Posted: Tue Jan 01, 2008 5:20 am Post subject: Rivet, Rivet ! |
No I m not a frog. Just a 601 XL builder thats not perfect. My aircraft will be close but it too is not perfect.
I dont think any machine is perfect. So,,, that brings me to this:
In a "few" cases I ve had to drill out a pop rivet. I really didnt mess up a part or two but was unhappy with fit, looks, operation and for other reasons.. whatever..
Whats been on my mind is the hole left in the aluminum after drilling out the rivet. I bet all of Zenith builders have learned about drilling out these things..
My real question for discussion is this: If the hole isnt perfectly round after drilling, will the aluminum rivet fill the odd shape of the new hole ? I say yes. Yes to a point.
I m not talking about a football shape, just an out of round hole..
I ve squeezed standard rivets with my squeezer thousands of times in the past and watched as the rivet conformed to the hole. I assume the pop type rivets do the same...
Amazing how I wake up at night thinking about "things".
Steve 601XL QBK
skyridersbn(at)yahoo.com Guest
Posted: Tue Jan 01, 2008 6:21 am Post subject: Rivet, Rivet ! |
I would say that if the hole has become oblonged, you would be better off redrilling it to the next larger sized rivet. The last thing I would want on my aircraft is a sloppy rivet. If left go, I would certainly think that over time, it would work its way loose and then you would have a "smoking rivet" (dark powder around the loose rivet) and place for potential structural failure. Then again, what do I know. I'm not an engineer nor an A & P. I would suggest you call Zenith Air and ASK one of their engineers just to make positive sure. Please let us know what they say about it.
Happy New Year everyone.
Larry
psm(at)ATT.NET Guest
Posted: Tue Jan 01, 2008 8:12 am Post subject: Rivet, Rivet ! |
Hi Steve,
First, let me ask if you really mean Pop rivet or Avex Rivet. If you are using hardware store Pop Rivets then you might consider changing your airplane into a lawn ornament and starting over.
Solid rivets do a nice job of filling whatever hole they are in when they are squeezed or otherwise set in place. This also happens to some degree with Avex rivets, but not nearly as much. The forces and vectors (direction of forces) in the Avex rivet means most of the force is used to form the "Shop" head, and very little goes to deforming the tube to fill the hole. This may not be a problem, or in cases where the hole is badly deformed the resulting bond could be too weak.
You should be able to drill out a rivet without causing any deformity to the hole. I start with the smallest drill I have (#40) and use the next larger drills while drilling part way through the rivet until reaching the same size drill as the one that finished the rivet hole before setting the rivet. This last drill will spin the head off the rivet without even entering the hole. This is all done at low speeds in my battery powered drill. (I doubt you would get such good results in a high speed air drill.) You can then push the other part of the rivet through the rest of the hole or pry it off from the other side with pliers. Sometimes I use a lot of pushing force on an undersized drill and that pushes out the other side while making a larger hole in the doomed rivet.
If you are unhappy with the hole after drilling out the rivet then the accepted practice is to drill out the hole to the next rivet size and install a larger rivet in place of the one you just removed. Another accepted practice is to install two rivets, one on either side of the replaced one, with proper edge distances from the old rivet hole and the other rivets in the line.
I'm sure you will get other opinions on this subject. It seems there is not a whole lot of training for this operation, so we each develop our own techniques.
Good luck,
Paul
XL fuselage
At 05:19 AM 1/1/2008, you wrote:
[quote]No I m not a frog. Just a 601 XL builder thats not perfect. My aircraft will be close but it too is not perfect.
Steve 601XL QBK
Posted: Tue Jan 01, 2008 9:55 am Post subject: Rivet, Rivet ! |
Yes Avex rivets. I just use the aximoron of POP....
My holes are in no way a problem. I actually knew the answers on this question but need reasuring, cause its lonely out here in Arizona...
Its just me and my aluminum parts.
Thanks for the replies...
SW
bryanmmartin
Posted: Tue Jan 01, 2008 10:46 am Post subject: Rivet, Rivet ! |
In my experience, the Avex rivets will do a fairly good job of filling a slightly damaged hole. You should punch out the steel stem from the rivet before attempting to drill it out, This makes it so much easier and less likely to damage the hole.
On Jan 1, 2008, at 11:12 AM, Paul Mulwitz wrote:
Good luck,
Paul
XL fuselage
| Quote: | No I m not a frog. Just a 601 XL builder thats not perfect. My aircraft will be close but it too is not perfect.
Steve 601XL QBK
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
Posted: Tue Jan 01, 2008 12:12 pm Post subject: Rivet, Rivet ! |
Hey Steve, it sounds like you need to "put the pedal to the metal" (literally!) and hustle up on your XL so you can GO SOMEWHERE and enjoy not only your aircraft but to get away from home for a bit. The view outside should be great.....at least better than here in Michigan! Its snowing and blowing outside. The clouds have been so low we can't even THINK about getting off the ground! Has been that way for several months now.....be glad you don't live here!
Larry
rjscep(at)yahoo.com Guest
Posted: Tue Jan 01, 2008 2:38 pm Post subject: Rivet, Rivet ! |
| Quote: | There's always Bondo, many an aircraft hole was
filled with it...Don not archive
not perfect.
brings me to this:
whatever..
these things..
of round hole..
"things".
Steve 601XL QBK
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
Posted: Tue Jan 01, 2008 4:29 pm Post subject: Rivet, Rivet ! |
Larry
I m soooo glad I purchased a QBK.
I would never finish a kit otherwise.
I ve had the QBK since August and today pulled my LAST rivet. Painting is not too far off....
The only real problem that I ve have with this 601 XL is the main spar bolts. You might have read here about a week ago that my spar holes are too big for the 5/16 bolts.
Zenith engineers told me how to solve the situation and they sent new 3/8 bolts. I think its going to be a real pain trying to ream out the holes....
Figured I finish everything first and then tackle the holes.
Im in Bullhead City ( 95 miles south of Las Vegas)
Its 53 degrees today, Brrrrr!
Steve
Posted: Tue Jan 01, 2008 4:58 pm Post subject: Rivet, Rivet ! |
Sorry to hear your getting ONLY 53 there today. We are STILL under a Winter Storm Warning (2nd day now) and the weatherman is predicting ANOTHER 3" TO 8" more of snow tonight. Tomorrow, the temps are going down to single digits and then the Lake Effect Snow is going to kick in over Lake Michigan. Most of times that is really severe and we usually have white out conditions. Sometimes we measure the lake effect snow in FEET. The 12" of snow we had last night is going to be thrown all around when the strong winds that are predicted to hit something later in the night. The snow we've had along with the high winds will cause big snow drifts and I seriously think no one will be doing much traveling tomorrow. Our temps are supposed to go back up into the low 40's next week, which is strange for us this time of year. I'm about 30 northwest of South Bend Indiana, just to give you some idea where I'm at. I'm really lucky because I live on the south end of a private airstrip that is 150' wide and 2650" long......its a sod strip but very nice. I just started my rudder starter kit but I did order the tail section already from Zenith. I'm building the 601 XL. It should be a perfect plane for around here.
Larry
Be a better friend, newshound, and [quote][b]
Posted: Tue Jan 01, 2008 5:34 pm Post subject: Rivet, Rivet ! |
Steve,
I'm surprised the spar would be held by 5/16-inch bolts. The transition
from 5/16ths to 3/8th shouldn't be a problem if you're wing's jigged well.
Drill undersize and ream, then bolt each progressively as you go.
Should be a draggy fit bolt to holes.
I made a drill/reamer guide for getting centered and aligned on the spar
plates. You might be able to do the same and help keep the drill/reamer
aligned.
http://www.macsmachine.com/images/TJH/drillingguides/full/predrill-marking(2).gif
steve wrote:
[quote] Larry
holes....
Steve
planecrazydld(at)yahoo.co Guest
Posted: Tue Jan 01, 2008 5:54 pm Post subject: Rivet, Rivet ! |
please tell me this is a joke - I hope so. You are right - and there have been failures due to this practice...
If it was a joke please forgive my alarmist reaction - I could not tell....
ROBERT SCEPPA <rjscep(at)yahoo.com> wrote:[quote] --> Zenith-List message posted by: ROBERT SCEPPA
not perfect.
brings me to this:
whatever..
these things..
of round hole..
"things".
Steve 601XL QBK
Never miss a thing. Make Yahoo your home page. [quote][b]
Posted: Tue Jan 01, 2008 6:15 pm Post subject: Rivet, Rivet ! |
Larry
I dont mind the enlarging of the holes to 3/8. Problem is that the 601 is
built. QBK came from the factory with the "defect". An easy fix ? Sure if
the airplane is apart. The QBK is pretty much done from the factory. The
factory assembled the whole airframe and the spar holes should have been
PERFECT!
How in the heck am I supposed to ream out these holes with the extremely
small amount of space in the fuselage ??????
If I owned Zenith, I d have one of my people on the next airliner headed to
my customers and fix the situation before a failure happened and a MAJOR
lawsuit happened...
I ve documented all correspondence with Zenith...
Steve
rstone4(at)hot.rr.com Guest
Posted: Tue Jan 01, 2008 6:16 pm Post subject: Rivet, Rivet ! |
Steve,
Go through the existing holes with an 11/32 drill bit, then ream to a tight fit.
Bob Stone
Harker Heights, Tx
ZodiacXL w/Jabiru 3300
Posted: Wed Jan 02, 2008 12:54 am Post subject: Rivet, Rivet ! |
Bob
Shouldnt I use a 23/64 bit? then ream ???
What kind of drill will fit down in the bildge under the seat?
The holes next to the fuselage side skins are so close that I ll need to go out and purchase a small size drill motor...
Posted: Wed Jan 02, 2008 6:38 am Post subject: Rivet, Rivet ! |
Steve,
If you can get in there with an of/set drill head my suggestion of the 11/32 drill bit would make the hole only 1/32 too small and provide just enough meat to ream to a perfect tight fit. A 23/64 would work I suppose but not leave much meat to remove and you could over ream. This process requires a twist or two, then check with a 3/8 bolt until you just about have to force it in.
Bob
Terry Phillips
Joined: 11 Jan 2006 Posts: 346 Location: Corvallis, MT
Posted: Wed Jan 02, 2008 9:06 am Post subject: Rivet, Rivet ! |
There are various close quarters drills and attachments available. I purchased a used item from Brown Tool,
http://www.browntool.com/productselect.asp?ProductID=680
that attaches to my 3/8 electric drill chuck. The used item is a bit beat-up, but functions just fine. Brown sells new ones in various price ranges also. Like most of the really close quarters drills, it doesn't have a chuck. Rather, it requires bits that are threaded 1/4"x28, which, of course, Brown also sells, including very short (9/16"-long) bits for really close quarters. Brown also sells collets which will grip regular drill bits over a narrow range of diameters. (I put collets on my Christmas list for #20 & #30. I haven't used them yet.) Though I am barely into wings, there were a couple of spots on the tail where I used the close quarter drill. It worked like a champ, but I think I'd want to practice a bit before I drilled something thick and really critical like wing spar attachment.
Good luck and happy building!
Terry
At 07:37 PM 1/1/2008 -0700, you wrote:
[quote]Bob
The holes next to the fuselage side skins are so close that I ll need to go out and purchase a small size drill motor... ---
_________________ Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings. |
