift the cowling or just admire my bird. Inspection is never
overdone but ... do we really have to change the bungees annually?
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200
Fox5flyer
PostPosted: Thu Jan 03, 2008 12:23 pm    Post subject: Shock cords -- FWIW (triv) Reply with quote
Er...Michel, no you don't have to change them annually. You change them
whenever you want to. I never recommended them be changed annually and I
don't personally believe they need to be changed annually. I was just
making the point that "annually" was -- and unless it has been changed --
the factory recommendation and it's been that way from when Denney had it.
Somewhere there will be a reference to this or perhaps it's right in the
older builder manuals. I dunno. I'm still looking for something that makes
any reference at all to the bungies. If I find it I'll pass it on.
Otherwise, I'm moving on.
Deke Morisse
Mikado Michigan
msm_9949(at)yahoo.com
PostPosted: Thu Jan 03, 2008 1:00 pm    Post subject: Shock cords -- FWIW (triv) Reply with quote
Michel,
The original bungees in my plane came with the kit, delivered in 1989. Prior owner had only 4 wraps on them and I eventually squeezed 7 out of that set of rubberbands. But before the airplane ever flew (2005) I noticed slack had developed in the left bungee. Don't know if it was age (certainly wasn't wear) that caused stretching. Anyway I replaced with a set I made. A year later I replaced again tho old ones still looked fine.
Because the job is such a chore (at least for me) I've asked myself the same question, i.e., is replacement every year really necessary? Personally, I think not. So I'm going with every 2 years, tho I do check their condition routinely.
P.S.: Back to old songs . . . Reading your description of North African adventure, I think I heard "Marakesh Express" playing in the background.
Michel Verheughe <michel(at)online.no> wrote:
[quote]--> Kitfox-List message posted by: Michel Verheughe
Michel Menezes
Model 2 582 N99KX
Michel
PostPosted: Thu Jan 03, 2008 1:11 pm    Post subject: Shock cords -- FWIW (triv) Reply with quote
On Jan 3, 2008, at 9:22 PM, fox5flyer wrote:
I never recommended them be changed annually and I don't personally
Oh, I know Deke! I never implied that. I just wanted the group to know
that, at least in my case, the bungees were still in good shape after
13 years. You know, I have an art education; I know really nothing
about mechanics. In my mind, anything that is made out of rubber or any
other 'soft' stuff, has a limited life time. That's why I changed mine.
But I think those little 'rubber bands' are good stuff and I am
impressed. It makes me think that, after all, it is not a wonder that
no bungee failure has been registered yet and that ... maybe removing
the safety wire is a good idea. I still have mines but I'll be thinking
about removing them.
Michel Verheughe
Norway
dave
PostPosted: Thu Jan 03, 2008 1:26 pm    Post subject: Re: Shock cords -- FWIW (triv) Reply with quote
Michel read up a a few posts ........of mine
Goto page 1, 2  Next
Page 1 of 2
