lgold(at)quantum-associat Guest
Posted: Wed Jan 02, 2008 9:34 am Post subject: Prop-pitch; 701 w/Rotax 912ULS |
I have a few hours on my new 701 and could use some advice regarding maximum RPM and prop pitch.
The prop manufacturer for my 3-blade Warpdrive suggested a 12-degree pitch. Set at 12-degrees, the maximum RPM the 701 can develop is 5375-RPM. The plane seems to fly well with this setting. At cruise RPM (4900-5000) is goes 85-90-MPH and at full RPM, lightly loaded, it will reach the do-not-exceed speed in level flight and climbs over 1400’/minute.
I’m satisfied with the performance but am concerned that I can’t get to the maximum 5600-5800 RPM that Rotax suggests. Do you think I’m OK with the 5375 maximum RPM, or should I decrease the prop pitch?
Thanks for the help,
Les
Posted: Wed Jan 02, 2008 11:25 am Post subject: Prop-pitch; 701 w/Rotax 912ULS |
Les,
The inability to get to the highest rpm the engine is capable of is
probably the wrong approach. You should consider that your performance
optimized
to an rpm that mixes fuel economy, low engine wear and less noise. I'd
increase the prop pitch to the lowest rpm that still reaches the
do-not-exceed
speed and still gives satisfactory climb with a passenger. Sounds like
you're close, but try 13 and then 14 degrees to see how performance changes.
Larry McFarland 601HDS with 17-degree pitch WD 3-blade 70-inch at
www.macsmachine.com
Les Goldner wrote:
1400’/minute.
Les
alex_01
Posted: Wed Jan 02, 2008 11:43 am Post subject: Re: Prop-pitch; 701 w/Rotax 912ULS |
Hi, i fly a 601xl with a 3 blade woodcomp and i have a very steep setting max take of rpm 4600-4700rpm
climbes with approx 900-1000ft/min but has a very nice cruising at 110-115 knts IAS with 4500-4600 rpm and approx 24hg MP
fuel com. approx 15ltr/hour
side effect with less rpm it is also quieter
27.9 KB |
736 Time(s) |
27.9 KB |
759 Time(s) |
NYTerminat(at)aol.com Guest
Posted: Wed Jan 02, 2008 4:28 pm Post subject: Prop-pitch; 701 w/Rotax 912ULS |
Les,
I would reduce the pitch slightly. I am assuming that your max RPM is 5375 in flight right? I would shoot for 5700- 5800 max in flight rpm. You should be getting approx 5350-5400 static RPM. Right now it seems you are over pitched. Congratulations on your first few hours of flight.
Bob Spudis
N701ZX / CH701/ 912S/ 140hrs
In a message dated 1/2/2008 12:36:08 P.M. Eastern Standard Time, lgold(at)quantum-associates.com writes:
I have a few hours on my new 701 advice regarding maximum RPM and prop pitch.
Les
top rated recipes and easy ways to stay in shape for winter.
graeme(at)coletoolcentre. Guest
Posted: Wed Jan 02, 2008 5:07 pm Post subject: Prop-pitch; 701 w/Rotax 912ULS |
My 701 rotax 912
usually two up on acceletation and climb gets 5600rpm a compromise of climb and cruise 70-75 knots.
you should try for 5800 on acceleration and climb.
then check your other figures.
NB. two up every thing is much differant speed and climb wise
you should find in level flight you will over rev if you hold full throttle.
Graeme cns
ronlee
Posted: Wed Jan 02, 2008 6:49 pm Post subject: Re: Prop-pitch; 701 w/Rotax 912ULS |
I talked to Ronnie Smith, and my understanding is that dragging the engine down too much can cause possible cracking of the crank case. In other words don't pitch the prop so much that the engine can't wind up to near the recommended RPM on full throttle.
_________________ Ron Lee
Tucson, Arizona |
billmileski
Posted: Thu Jan 03, 2008 6:52 am Post subject: Re: Prop-pitch; 701 w/Rotax 912ULS |
Les,
Congrats on the new arrival to the 701 fleet. My 701 with 912S and 3-blade fixed 68" Woodcomp performs similarly:
Full throttle static rpm: 5250
Climb: solo at sea level on standard day, ~1500fpm
Full throttle in level flight: 110mph (redline) and not sure but I think less than 5500rpm.
Cruise at 4800rpm is around 85mph and 3.4gph (solo). Cruising at 75-80 seems very light load on everything, with even better economy.
That said, I have often wondered about setting static as high as 5400-5500 and see what the short takeoff performance would be, but would expect that cruise rpm would be higher, as well as fuel consumption. Maybe for the next STOL contest.
If you are getting 5375rpm static (or was that your in-flight max?), that sounds appropriate, for more opinion do an archive search, this topic has been discussed. Cruise at 5000 seems appropriate, personally wouldn't want to spin faster at 85-90. As you fly off the 40hrs (if you have to do a Phase I) you'll find out whether you prefer jump-takeoffs or mellow cruise rpm and increased fuel economy. Lastly, I think lower pitch (higher rpm) might help reduce glide distance at idle if you desire a short approach as well.
Congrats again,
Bill Mileski
Ledyard, CT
701 912S
